Home » Modeling » Epsilon » Implicit edges in Control Flow Graph(M2M transformation - Create nodes and edges from CFG)
Implicit edges in Control Flow Graph [message #1843673] Fri, 13 August 2021 05:12 Go to next message
Hi everybody,
I try to do a model-to-model conversion by means of ETL of a Control Flow Graph to an Uppaal model. I already have the meta-models for both sides, but my main challenge now is to create the edges between the nodes.
My CFG model only contains nodes where the tree hierarchy and location of the node defines the flow between the nodes. The Uppaal model however requires edges between the nodes.
Does anybody has experience with this or some pattern to (recursively) create these edges by means of ETL? Especially the recursive part is something I struggle with.
Thanks!
Regards, Jildert
Re: Implicit edges in Control Flow Graph [message #1843723 is a reply to message #1843673] Mon, 16 August 2021 02:53 Go to previous messageGo to next message
Hi Jildert,
Would adding a recursive EOL function [1] to your ETL transformation do the trick? If not, could you please share a minimal example [2] showing what you're trying to achieve?
Best,
Dimitris
[1] https://www.eclipse.org/epsilon/doc/eol/#user-defined-operations
[2] https://www.eclipse.org/epsilon/doc/articles/minimal-examples/
Re: Implicit edges in Control Flow Graph [message #1843790 is a reply to message #1843723] Wed, 18 August 2021 09:55 Go to previous message
Hi Dimitris,
I'll give that a try!
Thx
Previous Topic:[EGL/EGX + Maven]
Next Topic:Using external querying language
Current Time: Tue Nov 04 22:30:52 EST 2025
Powered by FUDForum. Page generated in 0.04640 seconds
