Home » Eclipse Projects » GlassFish » [Java15] maven-embedded-glassfish-plugin with latest glassfish(Different questions around embedded glassfish)
[Java15] maven-embedded-glassfish-plugin with latest glassfish [message #1836905] Mon, 18 January 2021 07:12 Go to next message
Hello.
I tried to build my first Maven project using embedded glassfish server to provide a jax-ws webservice and static page.
My first problem at this time is that the glassfish server start and I have glassfish 404 page on localhost:8080/ and on localhost:8181/
You can find extra information of my project on https://github.com/BeRoots/WeathforcastWS2 and around the maven-embedded-glassfish-plugin on https://glassfish.org/docs/latest/embedded-server-guide.pdf#gjldy
If someone has an idea why my index.html not work and return a 404 ?
Thanks in advance
[Updated on: Mon, 18 January 2021 17:24] by Moderator
Re: [Java15] maven-embedded-glassfish-plugin with latest glassfish [message #1836926 is a reply to message #1836905] Mon, 18 January 2021 17:16 Go to previous message
My goal here is just create a parent project that is a standalone application with module like this one to improve my java skill.
So i don't think it's an "anti-pattern" in this case. In case someone think is better to use a managed glassfish instance or a docker.
[Updated on: Mon, 18 January 2021 17:31] by Moderator
Previous Topic:apache derby IJ ERROR: Unable to establish connection with glassfish5 on linux mint
Next Topic:CDI issue
Current Time: Thu Nov 06 05:23:33 EST 2025
Powered by FUDForum. Page generated in 0.03405 seconds
