EASE debug mode [message #1837012] |
Thu, 21 January 2021 00:06  |
Stephane LACRAMPE Messages: 215 Registered: July 2009 |
Hi there,
I am experimenting with EASE using python. I wrote a 2 python scripts. The main script is calling a sub-function from the second script (I am using the include command). The scripts works fine when I run it and produces what it is supposed to do.
Now I am trying to launch the main script in debug mode, it looks like it is working fine, but when I try to go inside the sub-function on the other script in debug mode, it enters but then goes out back to the main script on the next step even if there are more instructions in the sub-function.
Do you know if this is a limitation of the debug mode? or if I am doing something wrong?
Thanks a lot.
Stephane
Stephane LACRAMPE
Obeo Canada
FUDForum. Page generated in 0.01790 seconds
