Home » Modeling » Compare » AbstractChangeFactory.fillRequiredDifferences() may cause circular dependencies
AbstractChangeFactory.fillRequiredDifferences() may cause circular dependencies [message #1836325] Mon, 28 December 2020 21:41
Hello
I'm using EMF compare 3.5.3.202003070301 with custom macroscopic differences.
It seems to me that the execution of fillRequiredDifferencesForMacroToMacro() and fillRequiredDifferencesForUnitToMacro() by fillRequiredDifferences() is not necessary.
As of 507177 , refines/refinedBy are now merged together, so requires/requiredBy is no longer needed. However, since refines are handled by getDirectResultingMerges(), but requires/requiredBy are handled by getDirectMergeDependencies(), depending on the direction of the merge, a cycle of preconditions may occur if both of these are configured.
  • fillRequiredDifferencesForMacroToMacro()
    • extension.requires.addAll(extension.refinedBy.requires.refines)
    • extension.requiredBy.addAll(extension.refinedBy.requiredBy.refines)
  • fillRequiredDifferencesForUnitToMacro()
    • extension.requires.addAll(extension.refinedBy.requires)
    • extension.requiredBy.addAll(extension.refinedBy.requiredBy)
The two ends are different, but the overview is as above, and the pathways it adds are similar.
And these will be merged properly even if you don't add them, because the dependency when merging forward with AbstractMerger is as follows.
  • getDirectMergeDependencies(extension)'s result contains "refinedBy(extension.refinedBy)"
  • getDirectMergeDependencies(extension.refinedBy)'s result contains "requires(extension.refinedBy.requires)"
  • getDirectResultingMerges(extension.refinedBy.requires)'s result contains "refines(extension.refinedBy.requiredBy.refines)"
  • Merging "extension" will result in all paths up to "extension.requires.refines" being merged
  • If you use "extension.requiredBy.refines" as a starting point, all paths up to "extension" will be merged as well
Akira
Previous Topic:Crossover operation by EMF Compare
Next Topic:Load resources from revision control
Current Time: Sat Oct 25 13:45:01 EDT 2025
Powered by FUDForum. Page generated in 0.04533 seconds
