Home » Newcomers » Newcomers » Opening an XML file launches another copy of Eclipse
Opening an XML file launches another copy of Eclipse [message #1836825] Thu, 14 January 2021 18:12 Go to next message
Ever since I upgraded from 2020-09 to the 2020-12 release, whenever I open an XML file, another copy of Eclipse is launched and fails with the "please choose another workspace as <this> is currently in use." Any ideas on where to look to solve this issue?
I used the "in place" upgrade to the new eclipse release, not a new install. I'm wondering if this had anything to do with it.
I'm running Eclipse on a MacBook Pro on OS X Catalina.
Re: Opening an XML file launches another copy of Eclipse [message #1836826 is a reply to message #1836825] Thu, 14 January 2021 21:00 Go to previous messageGo to next message
How, exactly, are you "opening a XML file"?
Re: Opening an XML file launches another copy of Eclipse [message #1836845 is a reply to message #1836826] Fri, 15 January 2021 09:04 Go to previous messageGo to next message
Nitin, thanks for responding.
I'm opening the XML file from within eclipse by double clicking the file in the Package Explorer tab. The XML file opens in a new editor in the current eclipse instance, the eclipse app loses focus, and a new instance of eclipse tries to open (splash screen, "please choose another workspace" dialog).
Re: Opening an XML file launches another copy of Eclipse [message #1836849 is a reply to message #1836845] Fri, 15 January 2021 10:10 Go to previous messageGo to next message
Well that's not supposed to happen. I've not run into this on macOS. Which editor is it opening in the current instance? Is there anything in the Error Log view when this occurs?
Re: Opening an XML file launches another copy of Eclipse [message #1836852 is a reply to message #1836849] Fri, 15 January 2021 10:45 Go to previous messageGo to next message
For pom.xml, it's opening the Maven Pom Editor. For a non-pom XML file, it opens the XML Editor.
There are quite a few entries in the Error Log that happen on eclipse startup, mostly having to do with Lombok (lombok/eclipse/handlers/EclipseHandlerUtil). No new errors are logged when I open the XML file.
Edit: I downloaded a fresh install of eclipse 2020-12, and the problem isn't occurring.
[Updated on: Fri, 15 January 2021 12:04] by Moderator
Re: Opening an XML file launches another copy of Eclipse [message #1836895 is a reply to message #1836852] Mon, 18 January 2021 02:10 Go to previous message
Seems it's been found as https://github.com/eclipse/wildwebdeveloper/issues/601.
[Updated on: Mon, 18 January 2021 02:10] by Moderator
Previous Topic:Sometimes outline view is not displayed correctly
Next Topic:Eclipse is damaged while installing RTC602
Current Time: Wed Nov 05 19:34:24 EST 2025
Powered by FUDForum. Page generated in 0.11968 seconds
