IllegalStateException, unknown connection on second transaction in request on JBoss EAP 7.3 server [message #1835584] |
Mon, 07 December 2020 11:13  |
We migrated our JEE application from JBoss EAP 6.4 to 7.3.3, and saw that the below exceptions starting appearing. These exceptions only occur for requests where we have database requests with two consecutive transactions in a single web request.
Moving all requests to one transaction makes the issue disappear. The issue also disappears when we use Hibernate instead of EclipseLink as JPA implementation.
The database we use is Oracle 12 and 19. The eclipselink version we use is 2.7.7.
Apart from this stacktrace the application seems to function correctly.
I have added a stacktrace to the method that executes the (second) transaction.
Does anybody know what is happening here? How serious should we take this exception?
03122020 02:19:31,342 INFO [org.jboss.jca.core.connectionmanager.listener.TxConnectionListener] (default task-1) IJ000311: Throwable from unregister connection: java.lang.IllegalStateException: IJ000152: Trying to return an unknown connection: org.jboss.jca.adapters.jdbc.jdk8.WrappedConnectionJDK8@2cb1594b
at org.jboss.ironjacamar.impl@1.4.22.Final-redhat-00001//org.jboss.jca.core.connectionmanager.ccm.CachedConnectionManagerImpl.unregisterConnection(CachedConnectionManagerImpl.java:408)
at org.jboss.ironjacamar.impl@1.4.22.Final-redhat-00001//org.jboss.jca.core.connectionmanager.listener.TxConnectionListener.connectionClosed(TxConnectionListener.java:645)
at org.jboss.ironjacamar.jdbcadapters@1.4.22.Final-redhat-00001//org.jboss.jca.adapters.jdbc.BaseWrapperManagedConnection.returnHandle(BaseWrapperManagedConnection.java:600)
at org.jboss.ironjacamar.jdbcadapters@1.4.22.Final-redhat-00001//org.jboss.jca.adapters.jdbc.BaseWrapperManagedConnection.closeHandle(BaseWrapperManagedConnection.java:545)
at org.jboss.ironjacamar.jdbcadapters@1.4.22.Final-redhat-00001//org.jboss.jca.adapters.jdbc.WrappedConnection.returnConnection(WrappedConnection.java:307)
at org.jboss.ironjacamar.jdbcadapters@1.4.22.Final-redhat-00001//org.jboss.jca.adapters.jdbc.WrappedConnection.close(WrappedConnection.java:265)
at deployment.kharon-rest.war//org.eclipse.persistence.internal.databaseaccess.DatabaseAccessor.closeDatasourceConnection(DatabaseAccessor.java:502)
at deployment.kharon-rest.war//org.eclipse.persistence.internal.databaseaccess.DatasourceAccessor.closeConnection(DatasourceAccessor.java:524)
at deployment.kharon-rest.war//org.eclipse.persistence.internal.databaseaccess.DatabaseAccessor.closeConnection(DatabaseAccessor.java:527)
at deployment.kharon-rest.war//org.eclipse.persistence.internal.databaseaccess.DatasourceAccessor.closeJTSConnection(DatasourceAccessor.java:190)
at deployment.kharon-rest.war//org.eclipse.persistence.sessions.server.ClientSession.releaseJTSConnection(ClientSession.java:175)
at deployment.kharon-rest.war//org.eclipse.persistence.transaction.AbstractSynchronizationListener.beforeCompletion(AbstractSynchronizationListener.java:177)
at deployment.kharon-rest.war//org.eclipse.persistence.transaction.JTASynchronizationListener.beforeCompletion(JTASynchronizationListener.java:70)
at org.wildfly.transaction.client@1.1.13.Final-redhat-00001//org.wildfly.transaction.client.AbstractTransaction.performConsumer(AbstractTransaction.java:236)
at org.wildfly.transaction.client@1.1.13.Final-redhat-00001//org.wildfly.transaction.client.AbstractTransaction.performConsumer(AbstractTransaction.java:247)
at org.wildfly.transaction.client@1.1.13.Final-redhat-00001//org.wildfly.transaction.client.AbstractTransaction$AssociatingSynchronization.beforeCompletion(AbstractTransaction.java:292)
at org.jboss.jts//com.arjuna.ats.internal.jta.resources.arjunacore.SynchronizationImple.beforeCompletion(SynchronizationImple.java:76)
at org.jboss.jts//com.arjuna.ats.arjuna.coordinator.TwoPhaseCoordinator.beforeCompletion(TwoPhaseCoordinator.java:360)
at org.jboss.jts//com.arjuna.ats.arjuna.coordinator.TwoPhaseCoordinator.end(TwoPhaseCoordinator.java:91)
at org.jboss.jts//com.arjuna.ats.arjuna.AtomicAction.commit(AtomicAction.java:162)
at org.jboss.jts//com.arjuna.ats.internal.jta.transaction.arjunacore.TransactionImple.commitAndDisassociate(TransactionImple.java:1287)
at org.jboss.jts//com.arjuna.ats.internal.jta.transaction.arjunacore.BaseTransaction.commit(BaseTransaction.java:126)
at org.jboss.jts.integration//com.arjuna.ats.jbossatx.BaseTransactionManagerDelegate.commit(BaseTransactionManagerDelegate.java:94)
at org.wildfly.transaction.client@1.1.13.Final-redhat-00001//org.wildfly.transaction.client.LocalTransaction.commitAndDissociate(LocalTransaction.java:78)
at org.wildfly.transaction.client@1.1.13.Final-redhat-00001//org.wildfly.transaction.client.ContextTransactionManager.commit(ContextTransactionManager.java:71)
at org.jboss.as.ejb3@7.3.3.GA-redhat-00004//org.jboss.as.ejb3.tx.CMTTxInterceptor.endTransaction(CMTTxInterceptor.java:89)
at org.jboss.as.ejb3@7.3.3.GA-redhat-00004//org.jboss.as.ejb3.tx.CMTTxInterceptor.invokeInOurTx(CMTTxInterceptor.java:280)
at org.jboss.as.ejb3@7.3.3.GA-redhat-00004//org.jboss.as.ejb3.tx.CMTTxInterceptor.required(CMTTxInterceptor.java:386)
at org.jboss.as.ejb3@7.3.3.GA-redhat-00004//org.jboss.as.ejb3.tx.CMTTxInterceptor.processInvocation(CMTTxInterceptor.java:156)
at org.jboss.invocation@1.5.3.Final-redhat-00001//org.jboss.invocation.InterceptorContext.proceed(InterceptorContext.java:422)
at org.jboss.invocation@1.5.3.Final-redhat-00001//org.jboss.invocation.InterceptorContext$Invocation.proceed(InterceptorContext.java:509)
at org.jboss.weld.core@3.1.4.Final-redhat-00001//org.jboss.weld.module.ejb.AbstractEJBRequestScopeActivationInterceptor.aroundInvoke(AbstractEJBRequestScopeActivationInterceptor.java:72)
at org.jboss.as.weld.common@7.3.3.GA-redhat-00004//org.jboss.as.weld.ejb.EjbRequestScopeActivationInterceptor.processInvocation(EjbRequestScopeActivationInterceptor.java:89)
at org.jboss.as.ejb3@7.3.3.GA-redhat-00004//org.jboss.as.ejb3.component.interceptors.CurrentInvocationContextInterceptor.processInvocation(CurrentInvocationContextInterceptor.java:41)
at org.jboss.as.ejb3@7.3.3.GA-redhat-00004//org.jboss.as.ejb3.component.invocationmetrics.WaitTimeInterceptor.processInvocation(WaitTimeInterceptor.java:47)
at org.jboss.as.ejb3@7.3.3.GA-redhat-00004//org.jboss.as.ejb3.security.SecurityContextInterceptor.processInvocation(SecurityContextInterceptor.java:100)
at org.jboss.as.ejb3@7.3.3.GA-redhat-00004//org.jboss.as.ejb3.deployment.processors.StartupAwaitInterceptor.processInvocation(StartupAwaitInterceptor.java:22)
at org.jboss.as.ejb3@7.3.3.GA-redhat-00004//org.jboss.as.ejb3.component.singleton.ContainerManagedConcurrencyInterceptor.processInvocation(ContainerManagedConcurrencyInterceptor.java:106)
at org.jboss.as.ejb3@7.3.3.GA-redhat-00004//org.jboss.as.ejb3.component.interceptors.ShutDownInterceptorFactory$1.processInvocation(ShutDownInterceptorFactory.java:64)
at org.jboss.as.ejb3@7.3.3.GA-redhat-00004//org.jboss.as.ejb3.component.interceptors.LoggingInterceptor.processInvocation(LoggingInterceptor.java:67)
at org.jboss.as.ee@7.3.3.GA-redhat-00004//org.jboss.as.ee.component.NamespaceContextInterceptor.processInvocation(NamespaceContextInterceptor.java:50)
at org.jboss.invocation@1.5.3.Final-redhat-00001//org.jboss.invocation.ContextClassLoaderInterceptor.processInvocation(ContextClassLoaderInterceptor.java:60)
at org.jboss.invocation@1.5.3.Final-redhat-00001//org.jboss.invocation.InterceptorContext.run(InterceptorContext.java:438)
at org.wildfly.security.elytron-private@1.10.8.Final-redhat-00001//org.wildfly.security.manager.WildFlySecurityManager.doChecked(WildFlySecurityManager.java:628)
at org.jboss.invocation@1.5.3.Final-redhat-00001//org.jboss.invocation.AccessCheckingInterceptor.processInvocation(AccessCheckingInterceptor.java:57)
at org.jboss.invocation@1.5.3.Final-redhat-00001//org.jboss.invocation.ChainedInterceptor.processInvocation(ChainedInterceptor.java:53)
at org.jboss.as.ee@7.3.3.GA-redhat-00004//org.jboss.as.ee.component.ViewService$View.invoke(ViewService.java:198)
at org.jboss.as.ee@7.3.3.GA-redhat-00004//org.jboss.as.ee.component.ViewDescription$1.processInvocation(ViewDescription.java:191)
at org.jboss.as.ee@7.3.3.GA-redhat-00004//org.jboss.as.ee.component.ProxyInvocationHandler.invoke(ProxyInvocationHandler.java:81)
at deployment.kharon-rest.war//com.example.services.dao.interfaces.UserDao$$$view4.getAccesStrings(Unknown Source)
FUDForum. Page generated in 0.12352 seconds
