I write a custom `Annotation Processor`:
public class MyProcessor extends AbstractProcessor {
BaseProcessingEnvImpl env;
public synchronized void init(ProcessingEnvironment processingEnv) {
String className = processingEnv.getClass().getName();
processingEnv.getMessager().printMessage(WARNING, "class name is: " + className);
if ("org.eclipse.jdt.internal.compiler.apt.dispatch.BaseProcessingEnvImpl".equals(className) ||
"org.eclipse.jdt.internal.apt.pluggable.core.dispatch.IdeBuildProcessingEnvImpl".equals(className)){
// Trying to convert ProcessingEnvironment to BaseProcessingEnvImpl
env = (BaseProcessingEnvImpl) processingEnv;
super.init(processingEnv);
public boolean process(Set<? extends TypeElement> annotations, RoundEnvironment roundEnv) {
return false;
1. I package it to `test.jar`,
2. I add `test.jar` to <b>Eclipse project</b>.
3. I add `test.jar` to <b>Java compiler - annotation processing - factory path</b>
4. **build project**, but it throw exception:
java.lang.NoClassDefFoundError: org/eclipse/jdt/internal/compiler/apt/dispatch/BaseProcessingEnvImpl
at test.MyProcessor.init(MyProcessor.java:29)
at org.eclipse.jdt.internal.apt.pluggable.core.dispatch.IdeAnnotationProcessorManager.discoverNextProcessor(IdeAnnotationProcessorManager.java:97)
at org.eclipse.jdt.internal.compiler.apt.dispatch.RoundDispatcher.round(RoundDispatcher.java:119)
at org.eclipse.jdt.internal.compiler.apt.dispatch.BaseAnnotationProcessorManager.processAnnotations(BaseAnnotationProcessorManager.java:171)
at org.eclipse.jdt.internal.apt.pluggable.core.dispatch.IdeAnnotationProcessorManager.processAnnotations(IdeAnnotationProcessorManager.java:138)
at org.eclipse.jdt.internal.compiler.Compiler.processAnnotations(Compiler.java:950)
at org.eclipse.jdt.internal.compiler.Compiler.compile(Compiler.java:450)
at org.eclipse.jdt.internal.compiler.Compiler.compile(Compiler.java:426)
at org.eclipse.jdt.internal.core.builder.AbstractImageBuilder.compile(AbstractImageBuilder.java:377)
at org.eclipse.jdt.internal.core.builder.BatchImageBuilder.compile(BatchImageBuilder.java:214)
at org.eclipse.jdt.internal.core.builder.AbstractImageBuilder.compile(AbstractImageBuilder.java:309)
at org.eclipse.jdt.internal.core.builder.BatchImageBuilder.build(BatchImageBuilder.java:79)
at org.eclipse.jdt.internal.core.builder.JavaBuilder.buildAll(JavaBuilder.java:272)
at org.eclipse.jdt.internal.core.builder.JavaBuilder.build(JavaBuilder.java:187)
at org.eclipse.core.internal.events.BuildManager$2.run(BuildManager.java:846)
at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:45)
at org.eclipse.core.internal.events.BuildManager.basicBuild(BuildManager.java:229)
at org.eclipse.core.internal.events.BuildManager.basicBuild(BuildManager.java:277)
at org.eclipse.core.internal.events.BuildManager$1.run(BuildManager.java:330)
at org.eclipse.core.internal.events.BuildManager.basicBuild(BuildManager.java:333)
at org.eclipse.core.internal.events.BuildManager.basicBuild(BuildManager.java:292)
at org.eclipse.core.internal.events.BuildManager.build(BuildManager.java:481)
at org.eclipse.core.internal.resources.Project$1.run(Project.java:565)
at org.eclipse.core.internal.resources.Workspace.run(Workspace.java:2292)
at org.eclipse.core.internal.resources.Project.internalBuild(Project.java:603)
at org.eclipse.core.internal.resources.Project.build(Project.java:116)
at org.eclipse.jdt.internal.ui.util.CoreUtility$BuildJob.run(CoreUtility.java:157)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:63)
Caused by: java.lang.ClassNotFoundException: org.eclipse.jdt.internal.compiler.apt.dispatch.BaseProcessingEnvImpl
at java.base/java.net.URLClassLoader.findClass(URLClassLoader.java:435)
at java.base/java.lang.ClassLoader.loadClass(ClassLoader.java:589)
at java.base/java.lang.ClassLoader.loadClass(ClassLoader.java:522)
I know Eclipse use `ecj` compiler, so Why is it not loaded class `BaseProcessingEnvImpl`?
And I also try convert to `IdeBuildProcessingEnvImpl`, but get the same error.
