Home » Eclipse Projects » Marketplace Client Project » Can't install an extension from the market
Can't install an extension from the market [message #1839296] Thu, 18 March 2021 18:32 Go to next message
This extension cannot be installed. Eclipse does not see it in the market.
OS: Solus Linux
Eclipse version: 2020-12 (4.18.0)
index.php/fa/40163/0/
Re: Can't install an extension from the market [message #1839386 is a reply to message #1839296] Fri, 19 March 2021 12:34 Go to previous message
I think it's broken according to the tests that run against it:
https://www.eclipse.org/setups/marketplace/?id=4120961
It doesn't appear that that update site even loads correctly:
https://ascii-uml.github.io/eclipse
Maybe they answer questions here:
Previous Topic:Installing Plugin via Marketplace client stays "Install Pending"
Next Topic:How to disable HTTP Marketplace with Proxy
Current Time: Thu Nov 06 02:35:20 EST 2025
Powered by FUDForum. Page generated in 0.03772 seconds
