Eclipse RCP: Error when exporting Sample Eclipse Product [message #1838430] |
Wed, 24 February 2021 13:48  |
I've set up jdk-15.0.2+7 from AdoptOpenJDK. I've set up Eclipse IDE for RCP and RAP Developers (version: 2020-12 (4.18.0), Build id: 20201210-1552). I started Eclipse, created Plug-in Project PortfolioAnalyzer with default settings:
Target platform: Eclipse,
Create a rich client application? Yes
Plug-in Template: Eclipse 4 RCP Application
Checkbox Create sample content (part, menu, command...): True
Then I
- open PortfolioAnalyzer.product with default Product Configuration Editor, tab Overview and click link Eclipse Product export wizard in Exporting section
- specify Destination directory: D:\rcp_out, all settings by default.
And get error:
D:\Work\Eclipse\Java\PortfolioAnalyzer\.metadata\.plugins\org.eclipse.pde.core\temp\org.eclipse.pde.container.feature\package.org.eclipse.pde.container.feature.win32.win32.x86_64.xml:477: The following error occurred while executing this line:
C:\Users\Vadim\.p2\pool\plugins\org.eclipse.pde.build_3.10.900.v20201111-1557\scripts\genericTargets.xml:240: A problem occured while invoking the director.
I've edited C:\Users\Vadim\.p2\pool\plugins\org.eclipse.pde.build_3.10.900.v20201111-1557\scripts\genericTargets.xml
by adding in target runDirector the following line just after properties definitions:
<record name="d:/build.log" loglevel="verbose" append="false"/>
In the case I get the log file when the error occurs. This is its content:
Property "p2.director.log" has not been set
[p2.director] Installing App 1.0.0.202102120000.
[p2.director] Installation failed.
[p2.director] Cannot complete the install because one or more required items could not be found.
[p2.director] Software being installed: PortfolioAnalyzer 1.0.0.202102120000 (App 1.0.0.202102120000)
[p2.director] Missing requirement: PortfolioAnalyzer 1.0.0.202102120000 (PortfolioAnalyzer 1.0.0.202102120000) requires 'osgi.ee; (&(osgi.ee=JavaSE)(version=15))' but it could not be found
[p2.director] Cannot satisfy dependency:
[p2.director] From: PortfolioAnalyzer 1.0.0.202102120000 (App 1.0.0.202102120000)
[p2.director] To: org.eclipse.equinox.p2.iu; PortfolioAnalyzer [1.0.0.202102120000,1.0.0.202102120000]
runDirector: duration 0 seconds
Could you explain how to fix the problem? Should p2.director.log property be set somehow? Or something wrong with org.eclipse.equinox.p2.iu?
FUDForum. Page generated in 0.03031 seconds
