Home » Modeling » TMF (Xtext) » Customize Scoping for inheritance
Customize Scoping for inheritance [message #1839773] Sun, 28 March 2021 07:53 Go to next message
Hi all,
I have the following grammar in Xtext where Countries extend Countries. By that I want to support inheritance. The following is my grammar and afterwards I will be showing some examples of what I want to achieve.
grammar org.xtext.example.forest.Forest with org.eclipse.xtext.common.Terminals
generate forest "http://www.xtext.org/example/forest/Forest"
Country:
	"country" name=ID ("extends" supercountry=[Country|QualifiedName])?
	forests=Forest
Forest:
	name=ID
	("tree" trees+=Tree ("," trees+=Tree)*)*
	("house" houses+=House ("," houses+=House)*)*
	("remove" remove=[Tree|QualifiedName])?
	("remove" remove=[House|QualifiedName])?
Tree:
	name=ID
House:
	name=ID
QualifiedName:
 ID ('.' ID)*
The example is as follows:
file1.dsl
country C1 {
   forest {
      tree T1, T2;
     house H1, H2;
file2.dsl
country C2 extends C1 {
   forest  {
      remove T1;
     remove H2;
I want to customize the Scope Provider so that when I say country C2 extends C1, I will get suggestions only from C1 (because if I were to work with the Default Scope Provider and I would have a third file with Country C3, I would get suggestions from there too which I do not want).
I also tried the approach of using imports, but that doesn't work well for me either. I have been trying to find examples on how to customize this scope provider to achieve what I want but I have not been able to.
Your help is highly appreciated.
Thanks!
Re: Customize Scoping for inheritance [message #1839774 is a reply to message #1839773] Sun, 28 March 2021 08:25 Go to previous messageGo to next message
what is unclear to me in all your questions. what is the problem with simply implement scoping
- from the context object search the Country (EcoreUtil.getContainerOfType might help)
- from the country recursively collect and decollect all Tree and Houses
- put the result of Trees and Houses to a Scope (Scope.scopesFor util will help here)
as you dont post any snippet of scope provider it is hard to find out where your problem is.
Re: Customize Scoping for inheritance [message #1839779 is a reply to message #1839774] Sun, 28 March 2021 10:42 Go to previous messageGo to next message
Hi Christian,
Thank you for your reply!
Up until now, from an example I found online I have only been able to implement this.
public IScope getScope(EObject context, EReference reference) {
    if (context instanceof Country
            && reference == ForestPackage.Literals.COUNTRY__SUPER_COUNTRY) {
        EObject rootCountry = EcoreUtil2.getRootContainer(context);
        List<Element> candidates = EcoreUtil2.getAllContentsOfType(rootCountry, Country.class);
        return Scopes.scopeFor(candidates);
    return super.getScope(context, reference);
But I am not really sure how accurate this is and how to implement the rest (collect and decollect trees and houses).
Haven't been able to find an example on how to really code this.
Thank you!
Re: Customize Scoping for inheritance [message #1839782 is a reply to message #1839779] Sun, 28 March 2021 13:16 Go to previous messageGo to next message
still dont see the problem
reference == ForestPackage.Literals.FOREST__REMOVE
country.getForests().getTrees()
country.getForests().getHouses()
same for superCountry if not null.
Re: Customize Scoping for inheritance [message #1839783 is a reply to message #1839782] Sun, 28 March 2021 14:31 Go to previous messageGo to next message
When I try to write this example:
Country C2 extend C1
I get: Could not resolve reference to Country C1.
Or is it that I do not need this implementation of the scope provider at all?
public class ForestScopeProvider extends AbstractForestScopeProvider {
	            && reference == ForestPackage.Literals.COUNTRY__SUPERCOUNTRY) {
	        List<Country> candidates = EcoreUtil2.getAllContentsOfType(rootCountry, Country.class);
Thanks for your help!
Re: Customize Scoping for inheritance [message #1839784 is a reply to message #1839783] Sun, 28 March 2021 15:11 Go to previous messageGo to next message
do you want to scope supercountry?
Why don't you use default scoping for that
You code allows countries from the same file only
If that what you intend?
Re: Customize Scoping for inheritance [message #1839792 is a reply to message #1839784] Mon, 29 March 2021 04:27 Go to previous messageGo to next message
For the Country, the perfect option would be to be able to choose from all projects, but if that is not possible at least choose between the countries that are defined in files that are part of the same project, not just in one file. So the base Country and inherited Country are part of two different files.
As I said I do not have much experience with this so it is a bit hard for me to implement it but i tried the following, and I still get errors:
	            && reference == ForestPackage.Literals.FOREST__REMOVE) {
	        Country.getForests().getTrees();
	        Country.getForests().getHouses();
Cannot make a static reference to the non-static method getForests() from the type
Country
- Cannot make a static reference to the non-static method getForests() from the type
Country
Re: Customize Scoping for inheritance [message #1839793 is a reply to message #1839792] Mon, 29 March 2021 04:47 Go to previous messageGo to next message
why Country.getForests().getTrees();
and not
Country coutry = (Country) context;
country.getForests().getTrees();
Re: Customize Scoping for inheritance [message #1839795 is a reply to message #1839793] Mon, 29 March 2021 05:32 Go to previous messageGo to next message
I tried this out:
	        Country country=(Country) context;
	        country.getForests().getHouses();
But when I use the keyword remove, I still get suggestions from all the Countries specified in xtext files in the same project, while I want to get suggestions only from the Country from which I am inheriting.
Re: Customize Scoping for inheritance [message #1839801 is a reply to message #1839795] Mon, 29 March 2021 06:07 Go to previous messageGo to next message
still dont understand
are you talking about countries or about trees and houses.
why do you show scoping snippet for remove/houses/trees
but complain about countries.
Re: Customize Scoping for inheritance [message #1839810 is a reply to message #1839801] Mon, 29 March 2021 06:55 Go to previous messageGo to next message
Okay, so I might have misdirected you, but this is what I want to do with an example.Note that these are three different files in one project.
file1.dsl
country C1 { forest F1
	tree T1, T2
	house H1, H2
file2.dsl
country C2 { forest F2
	tree T3, T4
	house H3, H4
file3.dsl
country C3 inherits C2 { forest F3
	tree T5, T6
	house H5, H6
       remove T3 //here I should only get suggestions for T5, T6 which are part of C3, and T3,T4 which are inherited from C2. However, with the scope provider snippet that I have, I still get suggestions even for T1, and T2 which are part of C1 and I dont want that.
I understand that the code snippet I already have might be wrong, but I would very much appreciate your help as I really need it for a project.
Many thanks!
Re: Customize Scoping for inheritance [message #1839816 is a reply to message #1839810] Mon, 29 March 2021 08:30 Go to previous messageGo to next message
yes but where is your proper impl of the scope provider?
is not the impl you use for sure.
you should collect the valid trees and houses there
Re: Customize Scoping for inheritance [message #1839819 is a reply to message #1839816] Mon, 29 March 2021 08:46 Go to previous messageGo to next message
this one works fine for me
public class MyDslScopeProvider extends AbstractMyDslScopeProvider {
	    if (reference == MyDslPackage.Literals.FOREST__REMOVE) {
	        Country rootCountry = (Country) EcoreUtil2.getRootContainer(context);
	        List<EObject> treesAndHouses = new ArrayList<>();
	        while (rootCountry != null) {
	        	treesAndHouses.addAll(rootCountry.getForests().getTrees());
	        	treesAndHouses.addAll(rootCountry.getForests().getHouses());
	        	rootCountry = rootCountry.getSupercountry();
	       System.out.println(treesAndHouses);
	        return Scopes.scopeFor(treesAndHouses);
Re: Customize Scoping for inheritance [message #1839822 is a reply to message #1839819] Mon, 29 March 2021 10:14 Go to previous messageGo to next message
That works wonders. Thank you very much.
I will now try to adapt this to my grammar as it is much more complicated, but I just needed a starting point on how this works.
Thanks again!
Re: Customize Scoping for inheritance [message #1839861 is a reply to message #1839819] Tue, 30 March 2021 09:52 Go to previous messageGo to next message
Hi Christian,
I am currently working on customizing the scope provider for my grammar, and it works for most of it. However, I have issues in a specific case.
So being that Xtexts' default scope provider allows you to reference elements from all the files that are part of the same project by using the qualified name, I want to restrict that. I removed the qualified name but with the following grammar and the following scope provider I am not able to refer to trees specified in country which I am extending.
This is the grammar:
Country:
	forests=Forest
Forest:
	"forest" name=ID
	("workingArea" position+=Position)*
Tree:
	name=ID
Position:
	name=ID "from" from=[Tree] "to" from=[Tree]
House:
	name=ID
QualifiedName:
 ID ('.' ID)*
These are the examples:
file1.forest
	tree T1, T2
file2.forest
	forest F2
	tree T7
	workingArea area from T7 to T7 //here I also want to be able to refer to T1, and T2, but I can't.
This is a snippet of my scope provider. The second part else if, is what I am trying to implement to make this possible, but I can't seem to get it right.
	    if (reference == ForestPackage.Literals.FOREST__REMOVE) {
	    else if (reference == ForestPackage.Literals.FOREST__POSITION) {
	        List<EObject> position = new ArrayList<>();
	        	position.addAll(rootCountry.getForests().getPosition());
	       System.out.println(position);
	        return Scopes.scopeFor(position);
Thank you!
Re: Customize Scoping for inheritance [message #1839862 is a reply to message #1839861] Tue, 30 March 2021 09:59 Go to previous messageGo to next message
Position:
looks bogus. should be
Position:
name=ID "from" from=[Tree] "to" to=[Tree]
+ scoping for Position__from and Position__to (and not FOREST__POSITION)
Re: Customize Scoping for inheritance [message #1839947 is a reply to message #1839862] Thu, 01 April 2021 13:24 Go to previous messageGo to next message
Hi Christian,
I am trying to access a specific element from my grammar and I have been trying for a while but no luck.
Country:
	forests=Forest
Forest:
	"forest" name=ID "{"
	"subforest" subforest+=Subforest
Tree:
	name=ID
Position:
	name=ID "from" from=[Enter] "to" to=[Exit]
House:
	name=ID
Subforest:
	name=ID
	"enter" enter+=Enter
	"exit" exit+=Exit
Enter:
	name=ID
Exit:
	name=ID
QualifiedName:
 ID ('.' ID)*
And this is my scope provider:
	   if (reference == ForestPackage.Literals.POSITION__FROM) {
	        	position.addAll(rootCountry.getForests(). getSubforest());
I want to be able to access Enter and Exit so the position will be from enter to exit. Both enter and exit are contained by a subforest, but when I write this line in my scope provider:
I cannot go further than getSubforest() , while I have the idea that in order to access enter and exit I should be able to write
position.addAll(rootCountry.getForests(). getSubforest().getEnter());
position.addAll(rootCountry.getForests(). getSubforest().getExit);
Re: Customize Scoping for inheritance [message #1839954 is a reply to message #1839947] Fri, 02 April 2021 00:40 Go to previous messageGo to next message
getSubforest Returns a list so you may loop over it
Re: Customize Scoping for inheritance [message #1839964 is a reply to message #1839954] Fri, 02 April 2021 06:35 Go to previous messageGo to next message
Would it be something like this?
	        	return position.addAll(rootCountry.getForests().getSubforest());
Re: Customize Scoping for inheritance [message #1839968 is a reply to message #1839964] Fri, 02 April 2021 08:01 Go to previous messageGo to next message
for (Subforest sf :rootCountry.getForests().getSubforest()){
//ask sf for enters and exits
Re: Customize Scoping for inheritance [message #1839969 is a reply to message #1839968] Fri, 02 April 2021 08:21 Go to previous messageGo to next message
With the following implementation of the scope provider I cannot seem to get a suggestion for FROM:
	        		sf.getEnter();
Re: Customize Scoping for inheritance [message #1839970 is a reply to message #1839969] Fri, 02 April 2021 08:25 Go to previous messageGo to next message
You nowhere add the forms to the scope list
Re: Customize Scoping for inheritance [message #1839972 is a reply to message #1839970] Fri, 02 April 2021 08:40 Go to previous messageGo to next message
I tried to add this line to the grammar
 position.add(sf);
But I get sf cannot be resolved to a variable
	        		sf.getEnter();
	        	position.add(sf);
Re: Customize Scoping for inheritance [message #1839974 is a reply to message #1839972] Fri, 02 April 2021 08:43 Go to previous messageGo to next message
sf.getEnter()
Maybe this should be
position.add(sf.getEnter())
[Updated on: Fri, 02 April 2021 08:45] by Moderator
Re: Customize Scoping for inheritance [message #1839976 is a reply to message #1839974] Fri, 02 April 2021 10:44 Go to previous messageGo to next message
It works for this case, but for a more complex case like the following it doesnt:
Country:
	forests=Forest
Forest:
	("park" parks+=Park ("," parks+=Park)*)*
	"workingarea"  workingarea=WorkingArea
Park:
     name=ID ("{"
	"exit" exit+=Exit
WorkingArea:
	name=ID "from" from=[ParkEnter] "to" to=[ParkExit]
Enter:
	Name=ID
Exit:
	Name=ID
ParkEnter:
	Park | Enter
ParkExit:
	Park | Exit
QualifiedName:
 ID ('.' ID)*
And this is the scope provider:
	   if (reference == ForestPackage.Literals.WORKING_AREA__FROM) {
	        List<EObject> workingarea = new ArrayList<>();
	        	for (Park park :rootCountry.getForests().getParks()){
	        		workingarea.addAll(park.getEnter());
	        	workingarea.addAll(rootCountry.getForests().getParks());
	       System.out.println(workingarea);
	        return Scopes.scopeFor(workingarea);
	   else if (reference == ForestPackage.Literals.WORKING_AREA__TO) {
	        List<EObject> workingareato = new ArrayList<>();
	        		workingareato.addAll(park.getExit());
	        	workingareato.addAll(rootCountry.getForests().getParks());
	       System.out.println(workingareato);
	        return Scopes.scopeFor(workingareato);
However, if I try to write this example I cannot. I have put some comments in the grammar to show what is wrong.
country C1 {
	forest F1 {
		park P1 {
			enter Enter1
			exit Exit1
			park P2
			workingarea W1 from P1 to P1  \\here I want to be able to say from  and to P1, Enter1,Exit1, P2 , but I am only allowed to say P1
        park P3 {
        	enter Enter2
        	exit Exit2
        	park P4
        	workingarea W2 from P1 to P3 \\here I want to be able to say from  and to P1, Enter1,Exit1, P2 ,P3,Enter2,Exit2 and P4 but I am only allowed to say P1 and P3.
Many thanks!
Re: Customize Scoping for inheritance [message #1839977 is a reply to message #1839976] Fri, 02 April 2021 11:21 Go to previous messageGo to next message
i recommend you to debug your code.
make sure you collect the objects you want.
if you want Exit1 you should collect it.
besides that your example grammar has warnings and the example model does not parse.
so i cannot look into it
Re: Customize Scoping for inheritance [message #1839980 is a reply to message #1839977] Fri, 02 April 2021 12:15 Go to previous messageGo to next message
p.s.
in your sample you have
Enter:
Name=ID
and not
Enter:
name=ID
did you adapt IQualifiedNameProvider then?
https://dietrich-it.de/xtext/2011/07/16/iqualifiednameproviders-in-xtext-2.0/
and pass it to the scopeFor method?
of course renaming Name to name would help
also and be much much simpler
[Updated on: Fri, 02 April 2021 12:26] by Moderator
Re: Customize Scoping for inheritance [message #1839984 is a reply to message #1839980] Fri, 02 April 2021 16:50 Go to previous messageGo to next message
Ok, the grammar should work fine now. I changed Enter: name=ID but I cannot change Exit too because I get :
There cannot be two features named "name".
Country:
	"country" name=ID ("extends" supercountry=[Country|QualifiedName])? "{"
	forests=Forest
Forest:
	("workingarea"  workingarea=WorkingArea)*
Park:
     name=ID ("{"
	"exit" exit+=Exit
WorkingArea:
Enter:
	name=ID
Exit:
	Name=ID
ParkEnter:
	Park | Enter
ParkExit:
	Park | Exit
QualifiedName:
 ID ('.' ID)*
This is the example and there are comments there to explain what I need:
country C1 {
	forest F1 {
		park P1 {
			enter EN1
			exit EX1
			park P2 {
				enter EN2
				exit EX2
				park P3
				park P4 {
					enter EN3
					exit EX3
					park P5
					workingarea W4 from EN1 to P2 //need to have from: P5, P4.EN3 to: P5,P4.EX3 because P4 only contains P4.EN3,P4.EX3 and P5
			 workingarea W2 from EN1 to P2 //need to have from: P2.EN2, P3, P4, P4.EN3  to: P2.EX2, P3, P4,P4.EX3 because P2 contains P2.EN2, P2.EX2, P3, P4, P4.EN3 and P4.EX3. Contrary to others, here we have two parks contained in one park therefore we also allow P3 and P4, not only P4.EN3 and P4.EX3
         workingarea W1 from EN1 to P2 //need to have from: P1.EN1  to:  P1.EX1
		park P6 {
			enter EN4
			exit EX4
		workingarea WF from EN4 to P6 // here I currently have from: EN1, EN4,P1,P2,P6 . I should not have P2 , I should only have P1, P6, P1.EN1,P6.EN4. To should be: P1.EX1, P6.EX4, P1,P6
So to summarize each working area that belongs to a park, should allow cross referencing enter and exit of that same park, sub parks of that park and the corresponding enter and exit. However, the current scope provider only allows to cross reference park P1, park P6 and their corresponding enter and exit (EN1,EX1,EN4,EX4) but not their sub parks and corresponding enter and exit (it allows the same thing throughout the entire grammar).
For the forest, I should not have P2, because it is a subpark of P1. I should only have P1, P6 and their corresponding enter and exit.
Hope this isn't too complex.
This is the scope provider.
	        		workingarea.addAll(park.getParks());
	        		workingareato.addAll(park.getParks());
I think the current scope provide only collects the first (P1, P6) and second (P2) level of parks and their respective enter and exit points, but it does not go deeper than that, while in my case I guess I have to check until there are no more parks.
Many thanks!
[Updated on: Fri, 02 April 2021 18:50] by Moderator
Re: Customize Scoping for inheritance [message #1839988 is a reply to message #1839984] Sat, 03 April 2021 01:31 Go to previous messageGo to next message
You can introduce a
Named : ParkEnter | ParkExit ;
To be able to have name=ID again
Maybe EcoreUtil2.getAllContentsOfType might help you to collect
All stuff under the root
If you cannot do it with recursive traversal
[Updated on: Sat, 03 April 2021 01:33] by Moderator
Re: Customize Scoping for inheritance [message #1839994 is a reply to message #1839988] Sat, 03 April 2021 05:01 Go to previous messageGo to next message
What approach would you suggest?
I feel like it is better to do recursive traversal but when I tried to add a while loop
while(park!=null)
That didn't really work
Re: Customize Scoping for inheritance [message #1839998 is a reply to message #1839994] Sat, 03 April 2021 10:00 Go to previous messageGo to next message
you can also create a recursive method to collect or whatever you feel good with when using java
Re: Customize Scoping for inheritance [message #1839999 is a reply to message #1839998] Sat, 03 April 2021 10:46 Go to previous messageGo to next message
I tried the following, so that when a park is not null (it has enter, exit or other subparks), it should add them to the working area, and then assign these parks to park and check again if the park is null or it has subparks, but now I don't get any suggestions at all.
	        	while (park !=null) {
	        		park = (Park) park.getParks();
Re: Customize Scoping for inheritance [message #1840053 is a reply to message #1839998] Tue, 06 April 2021 04:02 Go to previous messageGo to next message
Hi Christian,
Any idea on why this is not working or how it can be resolved as I am currently stuck at this point in the project.
Many thanks!
Re: Customize Scoping for inheritance [message #1840054 is a reply to message #1840053] Tue, 06 April 2021 04:08 Go to previous messageGo to next message
i have lost the overview what your actual problem is.
unfortunately i dont have the time to program the tree traveral code for you.
did you check the EcoreUtil2.getAllContentsOfType?
did you solve the Name vs name problem.
did you use a debugger to find out which parts of the tree you miss?
[Updated on: Tue, 06 April 2021 04:09] by Moderator
Re: Customize Scoping for inheritance [message #1840066 is a reply to message #1840054] Tue, 06 April 2021 06:08 Go to previous messageGo to next message
I was actually just trying the recursive method as I thought it would work out better and not really sure what is wrong with what I already implemented.
Yeah the name issue is ok, now I am just trying to implement the scope provider for from and I changed the Enter Name to name.
I tried to come up with the following scope provider where I try to implement EcoreUtil2.getAllContentsOfType but I still do not get any suggestions for that.
	        			workingarea.addAll(EcoreUtil2.getAllContentsOfType(park,null));
Re: Customize Scoping for inheritance [message #1840068 is a reply to message #1840066] Tue, 06 April 2021 06:47 Go to previous messageGo to next message
EcoreUtil2.getAllContentsOfType(object, TypeYouWtoCollect)
e.g.
EcoreUtil2.getAllContentsOfType(rootCountry, ParkEnter.class), no for loop needed
Re: Customize Scoping for inheritance [message #1840070 is a reply to message #1840068] Tue, 06 April 2021 07:24 Go to previous messageGo to next message
Hi Christian,
Thank you for your help!
Even though this approach is a bit different from what I wanted (I wanted to be able to cross reference only the subelements of a park and not everything), it is still fine.
However, now I am trying to have the following
workingarea W2 from P2.E2
while the grammar now only allows me to have
working area W2 from E2
Isn't the DefaultDeclarativeQualifiedNameProvider supposed to provide P2.E2? I have not made any changes to it.
Country:
	forests=Forest
Forest:
Park:
     name=ID ("{"
WorkingArea:
	name=ID "from" from=[ParkEnter|QualifiedName]
Enter:
	name=ID
ParkEnter:
	Park | Enter
QualifiedName:
 ID ('.' ID)*
	        			workingarea.addAll(EcoreUtil2.getAllContentsOfType(rootCountry, ParkEnter.class));
Many thanks!
Re: Customize Scoping for inheritance [message #1840071 is a reply to message #1840070] Tue, 06 April 2021 07:25 Go to previous messageGo to next message
yes this is that is passed to the overloads of scopeFor (there is one that accepts a fuction that calc a qualifiedname
Re: Customize Scoping for inheritance [message #1840076 is a reply to message #1840071] Tue, 06 April 2021 08:11 Go to previous messageGo to next message
Sorry, didn't quite understand that.
Do I need to change the scope provider now?
Re: Customize Scoping for inheritance [message #1840087 is a reply to message #1840076] Tue, 06 April 2021 09:54 Go to previous messageGo to next message
yes you have to call Scopes.scopeFor(listOfObjects,Function<YoutObject, QualifiedName>,IScope.NULLSCOPE)
make sure you create the QalifiedNames with proper segments (no . in segments) with QUalifiedName.create
or use IQualifiedNameConverter (injected to ScopeProvider)
Re: Customize Scoping for inheritance [message #1840093 is a reply to message #1840087] Tue, 06 April 2021 12:16 Go to previous messageGo to next message
Hi Christian,
So one possibility is to do the following?
return Scopes.scopeFor(workingarea, QualifiedName.create(segments), IScope.NULLSCOPE);
But instead of segments, what should I put to get a qualified name for the enter?
Something like : P1. enter1 (don't really want to start from the country or forest).
Re: Customize Scoping for inheritance [message #1840095 is a reply to message #1840093] Tue, 06 April 2021 12:42 Go to previous messageGo to next message
no you need to pass a function or closure.
you can use eContainer() on an eObject to get the parent, then downcast it.
e.g.
List<ParkEnter> workingarea = new ArrayList<ParkEnter>();
return Scopes.scopeFor(workingarea, (ParkEnter e) -> {
Park p = (Park) e.eContainer();
return QualifiedName.create(p.getName(), e.getName());
}, IScope.NULLSCOPE);
Re: Customize Scoping for inheritance [message #1840102 is a reply to message #1840095] Tue, 06 April 2021 16:40 Go to previous messageGo to next message
I tried out the following scope provider where instead of :
I put
Because I couldn't say :
Being that I already had declared a working area.
This is the scope provider that I am using:
	       // List<EObject> workingarea = new ArrayList<>();
But I do not get any suggestions when I try to write the grammar
Re: Customize Scoping for inheritance [message #1840116 is a reply to message #1840102] Tue, 06 April 2021 23:58 Go to previous messageGo to next message
Please please debug your code and the scope provider
And the proposal provider
also check the console for errors.
this would have helped you to find the problem an solve it
			Function<ParkEnter, QualifiedName> nameComputation = (ParkEnter e) -> {
				EObject eContainer = e.eContainer();
				if (eContainer instanceof Park) {
					Park p = (Park) eContainer;
				return QualifiedName.create(e.getName());
			return Scopes.scopeFor(workingarea, nameComputation, IScope.NULLSCOPE);
[Updated on: Wed, 07 April 2021 00:10] by Moderator
Re: Customize Scoping for inheritance [message #1840129 is a reply to message #1840116] Wed, 07 April 2021 04:29 Go to previous messageGo to next message
Hi Christian,
Sorry for all the hustle.
I tried your approach, but first on this line:
I got an error saying:
Multiple markers at this line
- The target type of this expression must be a functional
interface
- Function cannot be resolved to a type
So I imported com.google.common.base.Function
However afterwards I got an error on this line:
saying:
- The method scopeFor(Iterable<? extends T>, Function<T,QualifiedName>, IScope) in the type Scopes is not applicable for the arguments (List<EObject>,
Function<ParkEnter,QualifiedName>, IScope)
This is the full scope provider:
Many thanks once again!
Re: Customize Scoping for inheritance [message #1840130 is a reply to message #1840129] Wed, 07 April 2021 04:31 Go to previous messageGo to next message
i recommend you to do some java training first
Function<EObject, QualifiedName> nameComputation = (EObject e) -> {
// do instanceof shit here
Re: Customize Scoping for inheritance [message #1840139 is a reply to message #1840130] Wed, 07 April 2021 05:58 Go to previous messageGo to next message
Hi Christian,
Yes you are right that is why it is so hard for me to customize this scope provider. However I still get issues, maybe it is something related to the EObject e, because in row:
return QualifiedName.create(p.getName(),e.getName());
And in row
I get
- The method getName() is undefined for the type EObject
Which I would not get when there was ParkEnter instead of EObject.
Many thanks!
Re: Customize Scoping for inheritance [message #1840141 is a reply to message #1840139] Wed, 07 April 2021 06:14 Go to previous messageGo to next message
as i said: use instanceof, downcast .....
Re: Customize Scoping for inheritance [message #1840147 is a reply to message #1840141] Wed, 07 April 2021 07:48 Go to previous messageGo to next message
Ok so if I am not mistaken (take a look at the comments in the code)
				if (eContainer instanceof Park) { // here I use instanceof
					Park p = (Park) eContainer;	//here I do downcasting
But is there something else I should do to get to e.getname().
Sorry I bothered you with this, is just that this is the last remaining issue in my project that I need to solve
Re: Customize Scoping for inheritance [message #1840149 is a reply to message #1840147] Wed, 07 April 2021 07:52 Go to previous messageGo to next message
(EObject e) -> {
well you need to make instanceof on e as well
Re: Customize Scoping for inheritance [message #1840152 is a reply to message #1840149] Wed, 07 April 2021 10:17 Go to previous messageGo to next message
Hi Christian,
I tried the following function
					if (e instanceof Enter) {
						Enter en = (Enter) eContainer;
					return QualifiedName.create(p.getName(), en.getname());
				return QualifiedName.create(en.getName());
But I still cannot get en.getname()
I get errors saying :
- The method getname() is undefined for the type
EObject
- en cannot be resolved
Re: Customize Scoping for inheritance [message #1840153 is a reply to message #1840152] Wed, 07 April 2021 11:38 Go to previous messageGo to next message
question: how firm are you with java programming?
//pseudo code
if (e instanceof ParkEnter) {
... container logic
} else if (e instanceof OtherStuffYOurPutTOTHATLIST) {
} elseif (e instanceof ThridStuff) {
else {
throw new IllegalStateException("did not expect an " e.GetClass().getName() +"here");
Re: Customize Scoping for inheritance [message #1840159 is a reply to message #1840153] Wed, 07 April 2021 15:58 Go to previous messageGo to next message
Hi Christian,
I tried a few things with the grammar :
First I tried the following function:
	    	   if (e instanceof Park)
	    		   Park p = (Park) e;
	    	      return QualifiedName.create(p.getName(), ((Park) e).getName());
	    	   return QualifiedName.create(((ParkEnter) e).getName());
But here I get Park.Park and not Park.Enter () because of this line:
Afterwards I tried the following function:
ParkEnter p = (ParkEnter) e;
return QualifiedName.create(p.getName(), ((ParkEnter) e).getName());
Here I get Park.Park and Enter.Enter being that ParkEnter: Park | Enter, but still I don't get Park.Enter
Now I am trying the following:
	    		  Enter en = (Enter) e;
	    	      return QualifiedName.create(Park.getName(), en.getName());
because I want to have Park.getName() , Enter.getName, but I don't really know how to access Enter, and the Park to which that Enter belongs to.
In this scope provider I get an error because
Cannot make a static reference to the non-static method getName() from the type
ParkEnter
I am including the grammar once again:
Country:
	forests=Forest
Forest:
Park:
     name=ID ("{"
WorkingArea:
Enter:
	name=ID
ParkEnter:
	Park | Enter
QualifiedName:
 ID ('.' ID)*
And the scope provider:
	    		   Park p = (Park) e;
Re: Customize Scoping for inheritance [message #1840170 is a reply to message #1840159] Thu, 08 April 2021 00:30 Go to previous messageGo to next message
Park is a Class and not a variable.
as you have Seen you can use eContainer to access parents
And you can ask the parent for its parent and you get the grandparent .
Where is this code gone? Why have you removed it
You can Also use EcoreUtil2.getContainerOfType(object, TypeOfAncestorYouSearch.class)
Please please consult somebody with basic java knowledge.
I will stop answering here as long as the problem boils down
To lacking java knowledge
Re: Customize Scoping for inheritance [message #1840179 is a reply to message #1840170] Thu, 08 April 2021 04:09 Go to previous messageGo to next message
Ok thank you, I will try to sort something out.
One final questions as I got confused trying out different things.
When I write this part:
The eContainer should be an instanceof Park,Enter or ParkEnter.
Many thanks for your help!
Re: Customize Scoping for inheritance [message #1840180 is a reply to message #1840179] Thu, 08 April 2021 04:29 Go to previous messageGo to next message
then use else if and another else if
Re: Customize Scoping for inheritance [message #1840182 is a reply to message #1840180] Thu, 08 April 2021 04:45 Go to previous messageGo to next message
Sorry for the misunderstanding, that was actually in the form of a question.
If I want to have Park.Enter, I should start with
if (eContainer instanceof Park) ? or
if (eContainer instanceof Enter)? or
if (eContainer instanceof ParkEnter)?
or should I have all three of them using if elseif elseif.
So my biggest issue is starting from instanceof Park I should be able to access Enter or vice versa?
Re: Customize Scoping for inheritance [message #1840183 is a reply to message #1840182] Thu, 08 April 2021 04:57 Go to previous messageGo to next message
i dont understand
why eContainer and not
e
} else if (e instanceof OtherStuffYouPutToTheList) {
Re: Customize Scoping for inheritance [message #1840184 is a reply to message #1840183] Thu, 08 April 2021 05:06 Go to previous messageGo to next message
From your earlier message :
I thought I should add it.
Re: Customize Scoping for inheritance [message #1840185 is a reply to message #1840184] Thu, 08 April 2021 05:53 Go to previous messageGo to next message
I was able to resolve it with the following approach:
	             Park p = EcoreUtil2.getContainerOfType(en, Park.class);
	    	      return QualifiedName.create(p.getName(), en.getName());
	    	   return QualifiedName.create(((ParkEnter)e).getName());
Thank you so much for all your help.
Re: Customize Scoping for inheritance [message #1840192 is a reply to message #1840183] Thu, 08 April 2021 08:09 Go to previous messageGo to next message
Hi Christian,
I was able to solve the issue that I had before, but now I was wondering about something else. With the following scope provider:
I should use the qualified name even when I cross reference elements in the same hierarchical level. For example in the following grammar(please read the comment).
country C1 {
	forest F1 {
		park P1 {
			enter EN1
			park P2 {
				enter EN2
				park P3
				park P4 {
					enter EN3
					park P5
					workingarea W4 from P4.EN3. // here it should be EN3 because both EN3 and W4 are Part of P4. If I were to have EN2, that I should write it as P2.EN2, as it is not part of P4.
         workingarea W1 from P6.EN4
		park P6 {
			enter EN4
		workingarea WF from P6.EN4
Is there a way around this?
Many thanks!
Re: Customize Scoping for inheritance [message #1840196 is a reply to message #1840192] Thu, 08 April 2021 08:58 Go to previous messageGo to next message
simply implement this is in your if else.
have a look at the context object that is passed to the scope method.
Re: Customize Scoping for inheritance [message #1840198 is a reply to message #1840196] Thu, 08 April 2021 09:31 Go to previous message
No Message Body
[Updated on: Thu, 08 April 2021 10:27] by Moderator
Previous Topic:missing RULE_BEGIN if using whitespace-aware
Next Topic:Qualified Name according to the hierarchical level
Current Time: Wed Aug 20 18:18:07 EDT 2025
Powered by FUDForum. Page generated in 0.15064 seconds
