| GUIDE ATL [message #1841680] |
Tue, 25 May 2021 11:09  |
I wrote this rule in ATL :
rule ListOfPart2MExpert {
from nomenclature : ListOfPart!CI
to ME : MExpert!MExpert(),
p :MExpert!pou (
name<-'POU_Principal',
pouType<-'program' --,
a :MExpert!localVars(),
variable:MExpert!variables(
name <-nomenclature.nature
t:MExpert!type(
REAL<- if nomenclature.type='WORD'
then
VR
else
OclUndefined
endif,
BOOL<- if nomenclature.type='STRING'
then
VB
else
OclUndefined
endif
VR :MExpert!REAL(),
VB :MExpert!BOOL(),
b :MExpert!FBD()
and I got that :
<pou name="POU_Principal" pouType="program"/>
<localVars/>
<variables name="Type"/>
<type/>
<REAL/>
<BOOL/>
<FBD/>
<MExpert/>
<localVars/>
<variables name="Unité"/>
<type/>
<REAL/>
<BOOL/>
<FBD/>
<MExpert/>
<localVars/>
<variables name="Offset"/>
<type/>
<REAL/>
<BOOL/>
<FBD/>
<MExpert/>
<localVars/>
<variables name="Date"/>
<type/>
<REAL/>
<BOOL/>
<FBD/>
<MExpert/>
<localVars/>
<variables name="Donnée_1"/>
<type/>
<REAL/>
<BOOL/>
<FBD/>
<MExpert/>
<localVars/>
<variables name="Donnée_2"/>
<type/>
<REAL/>
<BOOL/>
<FBD/>
<MExpert/>
<localVars/>
<variables name="Donnée_3"/>
<type/>
<REAL/>
<BOOL/>
<FBD/>
<MExpert/>
<localVars/>
<variables name="Donnée_4"/>
<type/>
<REAL/>
<BOOL/>
<FBD/>
<MExpert/>
<localVars/>
<variables name="Nom"/>
<type/>
<REAL/>
<BOOL/>
<FBD/>
But my objectif is to get this structure
<pou name="POU_Principal" pouType="program">
<interface>
<localVars>
<variable name="Val4_MxIn">
<type>
<REAL />
</type>
</variable>
<variable name="Val5_MiOu">
<type>
<REAL />
</type>
</variable>
<variable name="Val6_MxOu">
<type>
<REAL />
</type>
</variable>
<variable name="Val7_BOOL">
<type>
<BOOL />
</type>
</variable>
<variable name="Sortie_1_BOOL">
<type>
<BOOL />
</type>
</variable>
<variable name="Sortie_2_REAL">
<type>
<REAL />
</type>
</variable>
<variable name="Sortie_3_BOOL">
<type>
<BOOL />
</type>
</variable>
<variable name="Sortie_4_UINT">
<type>
<UINT />
</type>
</variable>
<variable name="Exemple_Temperature">
<type>
<derived name="FB_Scaling" />
</type>
</variable>
</localVars>
</interface>
as you notice, these lines <pou name="POU_Principal" pouType="program"/>
<localVars/>
<FBD/>
<MExpert/>
repeat until the end
| Re: GUIDE ATL [message #1841851 is a reply to message #1841786] |
Tue, 01 June 2021 05:21   |
I made some modification to the transformation code and to the metamodel of MExpert,
The code :
to p :MExpert!pou (
pouType<-'program' ,
interface<-a
a :MExpert!Interface(
localVars<-l
l :MExpert!localVars(
variable<-v
v :MExpert!variables(
name <-nomenclature.nature,
type<-t
t :MExpert!type(
then
VR
else
OclUndefined
endif,
then
VB
else
OclUndefined
endif
VR :MExpert!REAL(),
VB :MExpert!BOOL()
And I got this
<?xml version="1.0" encoding="ISO-8859-1"?>
<xmi:XMI xmi:version="2.0" xmlns:xmi="http://www.omg.org/XMI" xmlns="MachineExpert">
<interface>
<localVars>
<variable name="Type">
<type/>
</variable>
</localVars>
</interface>
</pou>
<REAL/>
<BOOL/>
<interface>
<localVars>
<variable name="Unité">
<type/>
</variable>
</localVars>
</interface>
</pou>
<REAL/>
<BOOL/>
<interface>
<localVars>
<variable name="Offset">
<type/>
</variable>
</localVars>
</interface>
</pou>
<REAL/>
<BOOL/>
<interface>
<localVars>
<variable name="Date">
<type/>
</variable>
</localVars>
</interface>
</pou>
<REAL/>
<BOOL/>
<interface>
<localVars>
<variable name="Donnée_1">
<type/>
</variable>
</localVars>
</interface>
</pou>
<REAL/>
<BOOL/>
<interface>
<localVars>
<variable name="Donnée_2">
<type/>
</variable>
</localVars>
</interface>
</pou>
<REAL/>
<BOOL/>
<interface>
<localVars>
<variable name="Donnée_3">
<type/>
</variable>
</localVars>
</interface>
</pou>
<REAL/>
<BOOL/>
<interface>
<localVars>
<variable name="Donnée_4">
<type/>
</variable>
</localVars>
</interface>
</pou>
<REAL/>
<BOOL/>
<interface>
<localVars>
<variable name="Nom">
<type/>
</variable>
</localVars>
</interface>
</pou>
<REAL/>
<BOOL/>
</xmi:XMI>
Attachment: Capture1.PNG
(Size: 53.31KB, Downloaded 122 times)
| Re: GUIDE ATL [message #1841909 is a reply to message #1841851] |
Wed, 02 June 2021 15:36   |
You appear to understand the principle now, where you need to assign values to the containment properties (interface, localVars, variable, ...) in order to have contained XMI elements.
However, none of the "if nomenclature.type=..." conditions in your transformation code seem to trigger, as no values are assigned to the REAL or BOOL property. You can debug this situation by inserting the "debug()" helper method into your code. Also, the VR and VB models elements are always created, whereas you likely meant to only create the value object of the applicable type instead of all of them. This can be achieved by using lazy rules.
Here's a reworked example (assumes you use EMFTVM):
to p :MExpert!pou (
interface<-a
localVars<-l
variable<-v
type<-t
t :MExpert!type(
REAL<- thisModule.RealValue(nomenclature),
BOOL<- thisModule.BoolValue(nomenclature)
lazy rule RealValue {
from nomenclature : ListOfPart!CI (
nomenclature.type.debug('RealValue')='WORD')
to VR :MExpert!REAL
lazy rule BoolValue {
nomenclature.type.debug('RealValue')='STRING')
to VR :MExpert!BOOL
| Re: GUIDE ATL [message #1841915 is a reply to message #1841909] |
Thu, 03 June 2021 03:13   |
This code allows me to have this structure:
<interface>
<localVars>
<type>
<REAL/>
<BOOL/>
</type>
</variable>
</localVars>
</interface>
</pou>
<interface>
<localVars>
<type>
<REAL/>
<BOOL/>
</type>
</variable>
</localVars>
</interface>
</pou>
<interface>
<localVars>
<type>
<REAL/>
<BOOL/>
</type>
</variable>
</localVars>
</interface>
</pou>
<interface>
<localVars>
<type>
<REAL/>
<BOOL/>
</type>
</variable>
</localVars>
</interface>
</pou>
<interface>
<localVars>
<type>
<REAL/>
<BOOL/>
</type>
</variable>
</localVars>
</interface>
</pou>
<interface>
<localVars>
<type>
<REAL/>
<BOOL/>
</type>
</variable>
</localVars>
</interface>
</pou>
<interface>
<localVars>
<type>
<REAL/>
<BOOL/>
</type>
</variable>
</localVars>
</interface>
</pou>
<interface>
<localVars>
<type>
<REAL/>
<BOOL/>
</type>
</variable>
</localVars>
</interface>
</pou>
<interface>
<localVars>
<type>
<REAL/>
<BOOL/>
</type>
</variable>
</localVars>
</interface>
</pou>
</xmi:XMI>
and it's not quite the structure I'm looking for. I still tried to improve my code:
from nomenclature : ListOfPart!Instance
to p :MExpert!pou (
interface<-a
localVars<-l
l : MExpert!localVars (
variable<-v
v : distinct MExpert!variables foreach(e in nomenclature.ci)(
name <- e.nature,
type <- t
t: distinct MExpert!type foreach(e in nomenclature.ci)(
REAL<- VR,
BOOL<- VB
VR :distinct MExpert!REAL foreach(e in nomenclature.ci)(
REAL<- if e.type='WORD'
then
VR
else
OclUndefined
endif
VB :distinct MExpert!BOOL foreach(e in nomenclature.ci)(
BOOL<- if e.type='STRING'
then
VB
else
OclUndefined
endif
and I get this structure:
<pou xmi:version="2.0" xmlns:xmi="http://www.omg.org/XMI" xmlns="MachineExpert" name="POU_Principal" pouType="program">
<interface>
<localVars>
<type>
<REAL/>
<BOOL/>
</type>
</variable>
<type>
<REAL/>
<BOOL/>
</type>
</variable>
<type>
<REAL/>
<BOOL/>
</type>
</variable>
<type>
<REAL/>
<BOOL/>
</type>
</variable>
<type>
<REAL/>
<BOOL/>
</type>
</variable>
<type>
<REAL/>
<BOOL/>
</type>
</variable>
<type>
<REAL/>
<BOOL/>
</type>
</variable>
<type>
<REAL/>
<BOOL/>
</type>
</variable>
<type>
<REAL/>
<BOOL/>
</type>
</variable>
</localVars>
</interface>
</pou>
It only remains to succeed in distinguishing between a "STRING" and a "WORD"
| Re: GUIDE ATL [message #1841922 is a reply to message #1841909] |
Thu, 03 June 2021 10:15   |
I finally managed to put it on the right structure and now it makes the difference between a BOOL and a REAL. Except that it adds me tags at the end of the program but that will not affecte my progress in the project. If you have any ideas how to remove them that will be nice ...
The problem was that I had to write #STRING instead of 'STRING'
rule Variables2MExpert {
to
p :MExpert!pou (
interface<-a
localVars<-l
variable<-v
name <- e.nature,
type <- t
t :distinct MExpert!type foreach(e in nomenclature.ci)(
BOOL<-if (e.type=#STRING)
then
VB
else
OclUndefined
endif,
REAL<-if (e.type=#WORD)
then
VR
else
OclUndefined
endif
VB :distinct MExpert!BOOL foreach(e in nomenclature.ci),
and this is the result
<interface>
<localVars>
<type>
<BOOL/>
</type>
</variable>
<type>
<BOOL/>
</type>
</variable>
<type>
<REAL/>
</type>
</variable>
<type>
<BOOL/>
</type>
</variable>
<type>
<REAL/>
</type>
</variable>
<type>
<REAL/>
</type>
</variable>
<type>
<REAL/>
</type>
</variable>
<type>
<REAL/>
</type>
</variable>
<type>
<BOOL/>
</type>
</variable>
</localVars>
</interface>
</pou>
<BOOL/>
<BOOL/>
<BOOL/>
<BOOL/>
<BOOL/>
<REAL/>
<REAL/>
<REAL/>
<REAL/>
</xmi:XMI>
FUDForum. Page generated in 0.05929 seconds
