| The most suitable theorem prover/validation tool for eclipse to validate OCLineCORE constraints. [message #1837839] |
Mon, 08 February 2021 08:34  |
I would like to apologize in advance if the forum is not appropriate for my topic ( redirect me to the appropriate one if possible).
I'm working on a model to model transformation, using ECORE metamodels and OCL constraints. I would like to know What is the best theorem prover/ testing tool (exp: coq, USE..) that I can use with Eclipse (as a plug-in or so) to express/validate mathematically the proposed OCL constraints that are embedded in my Ecore model?
I found coqoon which is an Eclipse plugin providing a feature-complete development environment for Coq projects. However, after little research I found out that it was not updated to be compatible with recent Coq versions, so I hesitated.
Thank you.
FUDForum. Page generated in 0.05314 seconds
