Re: Executing EASE scripts from CLI using Eclipse [message #1840978 is a reply to message #1840854] |
Thu, 29 April 2021 18:09 |
Christian Pontesegger Messages: 250 Registered: July 2009 Location: Graz, Austria |
eclipsec.exe -application org.eclipse.ease.runScript -workspace "C:\my workspace location" -script "workspace://Example Project/src/script1.js" param1 param2
... taken from Help/Scripting User Guide/Tasks/Launching Scripts/Headless
Details on the parameters can be found there.
PyDev is an IDE extension for python programming. The only thing EASE is using from PyDev is the breakpoint support. There is no other connection between these 2 projects. Still you can use PyDev to write your scripts and then EASE to run them within the JVM context.
HTH
Christian
PS: do not use the -refreshWorkspace parameter. Just found an issue with that and need to fix it in the nightly builds.
[Updated on: Thu, 29 April 2021 18:11] Report message to a moderator
FUDForum. Page generated in 0.03755 seconds
