Home » Modeling » TMF (Xtext) » Dokumentation for Formatter2 API(How to implement formatter2 in Xtext ?)
Dokumentation for Formatter2 API [message #1837158] Fri, 22 January 2021 18:19 Go to next message
The dokumentation of the formatter2 API is for me very incomplete.
Is there any document discribing in detail how to write a formmatter2.
Re: Dokumentation for Formatter2 API [message #1837162 is a reply to message #1837158] Sat, 23 January 2021 00:19 Go to previous messageGo to next message
Hello Olaf,
you can find more information about the Xtext formatter2 API under:
https://de.slideshare.net/meysholdt/xtexts-new-formatter-api
https://blogs.itemis.com/en/tabular-formatting-with-the-new-formatter-api
https://www.eclipse.org/forums/index.php?SQ=f1aaa0dbbe18f2d2d4155d24b42a5430&t=search&srch=formatter2&btn_submit=Search&field=all&forum_limiter=27&attach=0&search_logic=AND&sort_order=DESC&author=
take a look at the Xtext Examples shipped with the Xtext Framework, the also demonstrate the usage of the formatter2 API
If you have any particular problem, just ask a little bit more concrete question, then we were able to help you more.
Hope that helps,
Tamás
[Updated on: Sat, 23 January 2021 00:20] by Moderator
Re: Dokumentation for Formatter2 API [message #1837167 is a reply to message #1837162] Sat, 23 January 2021 03:24 Go to previous messageGo to next message
Thanx a lot I'l take a look and be eventually back with more concrete questions
Thanx a lot
Re: Dokumentation for Formatter2 API [message #1837168 is a reply to message #1837167] Sat, 23 January 2021 03:54 Go to previous messageGo to next message
I have the following formatter code:
	def dispatch void format(GeneratorModel m, extension IFormattableDocument document) {
		// TODO: format HiddenRegions around keywords, attributes, cross references, etc.
		// model.region
		val model = m.regionFor
		model.keyword("generator").prepend[newLine]
		interior(
			m.regionFor.keyword('{').append[newLine],
			m.regionFor.keyword('}'),
			[indent]
		for (sub : m.templateList) {
			sub.format
	def dispatch void format(TemplateDescriptor m, extension IFormattableDocument document) {
		interior(
			[indent]
		for (sub : m.sectionOrder) {
			sub.format
//			td.append[setNewLines(1, 1, 2)]
	def dispatch void format(Section m, extension IFormattableDocument document) {
		interior(
			[indent]
		for (sub : m.mapping) {
			sub.format
the coresponding grammar looks like this (terminal rule FQN ommitted)
GeneratorModel:
	"generator" "model" name=FQN "for" model=[ecore::EPackage]
	("template" templateList+=TemplateDescriptor)*;
TemplateDescriptor:
	name=ID sectionMarker=STRING variableMarker=STRING "{"
		sectionOrder+=Section*
Section:
	name=ID "{"
	mapping+=SectionVarMapping
SectionVarMapping:
	name=ID feature=[ecore::EStructuralFeature|FQN]
GeneratorModel:
TemplateDescriptor:
Section:
	name=ID "{"
SectionVarMapping:
And the following model text
template ClassTemplate "//XXXXX" "_X_" {
	package {
		packageName GeneratorModel.name
classheader {
		className   GeneratorModel.name
I expected the first '}' to be indented with the "package" subsequent line should be as well indented this way except the last '}'.
What is missing in my formatter code?
Re: Dokumentation for Formatter2 API [message #1837254 is a reply to message #1837168] Tue, 26 January 2021 05:10 Go to previous message
Hello Olaf,
In order to indent the closing '}' with the "package" keyword, you have to append a newline to the beginning and to the end of the interior.
The following formatter implementation works for me:
 * generated by Xtext 2.25.0-SNAPSHOT
package org.xtext.example.mydsl.formatting2
import org.eclipse.xtext.formatting2.AbstractFormatter2
import org.eclipse.xtext.formatting2.IFormattableDocument
import org.xtext.example.mydsl.myDsl.GeneratorModel
import org.xtext.example.mydsl.myDsl.Section
import org.xtext.example.mydsl.myDsl.SectionVarMapping
import org.xtext.example.mydsl.myDsl.TemplateDescriptor
class MyDslFormatter extends AbstractFormatter2 {
			sub.format
		val begin = m.regionFor.keyword("{")
		val end = m.regionFor.keyword("}")
		begin.append[newLine]
		interior(begin, end)[indent]
			sub.format
			sub.format
		end.append[newLine]
	def dispatch void format(SectionVarMapping m, extension IFormattableDocument document) {
		m.append[newLine]
The corresponding JUnit test cases:
package org.xtext.example.mydsl.tests
import com.google.inject.Inject
import org.eclipse.xtext.testing.InjectWith
import org.eclipse.xtext.testing.XtextRunner
import org.eclipse.xtext.testing.formatter.FormatterTestHelper
import org.junit.Test
import org.junit.runner.RunWith
@RunWith(XtextRunner)
@InjectWith(MyDslInjectorProvider)
class MyDslFormatterTest {
	@Inject extension FormatterTestHelper
	@Test def test001() {
		assertFormatted[
			toBeFormatted = '''
				generator model foo for bar
				template ClassTemplate "//XXXXX" "_X_" {}
			expectation = '''
	@Test def test002() {
		assertFormatted[
			toBeFormatted = '''
				package {
			expectation = '''
					package {
	@Test def test003() {
		assertFormatted[
			toBeFormatted = '''
				package {
			expectation = '''
					package {
	@Test def test004() {
		assertFormatted[
			toBeFormatted = '''
				package {
				classheader {
			expectation = '''
					package {
					classheader {
Hope that helps,
Tamás
Previous Topic:Strange Error Message - no clue what is wrong
Next Topic:Defining variable inside your language document?
Current Time: Mon Sep 01 13:59:11 EDT 2025
Powered by FUDForum. Page generated in 0.23783 seconds
