Home » Newcomers » Newcomers » Jetty 9.4.42 installed in eclipse 2021-06 - Missing Constraints Validation error(Jetty 9.4.42 in eclipse 4.20 (2021-06) Validation Errors)
Jetty 9.4.42 installed in eclipse 2021-06 - Missing Constraints Validation error [message #1842558] Wed, 23 June 2021 16:13 Go to next message
lea ilagan is currently offline lea ilaganFriend
Member
I installed Jetty 9.4.42 in Eclipse 4.20 (2021-06) and got lots of validation errors. I verified that the missing plugins are installed but still reported as missing. Please see attached screenshot.
Example:
org.eclipse.jetty.alpn.client
Missing Constraint: Import-Package: org.eclipse.jetty.io; version= "[9.4.42,10.0.0)"
Missing Constraint: Import-Package: org.eclipse.jetty.util.log; version= "[9.4.42,10.0.0)"
Any input please.
Lea
Re: Jetty 9.4.42 installed in eclipse 2021-06 - Missing Constraints Validation error [message #1842559 is a reply to message #1842558] Wed, 23 June 2021 17:29 Go to previous messageGo to next message
Nitin Dahyabhai is currently offline Nitin DahyabhaiFriend
What do you mean you "installed Jetty 9.4.42 in Eclipse 4.20"? Eclipse 4.20 contains bundles from Jetty 10.0.5.
Nitin Dahyabhai
Eclipse Web Tools Platform
[Updated on: Wed, 23 June 2021 17:30]
Report message to a moderator
Re: Jetty 9.4.42 installed in eclipse 2021-06 - Missing Constraints Validation error [message #1842561 is a reply to message #1842559] Wed, 23 June 2021 17:45 Go to previous messageGo to next message
Member
Yes, I installed Jetty 9.4.42 in eclipse 4.20.
We're currently using version 9.4.10 (https://download.eclipse.org/jetty/updates/jetty-bundles-9.x/9.4.10.v20180503/) and now upgrading it to latest 9.4.x using eclipse 4.20.
When i use Jetty 9.4.10 in eclipse 4.20, there is no validation error (not sure why). Can't we use latest 9.4.x in eclipse 4.20?
Also, yes, I see that eclipse 4.20 is using bundles from Jetty 10.x , however I can't find p2 repository to install 10.x.
Lea
Re: Jetty 9.4.42 installed in eclipse 2021-06 - Missing Constraints Validation error [message #1842564 is a reply to message #1842561] Wed, 23 June 2021 23:31 Go to previous messageGo to next message
You might find what you need by browsing https://download.eclipse.org/eclipse/jetty/ or https://download.eclipse.org/webtools/jetty/.
Check https://www.eclipse.org/lists/cross-project-issues-dev/msg18518.html for some information to watch for p2 repositories
directly from Jetty.
Nitin Dahyabhai
Re: Jetty 9.4.42 installed in eclipse 2021-06 - Missing Constraints Validation error [message #1842698 is a reply to message #1842564] Tue, 29 June 2021 10:07 Go to previous message
Member
Thanks Nitin Dahyabhai..
I just pulled the 10.0.5 jetty bundles from maven site and create local p2 repo..
regards,
Leahttps://www.eclipse.org/forums/index.php/r/frm_id/89/
Previous Topic:still trying to get started
Next Topic:Want to run sample Hello world test on selenium grid 4
Current Time: Tue Mar 28 11:20:13 GMT 2023
Powered by FUDForum. Page generated in 0.03268 seconds
