Home » Modeling » EMF » Ecore EDouble toString returns "Set{1.0}" instead of "1.0"
Ecore EDouble toString returns "Set{1.0}" instead of "1.0" [message #1841072] Mon, 03 May 2021 02:35 Go to next message
I have the following situation:
I want to model an inheritance hierachy for some action types in the OCLinEcore editor whereby each class should should override a "getLabel" operation. This operation should then return a string representation of its value:
Base type:
abstract class Action
operation getLabel() : String[?];
A concrete type:
class DoubleAction extends Action
body: self.value->toString();
attribute type : DoubleActionType[1];
attribute value : ecore::EDouble;
I want to design my own graphical modelling in the odesign file and this operation is then invoked here (in an expression field). For the value->toString() I expected "1.0" for a value of 1.0. However, I always get "Set{1.0}" as a result.
Does someone know how to correctly convert this into the expected form? I also would like to convert then the enum type to string (finally I want a result like "<type> = <value>")
Re: Ecore EDouble toString returns "Set{1.0}" instead of "1.0" [message #1841096 is a reply to message #1841072] Mon, 03 May 2021 15:07 Go to previous messageGo to next message
Your problem seems to be this OCL expression
You are using the arrow (->) operator, this automatically casts your attribute value to a singleton set.
try instead
self.value.toString();
Re: Ecore EDouble toString returns "Set{1.0}" instead of "1.0" [message #1841106 is a reply to message #1841096] Tue, 04 May 2021 00:41 Go to previous message
You should find that https://git.eclipse.org/r/plugins/gitiles/ocl/org.eclipse.ocl/+/refs/heads/master/examples/org.eclipse.ocl.examples.build/model/UML2EcoreControl.ecore shows you how to use hierarchical model names. Or use oclType() to use meta=names.
Ed Willink
Previous Topic:[CDO] NPE in SecurityManager$PermissionManager which leads to TimeoutRuntimeException on next commit
Next Topic:ChangeRecorder cannot be found by org.eclipse.emf.edit
Current Time: Wed Nov 05 00:52:57 EST 2025
Powered by FUDForum. Page generated in 0.04044 seconds
