Home » Eclipse Projects » Standard Widget Toolkit (SWT) » Draw2D Spike in Glimmer DSL for SWT(Created a Rough DSL for the GEF Draw2D Library in Glimmer)
Draw2D Spike in Glimmer DSL for SWT [message #1839058] |
Fri, 12 March 2021 00:18 |
The Eclipse ecosystem includes a highly advanced 2D graphics library called Draw2D (comes as part of GEF), which rests on top of the SWT Canvas widget.
I got a chance to play around with it today and even do a spike in Glimmer DSL for SWT for supporting a Draw2D DSL. I finished a rough version in about an hour or two. Check out the samples I created below.
Spike 1 (Rectangle and contained Polygon + Drag & Drop Movement):
# This is just a draw2d spike from the draw2d-spike branch 2021-03-12 (does not work in standard Glimmer DSL for SWT)
require 'glimmer-dsl-swt'
include Glimmer
shell {
minimum_size 200, 200
canvas {
fill_layout;
rectangle_figure {|proxy|
bounds org.eclipse.draw2d.geometry.Rectangle.new(0, 0, 50, 50)
background_color color(:cyan).swt_color
opaque true
on_mouse_dragged { |event|
old_x = proxy.draw2d_figure.location.x
old_y = proxy.draw2d_figure.location.y
proxy.draw2d_figure.setLocation(org.eclipse.draw2d.geometry.Point.new(old_x + event.x - @last_x, old_y + event.y - @last_y)) if @last_x && @last_y
@last_x = event.x
@last_y = event.y
on_mouse_released {
proxy.draw2d_figure.background_color = color([:green, :red, :blue].sample).swt_color
@last_x = nil
@last_y = nil
polygon {|proxy|
fill true
background_color color(:red).swt_color
points org.eclipse.draw2d.geometry.PointList.new([13, 13, 50, 30, 40, 4].to_java(:int))
@last_x = event.x
@last_y = event.y
on_mouse_released {
@last_x = nil
@last_y = nil
}.open
Screenshot:
Spike 2 (Rectangle and contained Ellipse + Drag & Drop Movement):
include Glimmer
shell {
minimum_size 300, 300
text 'Hello, Draw2d!'
canvas { |canvas_proxy|
fill_layout;
on_mouse_down { |event|
@last_x = event.x
@last_y = event.y
on_mouse_move { |event|
if @shape_to_move
old_x = @shape_to_move.location.x
old_y = @shape_to_move.location.y
new_x = old_x + event.x - @last_x
new_y = old_y + event.y - @last_y
@shape_to_move.setLocation(org.eclipse.draw2d.geometry.Point.new(new_x, new_y)) if @last_x && @last_y
@last_x = event.x
@last_y = event.y
end
on_mouse_up { |event|
@last_x = nil
@last_y = nil
@shape_to_move = nil
focus_traversable true
bounds org.eclipse.draw2d.geometry.Rectangle.new(10, 10, 180, 180)
clipping_strategy(lambda {|child_figure| [org.eclipse.draw2d.geometry.Rectangle.new(0, 0, 5000, 5000)].to_java(org.eclipse.draw2d.geometry.Rectangle)})
on_mouse_pressed { |event|
@last_x = event.x
@last_y = event.y
@shape_to_move = canvas_proxy.top_level_figure.find_figure_at(event.x, event.y)
@last_x = event.x
@last_y = event.y
on_mouse_released {
@last_x = nil
@last_y = nil
ellipse {|proxy|
fill true
opaque true
bounds org.eclipse.draw2d.geometry.Rectangle.new(50, 50, 100, 100)
@last_x = event.x
@last_y = event.y
@last_x = event.x
@last_y = event.y
on_mouse_released {
@last_x = nil
@last_y = nil
}.open
Screenshot:
Spike 3 (Multiple Rectangles and Ellipses within a GridLayout of 8 columns + Drag & Drop Movement):
include Glimmer
shell {
fill_layout;
@last_x = event.x
@last_y = event.y
if @shape_to_move
@last_x = event.x
@last_y = event.y
end
@last_x = nil
@last_y = nil
16.times {
bounds org.eclipse.draw2d.geometry.Rectangle.new(10, 10, 80, 80)
@last_x = event.x
@last_y = event.y
@last_x = event.x
@last_y = event.y
on_mouse_released {
@last_x = nil
@last_y = nil
ellipse {|proxy|
fill true
opaque true
minimum_size org.eclipse.draw2d.geometry.Dimension.new(100, 100)
preferred_size 100, 100
# points org.eclipse.draw2d.geometry.PointList.new([13, 13, 50, 30, 40, 4].to_java(:int)) # points for a polygon alternative figure
@last_x = event.x
@last_y = event.y
@last_x = event.x
@last_y = event.y
on_mouse_released {
@last_x = nil
@last_y = nil
}.open
Screenshot:
Originally Posted at: https://andymaleh.blogspot.com/2021/03/draw2d-spike-in-glimmer-dsl-for-swt.html
[Updated on: Fri, 12 March 2021 00:41] by Moderator
Current Time: Sun Aug 31 14:54:36 EDT 2025
Powered by FUDForum. Page generated in 0.03530 seconds
