Re: IDz Version: 14.0.0.9, Build id: idz14009O-I20191015_1437 shouldn't include EGit [message #1841707 is a reply to message #1841704] |
Wed, 26 May 2021 10:06 |
Thomas Wolf Messages: 576 Registered: August 2016 |
IDz is "IBM Developer for z Systems".
Sergio, you need to open a support ticket with IBM. The open-source Eclipse IDE & EGit developers have no control over the closed-source products IBM produces based on the Eclipse IDE.
That said, it should be possible to install EGit from the usual update site; see EGit downloads.
One caveat: in my experience IBM products are typically based on Eclipse versions that are a couple of years old. If that's the case for IDz, the newest EGit may or may not install. Give it a try; if it doesn't work, you'll have to figure out what Eclipse version your IDz is based on, check which EGit version to use, and then use the appropriate older EGit version.
I can personally vouch for EGit nightly installing fine in RSA 9.7.0.2 (another IBM product, based on Eclipse Oxygen.3).
[Updated on: Wed, 26 May 2021 10:13] Report message to a moderator
FUDForum. Page generated in 0.03402 seconds
