Home » Eclipse Projects » BPMN 2.0 Modeler » How to pick an Icon in a CustomTask(Questions about how to specify custom Elements as an Extension of the BPMN2 Modeler)
How to pick an Icon in a CustomTask [message #1841091] Mon, 03 May 2021 12:26 Go to next message
I want to extend the BPMN2 Modeler with uBPMN.
I started with the BPMN2-Modeler/DeveloperTutorials (Extending the BPMN2 Runtime, Extending the Model, Creating a Custom Task, Creating a Custom Shape) but in the last tutorial Creating a Custom Shape the Code Examples arent complete. So I looked it up in the GitHub repository https://github.com/rsoika/bpmn2-tutorial. But even with this code I couldn't manage to select a custom Icon for my Custom Tasks.
In the Extension Element Details tab is an icon field but selecting a .png isn't possible. If I try so it just appears a red box at the position where the Icon should be.
index.php/fa/40456/0/
Therefore what do I have to do to select icons in this field, or is there an easier way to select icons for custom tasks?
Iam running the latest Eclipse and BPMN2 Modeler Version.
Thanks in advance.
Re: How to pick an Icon in a CustomTask [message #1841100 is a reply to message #1841091] Mon, 03 May 2021 17:15 Go to previous messageGo to next message
If you want to define an 'Extension Element Icon', than you have to define the sub directories /icons/huge/ , /icons/large/ , and /icons/small/ and you need to place the icon in all 3 folders
The 'icon' property just takes the name of the icon file not the path.
index.php/fa/40458/0/
This is important, because the icon is used for different situations. For example the icon is also shown in the tool palette. For that reason the BPMNPlugin need 3 versions of the icon.
index.php/fa/40459/0/
[Updated on: Mon, 03 May 2021 17:19] by Moderator
Re: How to pick an Icon in a CustomTask [message #1841961 is a reply to message #1841100] Fri, 04 June 2021 09:09 Go to previous messageGo to next message
Thank you for the Help last time, it worked perfecly.
But now I have encountered a different problem, that i couldn't fix myself. After saving a BPMN Model with my Custom Elements and restarting Eclipse, the icons are no longer displayed in the Model.
Do anyone knows this Problem and can offer a solution?
Thanks in advance!
Re: How to pick an Icon in a CustomTask [message #1843617 is a reply to message #1841961] Tue, 10 August 2021 17:42 Go to previous message
Sorry for the late reply. Did you yet solved it?
Often this happened because of a wrong packaging in your eclipse plugin during development (with changing image names). Also try to cleanup your test workspace when you start the plugin from your Eclipse IDE for testing.
Previous Topic:Code snippet for export diagram feature
Next Topic:Migrating Eclipse BPMN2 Modeler to web
Current Time: Sun Oct 26 04:07:29 EDT 2025
Powered by FUDForum. Page generated in 0.04030 seconds
