Multi Cell Editor [message #1837284] |
Wed, 27 January 2021 01:43  |
We have a NAT table with 2 columns, Each column has a separate LOV (Single value Combo) .
For Example, Column 1 has 1, 2, 3 as LOV values, Column 2 has a, b, c, d as LOV values.
Now when the user selects 1 cell from Column 1 and 1 cell from column 2 and hit any key in the keyboard, Multi Cell combo editor is opened and it shows the LOV of either Column 1 or Column 2. If the user selects any value from the combo the value was set on both the cells.
Our Requirement is, If user selects multiple cells across different column where each column has different LOV attached to it. We should not open the Multi Cell editor dialog. Since it will list only one of the LOV.
Is there any way to achieve this ?
FUDForum. Page generated in 0.04033 seconds
