Indexer Fails on Change of Run/Debug Configuration. Requires Eclipse Restart [message #1842617] |
Fri, 25 June 2021 15:12 |
Brian Piccioni Messages: 3 Registered: June 2021 |
I am using Eclipse CDT 03-2021 with the ESP-IDF Plugin. The plugin does not seem compatible with 06-2021 but the described behaviour is the same. This seems to be a common problem.
Switching from run to debug configuration or vice-verse results in unresolved includes even though it will build with no errors, suggesting the indexer is not in synch with the source. Reindexing, "clean", etc., does not help. Usually a change in configuration immediately results in index issues but if it does not a re-index or build all always does.
Switching back does not fix the indexer. I.e. if you start Eclipse with the run config, switch to debug, then back to run the indexer still fails.
If debug works and I change to run, I get the same problem. I have to switch configurations because of an unfixed bug in the OpenOCD-ESP. Because of the indexer issue I have to
1) Switch to Run config to program the device
2) Close Eclipse
3) Open Eclipse and start the debug session.
This is tedious.
Below is a summary of the log files of a failing and working index
Note that the working index has an Include Search Path (option -I). I cannot find where to set the Include Search Path option for the indexer. In prior projects when I had unresolved includes (i.e. compile failures) there was an option for "Include Paths" but that is not present in the project or window properties, likely because this is a cmake project.
****Fails****
Project: SoftAP1
File: file:/C:/Users/bjpic/eclipse-windows/SoftAP1/main/softap_example_main.c
Language: GNU C
Index Version: 219.0
Build Configuration: Configuration
Context: file:/C:/Users/bjpic/eclipse-windows/SoftAP1/main/softap_example_main.c
C, {}
Versions in Index: 1
C: {}; 4 macros, 10 includes, 46 names;
Macro definitions (from language + headers in index):
****Works****
Project: SoftAP1
Language: GNU C
C, {}
C: {}; 4 macros, 10 includes, 512 names;
Include Search Path (option -I):
This is the contents of the project indexer preferences org.eclipse.cdt.core.prj-SoftAP1.prefs but I have tried numerous permutations thereof.
eclipse.preferences.version=1
indexer/indexAllFiles=false
indexer/indexAllHeaderVersions=false
indexer/indexAllVersionsSpecificHeaders=
indexer/indexOnOpen=true
indexer/indexUnusedHeadersWithAlternateLang=false
indexer/indexUnusedHeadersWithDefaultLang=false
indexer/indexerId=org.eclipse.cdt.core.fastIndexer
indexer/preferenceScope=0
indexer/skipFilesLargerThanMB=8
indexer/skipImplicitReferences=false
indexer/skipIncludedFilesLargerThanMB=16
indexer/skipMacroReferences=false
indexer/skipReferences=false
indexer/skipTypeReferences=false
indexer/useHeuristicIncludeResolution=false
FUDForum. Page generated in 0.03922 seconds
