Home » Newcomers » Newcomers » unable to uninstall Eclipse Java 2021-03 Windows(Program is still listed in search)
unable to uninstall Eclipse Java 2021-03 Windows [message #1841996] Sun, 06 June 2021 11:38 Go to next message
I needed to install Eclipse for a work project. I installed Eclipse for Java Developers through the Oomph installer on Windows 10. After the projected finished I uninstalled it by removing the Desktop shortcut the folder and files in the start menu, the .eclipse and .p2 folder and the workspaces and the application folder. But if I search for eclipse the IDE is still listed in search and has the correct icon. I deleted and rebuild the search index, ran repair on search and on windows. I also searched the whole machine for eclipse folders or anything that had to do with eclipse. To this day I can still search for eclipse and find it. My question is where do you store it, because the installer is not a normal windows installer and clearly it has to be stored somewhere because he reindexes it every time.
Thanks in advance.
Re: unable to uninstall Eclipse Java 2021-03 Windows [message #1842002 is a reply to message #1841996] Mon, 07 June 2021 01:00 Go to previous message
When you search, can't you use the Properties dialog to find out where the thing it's finding is located? Is it really finding things that don't exist? That's not very helpful is it...
Eclipse registers itself as a link handler these days and that's stored in the system registry. The installer also registers itself as a link handler in the system registry. So perhaps these leave behind things that search finds...
Previous Topic:Errors starting out
Next Topic:Highlight issues with Windows 7 and DevStyle (Darkest Dark)
Current Time: Wed Oct 29 07:20:55 EDT 2025
Powered by FUDForum. Page generated in 0.07396 seconds
