Home » Archived » Jubula » Headless Mode
Headless Mode [message #1842999] Fri, 09 July 2021 14:17 Go to next message
Is there an option to run Jubula tests in a headless mode from the command line? I've been looking for this because I want to include some Jubula tests as part of the automated tests on Circle CI.
If this is not possible, does anyone have experience running Jubula UI tests on Circle CI?
Re: Headless Mode [message #1843559 is a reply to message #1842999] Fri, 06 August 2021 04:51 Go to previous messageGo to next message
A complete headless mode is not possible. Jubula does work on the UI, so at least e.g. a VM with a UI is neccesarry.
If you have a complete jubula installastion you can use the tesexec[1] to run test. But where the test are running the System must have a UI.
best regards
Marvin Mueller
[1] https://help.eclipse.org/2020-06/topic/org.eclipse.jubula.client.ua.help/content/html/userManual/tasks/ch03s25.html
Re: Headless Mode [message #1843564 is a reply to message #1843559] Fri, 06 August 2021 12:54 Go to previous message
Thanks for your response, that's good to know for sure.
In case this is useful to anyone else, I was able to get Jubula tests to run on Circle CI using their Windows Executor https://circleci.com/docs/2.0/hello-world-windows/#specifying-a-shell-with-the-windows-executor
Previous Topic:Object Mapping of the existing components getting changed after an update in the UI
Next Topic:Sharing common test cases across projects.
Current Time: Sun Apr 27 10:54:42 EDT 2025
Powered by FUDForum. Page generated in 0.07468 seconds
