Shared utility object for entire project build [message #1844618] |
Fri, 17 September 2021 18:21 |
Elie Richa Messages: 72 Registered: February 2016 |
Member |
Hello folks,
In the generator of my language, I need to resolve a set of objects given a set of known static qualified names. Essentially the generator is aware of a set of qualified names of objects known exist in the project being built. It's a sort of a standard library, but since it's still evolving, for the moment it exists in the runtime project.
In the generator, I use the index the resolve the qualified names into objects as follows:
@Inject extension IndexUtils
def locateObj(EObject context, QualifiedName name) {
context.visibleContainers.flatMap[exportedObjects].findFirst [
name == it.name
]?.EObjectOrProxy
This is proving quite costly in terms of performance because we query the index again each time the generator is called for each resource.
Is there a way to perform this resolution once at the beginning of a project build, and use the same resolved objects for all resources processed in the scope of that build?
Perhaps by initializing a utility object that contains the references to the resolved objects and is shared by all generators called during the build?
Thanks.
Elie Richa, Ph.D
Software Engineer, AdaCore
https://www.adacore.com
Re: Shared utility object for entire project build [message #1844640 is a reply to message #1844623] |
Sun, 19 September 2021 18:37 |
Member |
Hello Neeraj,
Thank you for your reply.
Indeed I have profiled my application and observed the most significant bottleneck at the moment seems to be the querying of the index, and I think there are two reasons for that.
The first reason is that even though resolution happens once, it happens once per resource because a fresh generator is instantiated for each resource (I think?). Since I have hundreds of resources and tens of qualified names to resolve, I end up with thousands of unnecessary resolutions.
The second reason is that the index is organized by resource URI whereas my qualified names are not. So to perform my lookup I am having to combine all global object descriptions into the same iterator to query it. I think that performance could be better if I first query the index for the resource description of the resource where I know the qualified names are, and then query only that description.
But generally I felt it better to address the first point first, i.e. try to only perform the resolution once for all resources instead of once per resource.
Elie Richa, Ph.D
FUDForum. Page generated in 0.03433 seconds
