Home » Eclipse Projects » Eclipse Titan » Log FileMask / ConsoleMask filter by component type?
Log FileMask / ConsoleMask filter by component type? [message #1837653] |
Wed, 03 February 2021 16:41 |
I understand it is possible to configure the log verbosity ("log filtering") based on the name of a component (at time of the create), as explained in the Reference Guide under "Component and Plugin Based Filtering"
However, there doesn't seem to be any documented option to do the same based on the component type, or possibly based on wildcard/regex matching of the name given in crate().
I wonder how other people deal with this. Let's say you start one hundred components of a certain type, and you want to make sure to enable or disable certain log flags for all of those components?
Adding hundreds of different individual component names to the config file doesn't seem like a very elegant or scalable approach.
As always, any help is appreciated.
Re: Log FileMask / ConsoleMask filter by component type? [message #1837690 is a reply to message #1837658] |
Thu, 04 February 2021 09:10 |
Hi Roland,
thanks for your response.
"create()" of course just allows you to specify the identity of the component, and that should of course be unique, otherwise it doesn't serve much purpose. Sure, it is not mandatory for the name to be unique (If I remember correctly, but what point does a name have if it doesn't uniquely identify a component.
The feature I'm talking about is more one in terms of the config file parsing, specifically the LogFilter / ConsoleFilter syntax. If one could specify the Component Type there, it would be very easy to configure the desired scenario.
We already have per-component log files. The point is to not even generate tons of verbose logs unless it is needed. So, e.g. by default I would want to see TIMEROP_START logging of all my components, but I want to explicitly disable that for all components of one type, as that component is constantly starting very short timers of 5ms, and that creates lots of useless log (filling disk, costing CPU resources to print, ...).
Running hundreds of components works generally well in my experience.. This is not a performance use case, but relatively simple "functional" testing. We (at osmocom.org) typically have one component for every simulated UE, and then some other components to multiplex.
For example on the Gb interface in GPRS, the NS stack already has one component per NS-VC, and then one component as NS_Emulation for each NSE. On top of that, there is the BSSGP_Emulation with one shared + one component per BVC, and then you have one component for each of the UEs on top of each PTP-BVC component. Modern CPUs, particularly those on servers usd for CI or build purposes have many cores and even more threads, so parallel execution of many processes (= components) is not a problem. Furthermore, TITAN can even scale out and control components on other nodes/hosts, so scaling that way is not a problem.
Sure, things can always be done differently, but the strength of TTCN3 is in its programming model resembling an "actor" mdoel with incoming and outgoing ports, related queues, etc. - If I wanted to program in asynchronous state machines within a single component/thread/..., I would write it in C, not in TTCN3 ;) - this is how all of our actual IUT are developed. Also, it would be a rather strange motivation to let your software architecture be guided by how the logging system can or cannot be configured.
Re: Log FileMask / ConsoleMask filter by component type? [message #1837698 is a reply to message #1837690] |
Thu, 04 February 2021 10:57 |
roland gecse Messages: 20 Registered: December 2015 |
Perhaps a bit off-topic, but I cannot resist to answer:
I am happy that you are satisfied with our design/implementation.
Lucky you! When we run some traffic tests with TITAN we need to simulate millions of UEs. 1 PTC/UE will not do. We need a rack of high end multi processor, multi core servers to do it.
I know. Distributed execution over heterogeneous environment feature was kind of my idea :)
I am well aware.
Sure you could. The nice thing is that you can combine both languages with TITAN. You could use e.g. abstract communication primitives, type-value-template system of TTCN-3 along with more performance C/C++ behavior.
End of off-topic.
W.r.t. the original question I am sorry but we didn't prepare for your UC when doing the original design. But improvement ideas are always welcome. I really encourage you to submit a new feature request or write and contribute the necessary code changes yourself!
Current Time: Fri Apr 26 23:43:42 GMT 2024
Powered by FUDForum. Page generated in 0.03505 seconds
