cannot create projects "No project types available" [message #1840285] |
Sun, 11 April 2021 14:09 |
heinrich seebauer Messages: 5 Registered: April 2021 |
Hi, there.
Because of a more and more degrading installation, and updating made it even worse, I installed the last release 2021-03. To get rid of all the issues, I created a new workspace and deleted ~/.eclipse beforehand. I even installed on a new user's home, to no avail.
I'm not sure what information to provide, having no clue where the problem is located.
Any help in getting CDT functional is greatly appreciated.
OS is Linux, kernel 5.3.18-lp152.69-default, distro is openSuse 15.2, KDE Frameworks 5.71.0
Qt 5.12.7, Java openjdk 11.0.10 2021-01-19.
This is what I did so far:
- downloaded eclipse 2021-03 installer, unpacked it.
- started installer, Installing eclipse (C/C++ development) 2021-03 throws GTK warnings, as does staring installed eclipse.
~/eclipse/cpp-2021-03/eclipse$./eclipse-inst
(eclipse-inst:18281): Gtk-WARNING **: 14:42:00.997: Theme parsing error: widgets.css:146:17: expected ':'
(eclipse-inst:18281): Gtk-WARNING **: 14:42:00.998: Theme parsing error: widgets.css:295:11: Invalid name of pseudo-class
(eclipse-inst:18281): Gtk-WARNING **: 14:42:00.998: Theme parsing error: widgets.css:317:23: The :focused pseudo-class is deprecated. Use :focus instead.
(java:18305): Gtk-WARNING **: 14:42:01.195: Theme parsing error: widgets.css:146:17: expected ':'
(java:18305): Gtk-WARNING **: 14:42:01.195: Theme parsing error: widgets.css:295:11: Invalid name of pseudo-class
(java:18305): Gtk-WARNING **: 14:42:01.195: Theme parsing error: widgets.css:317:23: The :focused pseudo-class is deprecated. Use :focus instead.
(WebKitWebProcess:18424): Gtk-WARNING **: 14:42:03.601: Theme parsing error: widgets.css:146:17: expected ':'
(WebKitWebProcess:18424): Gtk-WARNING **: 14:42:03.601: Theme parsing error: widgets.css:295:11: Invalid name of pseudo-class
(WebKitWebProcess:18424): Gtk-WARNING **: 14:42:03.601: Theme parsing error: widgets.css:317:23: The :focused pseudo-class is deprecated. Use :focus instead.
(WebKitWebProcess:18424): Gtk-WARNING **: 14:42:03.681: Theme parsing error: widgets.css:146:17: expected ':'
(WebKitWebProcess:18424): Gtk-WARNING **: 14:42:03.681: Theme parsing error: widgets.css:295:11: Invalid name of pseudo-class
(WebKitWebProcess:18424): Gtk-WARNING **: 14:42:03.681: Theme parsing error: widgets.css:317:23: The :focused pseudo-class is deprecated. Use :focus instead.
(WebKitWebProcess:18516): Gtk-WARNING **: 14:42:07.367: Theme parsing error: widgets.css:146:17: expected ':'
(WebKitWebProcess:18516): Gtk-WARNING **: 14:42:07.367: Theme parsing error: widgets.css:295:11: Invalid name of pseudo-class
(WebKitWebProcess:18516): Gtk-WARNING **: 14:42:07.367: Theme parsing error: widgets.css:317:23: The :focused pseudo-class is deprecated. Use :focus instead.
(WebKitWebProcess:18516): Gtk-WARNING **: 14:42:07.452: Theme parsing error: widgets.css:146:17: expected ':'
(WebKitWebProcess:18516): Gtk-WARNING **: 14:42:07.452: Theme parsing error: widgets.css:295:11: Invalid name of pseudo-class
(WebKitWebProcess:18516): Gtk-WARNING **: 14:42:07.452: Theme parsing error: widgets.css:317:23: The :focused pseudo-class is deprecated. Use :focus instead.
(WebKitWebProcess:18630): Gtk-WARNING **: 14:42:34.159: Theme parsing error: widgets.css:146:17: expected ':'
(WebKitWebProcess:18630): Gtk-WARNING **: 14:42:34.160: Theme parsing error: widgets.css:295:11: Invalid name of pseudo-class
(WebKitWebProcess:18630): Gtk-WARNING **: 14:42:34.160: Theme parsing error: widgets.css:317:23: The :focused pseudo-class is deprecated. Use :focus instead.
(WebKitWebProcess:18630): Gtk-WARNING **: 14:42:34.195: Theme parsing error: widgets.css:146:17: expected ':'
(WebKitWebProcess:18630): Gtk-WARNING **: 14:42:34.196: Theme parsing error: widgets.css:295:11: Invalid name of pseudo-class
(WebKitWebProcess:18630): Gtk-WARNING **: 14:42:34.196: Theme parsing error: widgets.css:317:23: The :focused pseudo-class is deprecated. Use :focus instead.
- then started eclipse from installer with new eclipse-workpace, eclipse shows welcome screen
- clicked on "Create a new C/C++ project, shows C Managed Build, C++ Managed Build, selected C
- clicked "Next>" button
- C Project dialog opens: "Project name must be specified"
- enter "p1" for a program name
- Error message displays: "No project types available", so I can't create any project.
Same results when starting eclipse after installation.
I even tried to install with a complete new user on my machine, with the same results.
Besides, I observed problems with eclipse ui in general, especially with view menus not displayed at all, but can't tell if this relates to this issue.
Can't even tell if this is GTK related.
For now I'm running out of search terms for Mr. G. Searching for "No project types available" has been found several times but that didn't cover or solve the issue.
What am I doing wrong? Any help is GREATLY appreciated.
Kind regards
Heinrich
[Updated on: Thu, 15 April 2021 18:03] Report message to a moderator
FUDForum. Page generated in 0.04120 seconds
