Home » Eclipse Projects » Oomph » Command Line parameters for Eclipse 64bit Installer(Command line Parameters )
Command Line parameters for Eclipse 64bit Installer [message #1838980] Wed, 10 March 2021 13:12 Go to next message
Hello Guys we are trying to install eclipse through SCCM but it is failing we ae not using any parameters just running the exe let me know if there are some parameters that can help.
Below is the error I get from Software Installation. What does (-3) mean for the application.
0xFFFFFFFD(-3)
Jay
[Updated on: Thu, 11 March 2021 10:38] by Moderator
Re: Command Line parameters for Eclipse 64bit Installer [message #1839020 is a reply to message #1838980] Thu, 11 March 2021 08:00 Go to previous messageGo to next message
I have no experience with SCCM. I'm not sure what is failing.
Re: Command Line parameters for Eclipse 64bit Installer [message #1839021 is a reply to message #1839020] Thu, 11 March 2021 08:02 Go to previous messageGo to next message
Hello Ed,
Thank you for responding. What parameters do you generally use with the package to install? Doesn't have to be SCCM.
Thank you,
Jay
Re: Command Line parameters for Eclipse 64bit Installer [message #1839028 is a reply to message #1839021] Thu, 11 March 2021 09:51 Go to previous messageGo to next message
Keep in mind that when I say I have no exerience with SCCM I'm saying those are just 4 letters to me. The installer runs without need for any parameters, so I don't understand why you're asking about them.
Re: Command Line parameters for Eclipse 64bit Installer [message #1839031 is a reply to message #1838980] Thu, 11 March 2021 10:39 Go to previous messageGo to next message
The application is giving the following error: 0xFFFFFFFD(-3)
Do you know what it means?
Thank you,
Jay
Re: Command Line parameters for Eclipse 64bit Installer [message #1839036 is a reply to message #1839031] Thu, 11 March 2021 11:09 Go to previous message
No, sorry, I've never seen such a failure.
Previous Topic:Eclipse 2020-06 Installation Error with xtext
Next Topic:Doomph.setup.sync is not working properly
Current Time: Mon Aug 18 02:35:52 EDT 2025
Powered by FUDForum. Page generated in 0.05697 seconds
