| Feasibility of caching ThemeAdapter computations? [message #1835608] |
Tue, 08 December 2020 12:29  |
Recently I've found some time to profile a large RAP based application which I've always found to be slow (large UI, ~1.5s server response time) . The application is a bit layout-heavy, it triggers quite a few re-layouts - however what I found intriguing is that the profiler didn't report the time in the layout functions itself as a problem.
According to my profile, a lot of time (>50%) is spent in million calls to WidgetMatcher.select/matches - which are called by the ThemeAdapters which are in turn called often multiple times by almost all sizing-related stuff.
The codepaths don't seem to be problematic themself, however it seems all those small inefficiencies each call add up:
- many repeated calls to checkWidget(), which invokes currentThread() each time
- access custom CSS classes via Widget.getData (causing another checkWidget) with short (or longer) running loop to compare keys
- Lookup in the ConcurrentHashMap
The code-path itsel looks well optimized, however it is quite a bit of complex (for the JVM) code which can be called frequently - and all the code does in most cases* is to loop up a few constants. (most Constraints seem to actially be StyleConstraints and VariantConstraints and very little ThemeAdapter-Classes seem to implement their own constraints (Toolbar seems to be one of the exceptions).
What I wonder: have there ever been plans / discussions to implement some kind of caching for the ThemeAdapter return values? What are the reasons why this hasn't been implemented.
Would the following idea be possible to implement: For Widgets where ThemeAdapters do not have custom Constraint implementations simply cache the return value and clear cache in case setData(CUSTOM_VARIANT is called.
So instead of a SingleTon, getThemeAdapter() could return a per-Widget ThemeAdapter, which could return cached values at subsequent invocations until a cache-invalidating event occurs (css variant chance, what else could cause this?).
With the approach the cache could be even made optional - depending on a config setting a caching or non-caching ThemeAdapter could be installed, depending on what is more important - working set size of throughput performance.
Feedback is highly appreciated.
Thank you in advance, Clemens
[Updated on: Thu, 10 December 2020 02:39] by Moderator
| Re: Feasibility of caching ThemeAdapter computations? [message #1836542 is a reply to message #1835608] |
Thu, 07 January 2021 03:50  |
we are caching some performance "critical" values on widget bases - for example Tree/Table. See Tree#LayoutCache internal class. Using caching is always tricky, because you always deal with outdated values. Doing this globally is a lot of effort and hard to maintain. If you have some suggestion please open an enhancement request and create some Gerrit changes with proposed solution.
Ivan
FUDForum. Page generated in 0.03819 seconds
