| Error java.sql.SQLException: No suitable driver found for jdbc:mysql:XXXXXXXXXXXX [message #1839856] |
Tue, 30 March 2021 06:36  |
I have the following error after upgrading to scout 11 on prod.
org.eclipse.scout.rt.platform.exception.BeanCreationException: Exception while invoking @PostConstruct method public void com.scout.app.server.db.sql.DatabaseSetupService.autoCreateDatabase() throws java.sql.SQLException
at org.eclipse.scout.rt.platform.internal.BeanInstanceUtil.translateException(BeanInstanceUtil.java:171)
at org.eclipse.scout.rt.platform.internal.BeanInstanceUtil.initializeBeanInstance(BeanInstanceUtil.java:106)
at org.eclipse.scout.rt.platform.internal.BeanInstanceUtil.initializeBeanInstance(BeanInstanceUtil.java:77)
at org.eclipse.scout.rt.platform.internal.SingeltonBeanInstanceProducer.createInstance(SingeltonBeanInstanceProducer.java:236)
at org.eclipse.scout.rt.platform.internal.SingeltonBeanInstanceProducer.getOrCreateInstance(SingeltonBeanInstanceProducer.java:112)
at org.eclipse.scout.rt.platform.internal.SingeltonBeanInstanceProducer.lambda$0(SingeltonBeanInstanceProducer.java:95)
at org.eclipse.scout.rt.platform.internal.BeanInstanceUtil.createAndAssertNoCircularDependency(BeanInstanceUtil.java:149)
at org.eclipse.scout.rt.platform.internal.SingeltonBeanInstanceProducer.produce(SingeltonBeanInstanceProducer.java:95)
at org.eclipse.scout.rt.platform.internal.BeanImplementor.getInstance(BeanImplementor.java:98)
at org.eclipse.scout.rt.platform.internal.BeanManagerImplementor.startCreateImmediatelyBeans(BeanManagerImplementor.java:338)
at org.eclipse.scout.rt.platform.internal.PlatformImplementor.startCreateImmediatelyBeans(PlatformImplementor.java:242)
at org.eclipse.scout.rt.platform.internal.PlatformImplementor.start(PlatformImplementor.java:141)
at org.eclipse.scout.rt.platform.internal.PlatformStarter.run(PlatformStarter.java:30)
Caused by: java.sql.SQLException: No suitable driver found for jdbc:mysql:XXXXXXXXXXXX
at java.sql/java.sql.DriverManager.getConnection(DriverManager.java:702)
at java.sql/java.sql.DriverManager.getConnection(DriverManager.java:251)
at com.scout.app.server.db.sql.DatabaseSetupService.autoCreateDatabase(DatabaseSetupService.java:66)
at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
at java.base/jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.base/java.lang.reflect.Method.invoke(Method.java:566)
at org.eclipse.scout.rt.platform.internal.BeanInstanceUtil.initializeBeanInstance(BeanInstanceUtil.java:103)
... 11 common frames omitted
This is not happening on dev environment, only when deploying to tomcat.
Database for dev is same used with tomcat and they are on same machine.
Does anyone have any idea how to solve this issue.
Kind Regards
FUDForum. Page generated in 0.03043 seconds
