I installed eclipse on a virtual Fedora 33 using the following command:
Which installed this package
eclipse-jdt-1:4.17-4.fc33.noarch
When I try and run Eclipse from the desktop I get JVM terminated. Exit code=43
Interestingly after I close the pop up window and try to use Firefox my tab crashes. I have to restart my OS in order to use Firefox. I don't know where the log is kept so I can't copy and paste the entire error message here.
In the command terminal I typed this hoping that something useful can be used
Which attempts to run Eclipse (but fails) and returns this in the terminal
** (Eclipse:2994): CRITICAL **: 00:16:30.032: JNI class pointer is NULL for class org/eclipse/swt/accessibility/AccessibleObject
Exception in thread "Thread-0" java.lang.NoClassDefFoundError: org/eclipse/swt/accessibility/AccessibleObject
at org.eclipse.equinox.launcher.JNIBridge._takedown_splash(Native Method)
at org.eclipse.equinox.launcher.JNIBridge.takeDownSplash(JNIBridge.java:173)
at org.eclipse.equinox.launcher.Main.takeDownSplash(Main.java:2186)
at org.eclipse.equinox.launcher.Main$SplashHandler.run(Main.java:122)
Caused by: java.lang.ClassNotFoundException: org.eclipse.swt.accessibility.AccessibleObject
at java.base/jdk.internal.loader.BuiltinClassLoader.loadClass(BuiltinClassLoader.java:581)
at java.base/jdk.internal.loader.ClassLoaders$AppClassLoader.loadClass(ClassLoaders.java:178)
at java.base/java.lang.ClassLoader.loadClass(ClassLoader.java:522)
... 4 more
Please advise how to use Eclipse.
