Home » Modeling » M2T (model-to-text transformation) » Generate text on Annotation
Generate text on Annotation [message #1843921] Tue, 24 August 2021 10:00 Go to next message
i want to generate text on a Eclass witch contains attributes, some attributes have Annotation.
Acceleo 2 template was that :
<%script type="ecore.EClass" name="scTrier"%>
<%if (eAttributes[eAnnotations[source=="fce"].details[key=="trier"]]){%>
<%for (eAttributes[eAnnotations[source=="fce"].details[key=="trier"]].sep(",")){%><%name%><%}%>
This template "scTrier" Acceleo 2 returns
att1,att2
where att1 have a Annotation 'fce 'with a key 'trier'.
and nothing if any attribute of a Eclass contains this Annotation and this key.
How can i do the same thing on acceleo 3 ?
Re: Generate text on Annotation [message #1843942 is a reply to message #1843921] Wed, 25 August 2021 05:01 Go to previous messageGo to next message
This forum is not a free coding service.
Once you have studied https://wiki.eclipse.org/Acceleo/Migration_From_Acceleo_2 feel free to post your best endeavor and n outline of what problems you face. Then we can help you.
Ed Willink
Re: Generate text on Annotation [message #1844074 is a reply to message #1843942] Tue, 31 August 2021 04:58 Go to previous messageGo to next message
Hello Pascal,
As Ed mentionned, the wiki lists a few of the rules to keep in mind when migrating an Acceleo 2 project towards Acceleo 3.
In this case though, the acceleo 2 constructs for filtering are not intuitive and have to be translated to a proper filtering, I suggest using a query for that. Something like the following should give you the result you're expecting:
[template public scTrier(class : EClass)]
[for (attribute : EAttribute | class.eAttributes->select(att : EAttribute | att.hasAnnotation())) separator (',')][name/][/for]
[/template]
[query public hasAnnotation(att : EAttribute) : EBoolean =
att.eAnnotations->select(ann : EAnnotation | ann.source = 'fce' and ann.details->select(entry : EStringToStringMapEntry | entry.key = 'trier')->size() > 0)->size() > 0
[/query]
Laurent Goubet
Obeo
Re: Generate text on Annotation [message #1844088 is a reply to message #1844074] Tue, 31 August 2021 17:31 Go to previous messageGo to next message
When i copy your code, i have this error (syntax) : model content not valid ; behind [/query]
Re: Generate text on Annotation [message #1844089 is a reply to message #1844088] Tue, 31 August 2021 17:52 Go to previous message
It works well.
Previous Topic:Share a (E)MTL file using a JAR dependency
Next Topic:Acceleo: Custom Exception handler for IO exceptions
Current Time: Wed Sep 24 12:16:42 EDT 2025
Powered by FUDForum. Page generated in 0.03120 seconds
