Home » Modeling » EMF » Unresolved requirement after building CDO server plugin manually
Unresolved requirement after building CDO server plugin manually [message #1839401] Fri, 19 March 2021 21:42 Go to next message
I'm getting an error during CDO server startup when I replaced a server plugin from the 4.12 distribution with a manually built version of the plugin that I built from the CDO source tree with eclipse. I've updated org.eclipse.net4j.internal.util.bundle.OM to set a pattern for the PrintTraceHandler.CONSOLE to include a date and timestamp for the log.
I used the plugin development tools in eclipse to export the plugin just like I did for the org.eclipse.net4j.db.oracle plugin but when I replace it in the plugins directory I'm getting the error shown below in the configuration log and CDO server fails to start. This is one of many errors for unresolved plugins in the configuration log file, but the core reason seems to be originate from the org.eclipse.net4j.util plugin that I've built from the CDO source master branch. The version of the plugin from CDO 4.12 is 3.13.0 and the plugin I built from the source tree is 3.14.0, but the range of versions for net4j.util from the message seems to be 3.0 to 4.0 so this should work. Do you have any suggestions for how to fix this?
This is one example of the unresolved requirement for this plugin in the log and there are 51 similar entries:
!ENTRY org.eclipse.emf.cdo 4 0 2021-03-19 22:07:37.112
!MESSAGE FrameworkEvent ERROR
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.emf.cdo [87]
Unresolved requirement: Require-Bundle: org.eclipse.emf.cdo.common; bundle-version="[4.0.0,5.0.0)"; visibility:="reexport"
-> Bundle-SymbolicName: org.eclipse.emf.cdo.common; bundle-version="4.12.0.v20201125-0935"; singleton:="true"
org.eclipse.emf.cdo.common [88]
Unresolved requirement: Require-Bundle: org.eclipse.net4j.util; bundle-version="[3.0.0,4.0.0)"; visibility:="reexport"
at org.eclipse.osgi.container.Module.start(Module.java:463)
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel$2.run(ModuleContainer.java:1845)
at org.eclipse.osgi.internal.framework.EquinoxContainerAdaptor$1$1.execute(EquinoxContainerAdaptor.java:136)
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1838)
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1779)
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.doContainerStartLevel(ModuleContainer.java:1743)
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1665)
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1)
at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:234)
at org.eclipse.osgi.framework.eventmgr.EventManager$EventThread.run(EventManager.java:345)
Re: Unresolved requirement after building CDO server plugin manually [message #1839404 is a reply to message #1839401] Sat, 20 March 2021 01:56 Go to previous messageGo to next message
Hard to tell. Perhaps a feature locks in a fixed bundle version (including the qualifier)?
Can you use the OSGi console to find out more about the state of your installation?
Have you tried to run a full local Maven/Tycho build to get a consistent set of fetaures and bundles?
Re: Unresolved requirement after building CDO server plugin manually [message #1839422 is a reply to message #1839404] Sat, 20 March 2021 18:11 Go to previous messageGo to next message
I hadn't even heard of the osgi console. Although I may remember seeing it as one of the options on the eclipse console view menu - like the git console. Is there a link you can refer me to for how to use the osgi console to check the state?
One thing I was going to try monday is switching my CDO git branch to the 4.12 release tag (?) and building it again to see if that works.
Re: Unresolved requirement after building CDO server plugin manually [message #1839466 is a reply to message #1839422] Mon, 22 March 2021 05:08 Go to previous messageGo to next message
Warwick Burrows wrote on Sat, 20 March 2021 23:11
Unfortunately not. You'll need to find something on the web.
4.13 is out, too.
What I don't get is why you're trying to rebuild org.eclipse.net4j.util yourself just to set a tracing pattern. Couldn't you just call PrintTraceHandler.CONSOLE.setPattern()? Or even replace PrintTraceHandler.CONSOLE with your own instance of OMTraceHandler?
OMPlatform.INSTANCE.removeTraceHandler(PrintTraceHandler.CONSOLE);
OMPlatform.INSTANCE.addTraceHandler(new PrintTraceHandler()
Re: Unresolved requirement after building CDO server plugin manually [message #1839491 is a reply to message #1839466] Mon, 22 March 2021 12:07 Go to previous messageGo to next message
Well I do have the PrintTraceHandler setup that way in my client, but the CDO server also doesn't add timestamps to trace messages. Which is why I changed the trace setup in org.eclipse.net4j.util to add a timestamp to the front of the trace messages. e.g. in OM.java Activator.start(). The TODO note to make this configurable has been there in the source tree since CDO 4.1 :-)
// TODO Make configurable
PrintTraceHandler.CONSOLE.setPattern("{4,date,yyyy-MM-dd HH:mm:ss.SSS z} -- {6} [{0}] {5}"); //$NON-NLS-1$
AbstractPlatform.INSTANCE.addTraceHandler(PrintTraceHandler.CONSOLE);
AbstractPlatform.INSTANCE.addLogHandler(PrintLogHandler.CONSOLE);
Re: Unresolved requirement after building CDO server plugin manually [message #1839493 is a reply to message #1839491] Mon, 22 March 2021 12:49 Go to previous messageGo to next message
Problem solved. There must be a plugin that is referencing that exact version of the org.eclipse.net4j.util plugin. When I rebuilt the plugin with the exact version and qualifier of the original plugin then it works.
Re: Unresolved requirement after building CDO server plugin manually [message #1839526 is a reply to message #1839491] Tue, 23 March 2021 07:26 Go to previous messageGo to next message
Warwick Burrows wrote on Mon, 22 March 2021 17:07
You can contribute a custom IAppExtension with your server. There you can replace the trace handler just like in your client.
Re: Unresolved requirement after building CDO server plugin manually [message #1839527 is a reply to message #1839493] Tue, 23 March 2021 07:27 Go to previous messageGo to next message
Warwick Burrows wrote on Mon, 22 March 2021 17:49
As I said before, only features refer to exact plugin versions, but anyways... ;-)
Re: Unresolved requirement after building CDO server plugin manually [message #1839569 is a reply to message #1839526] Tue, 23 March 2021 23:21 Go to previous message
Sorry I should have checked the features.
I'll look into that after 4.12 is successfully in production. It will definitely make subsequent CDO server upgrades easier.
Previous Topic:model.ecore is not generated in /model/impl during 'clean install' maven goal
Next Topic:[CDO] Websocket transport layer
Current Time: Wed Nov 05 14:37:32 EST 2025
Powered by FUDForum. Page generated in 0.04452 seconds
