Home » Newcomers » Newcomers » Sometimes outline view is not displayed correctly(Sometimes outline view is not displayed correctly)
Sometimes outline view is not displayed correctly [message #1836894] Mon, 18 January 2021 01:24
We've developed a custom outline (treeviewer outline). Sometimes this outline is not show correctly, all the text is missing only the triangles (collapse, expand) of the treeviewer are shown.
Reopening the editor does not solve the problem, the editor must be closed and our eclipse RCP application has to be restarted. The below exceptions are shown, can't find anything within issue tracker about the problem.
Kind regards,
Richard
java.lang.IllegalStateException: Invalid class loader from a refreshed bundle is being used: org.eclipse.ui.workbench_3.117.0.v20191126-1131
at org.eclipse.osgi.internal.loader.BundleLoader.getProviderLoader(BundleLoader.java:980)
at org.eclipse.osgi.internal.loader.BundleLoader.findRequiredSource(BundleLoader.java:1214)
at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:466)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:425)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:417)
at org.eclipse.osgi.internal.loader.ModuleClassLoader.loadClass(ModuleClassLoader.java:171)
at java.base/java.lang.ClassLoader.loadClass(ClassLoader.java:521)
at org.eclipse.ui.internal.WorkbenchPlugin.getDecoratorManager(WorkbenchPlugin.java:751)
Caused by: java.lang.ClassNotFoundException: org.eclipse.e4.core.contexts.IEclipseContext cannot be found by org.eclipse.ui.workbench_3.117.0.v20191126-1131
at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:514)
... 116 more
java.lang.NoClassDefFoundError: org/eclipse/e4/core/contexts/IEclipseContext
at org.eclipse.ui.internal.PlatformUIPreferenceListener.preferenceChange(PlatformUIPreferenceListener.java:59)
at org.eclipse.core.internal.preferences.EclipsePreferences$2.run(EclipsePreferences.java:851)
at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:45)
at org.eclipse.core.internal.preferences.EclipsePreferences.firePreferenceEvent(EclipsePreferences.java:854)
at org.eclipse.core.internal.preferences.EclipsePreferences.put(EclipsePreferences.java:866)
at org.eclipse.ui.preferences.ScopedPreferenceStore.setValue(ScopedPreferenceStore.java:608)
at org.eclipse.ui.internal.decorators.DecoratorManager.writeDecoratorsPreference(DecoratorManager.java:694)
at org.eclipse.ui.internal.decorators.DecoratorManager.updateForEnablementChange(DecoratorManager.java:647)
at org.eclipse.ui.internal.decorators.DecoratorManager.setEnabled(DecoratorManager.java:822)
at org.eclipse.team.svn.ui.SVNTeamUIPlugin.start(SVNTeamUIPlugin.java:144)
at org.eclipse.osgi.internal.framework.BundleContextImpl$3.run(BundleContextImpl.java:842)
at org.eclipse.osgi.internal.framework.BundleContextImpl$3.run(BundleContextImpl.java:1)
Previous Topic:Eclipse installation issues
Next Topic:Opening an XML file launches another copy of Eclipse
Current Time: Wed Sep 10 19:38:45 EDT 2025
Powered by FUDForum. Page generated in 0.07728 seconds
