load model by using EMF API [message #1836676] |
Mon, 11 January 2021 17:15  |
Hello together,
excuse me, if I might lack of knowledge or skill, the topic is new and my coding is not the best.
Currently, I am on a project that deals with Test Description Language (TDL). For that I have wrote a Test Purpose and a Test Description which can be represented in XMI format (.tdlan2.tdl and .tplan2.tdl) as in Xtext (.tdlan2 and .tplan2). File names are TDExample. and TPExample.
The task I have struggle with is to load and navigate the model programmatically by using the EMF API. The following code is from the first section of https://wiki.eclipse.org./Xtext/FAQ.
package loadpackage;
import java.io.ByteArrayInputStream;
import java.io.InvalidObjectException;
import java.util.HashMap;
import org.eclipse.emf.mwe.utils.*;
import org.eclipse.emf.common.util.*;
import org.eclipse.emf.ecore.resource.Resource;
import org.eclipse.emf.ecore.EObject;
import org.eclipse.xtext.resource.XtextResource;
import org.eclipse.xtext.resource.XtextResourceSet;
//this import does not resolve
import org.xtext.example.mydsl.MyDslStandaloneSetup;
import com.google.inject.Injector;
public class alone {
public static void main (String [] args) {
new StandaloneSetup().setPlatformUri("../");
Injector injector = new MyDslStandaloneSetup().createInjectorAndDoEMFRegistration();
XtextResourceSet resourceSet = injector.getInstance(XtextResourceSet.class);
resourceSet.addLoadOption(XtextResource.OPTION_RESOLVE_ALL, Boolean.TRUE);
Resource resource = resourceSet.getResource(
URI.createURI("platform:/resource/org.xtext.example.mydsl/src/example.mydsl"), true);
Model model = (Model) resource.getContents().get(0);
For the last days I roamed through the forum, hunting down every clue I could find - without any productive results. For now it would be nice just to understand why the
"import org.text.example.mydsl.MyDslStanaloneSetup;" is not working. And if you have the time to spare, explaining what the code does and how it can work with the XMI and Xtext Model Representation.
I have not used Xtext so far, and furthermore, my supervisor has not provided any hints to use Xtext besides the FAQ.
Re: load model by using EMF API [message #1836681 is a reply to message #1836676] |
Tue, 12 January 2021 01:07  |
For questions specifically about Xtext it's best to use the TMF forum:
https://www.eclipse.org/forums/index.php/f/27/
I can't say, for example, what new StandaloneSetup().setPlatformUri("../"); is supposed to do. Maybe it's supposed to help make "platform:/resource" work, but I don't know how it would or does that.
In general, if an import doesn't resolve, you need to add the plugin/library with that class to the project's classpath. Assuming the project is a plugin, which definitely makes managing the classpath easier, you add another plugin to the classpath by editing the MANIFEST.MF and using the Dependencies to add dependencies.
FUDForum. Page generated in 0.30060 seconds
