Eclipse at startup "An Error has occured. See the log file /home.../.metadata/.log". [message #1835428] |
Thu, 03 December 2020 08:33 |
Nico van de Kamp Messages: 13 Registered: April 2013 |
I want to start working in Eclipse and I can choose the workspace environment and than short after this I get the error which I have paste here below.
I doesn't make any difference if I choose an another workspace.
I get the same error, if I choose an another existing workspace, but than another .metadata/.log file.
If I create a new workspace than also this error.
I've been working yesterday with Eclipse without any issue and/or problem
I'm working in Eclipse 2020-09 from the foundation. The OS is Fedora version 33.
Can somenone help me out what todo and how can I solve this?
.metadata/.log file content from this morning:
Quote:!SESSION 2020-12-03 08:39:01.327 -----------------------------------------------
eclipse.buildId=4.17.0.v20200914-0420
java.version=11.0.9.1
java.vendor=Red Hat, Inc.
BootLoader constants: OS=linux, ARCH=x86_64, WS=gtk, NL=nl_NL
Command-line arguments: -os linux -ws gtk -arch x86_64
!ENTRY org.eclipse.ecf.provider.filetransfer.ssl 2 0 2020-12-03 08:39:12.255
!MESSAGE Could not resolve module: org.eclipse.ecf.provider.filetransfer.ssl [913]
Unresolved requirement: Fragment-Host: org.eclipse.ecf.provider.filetransfer; bundle-version="2.0.0"
!ENTRY org.eclipse.ecf.ssl 2 0 2020-12-03 08:39:12.256
!MESSAGE Could not resolve module: org.eclipse.ecf.ssl [914]
!ENTRY org.eclipse.osgi.compatibility.state 2 0 2020-12-03 08:39:12.256
!MESSAGE Could not resolve module: org.eclipse.osgi.compatibility.state [930]
Unresolved requirement: Fragment-Host: org.eclipse.osgi; bundle-version="3.12.0"
!ENTRY org.eclipse.osgi 4 0 2020-12-03 08:39:12.256
!MESSAGE Application error
!STACK 1
org.eclipse.e4.ui.css.core.sac.ParserNotFoundException: java.lang.ClassCastException: class org.apache.batik.css.parser.Parser cannot be cast to class org.w3c.css.sac.Parser (org.apache.batik.css.parser.Parser is in unnamed module of loader org.eclipse.osgi.internal.loader.EquinoxClassLoader @28554ac8; org.w3c.css.sac.Parser is in unnamed module of loader org.eclipse.osgi.internal.loader.EquinoxClassLoader @4bcdd11)
at org.eclipse.e4.ui.css.core.impl.dom.parsers.AbstractCSSParser.getParser(AbstractCSSParser.java:152)
at org.eclipse.e4.ui.css.core.impl.dom.parsers.AbstractCSSParser.parseStyleSheet(AbstractCSSParser.java:61)
at org.eclipse.e4.ui.css.core.impl.engine.AbstractCSSEngine.parseStyleSheet(AbstractCSSEngine.java:192)
at org.eclipse.e4.ui.css.swt.internal.theme.ThemeEngine.setTheme(ThemeEngine.java:445)
at org.eclipse.e4.ui.css.swt.internal.theme.ThemeEngine.setTheme(ThemeEngine.java:406)
at org.eclipse.e4.ui.css.swt.internal.theme.ThemeEngine.setTheme(ThemeEngine.java:398)
at org.eclipse.e4.ui.css.swt.internal.theme.ThemeEngine.restore(ThemeEngine.java:594)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.setCSSTheme(PartRenderingEngine.java:1419)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.initializeStyling(PartRenderingEngine.java:1326)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$5.run(PartRenderingEngine.java:1050)
at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:338)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:1046)
at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:155)
at org.eclipse.ui.internal.Workbench.lambda$3(Workbench.java:644)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:551)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:153)
at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:150)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:401)
at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
at java.base/jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.base/java.lang.reflect.Method.invoke(Method.java:566)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:669)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:606)
at org.eclipse.equinox.launcher.Main.run(Main.java:1477)
at org.eclipse.equinox.launcher.Main.main(Main.java:1450)
Caused by: java.lang.ClassCastException: class org.apache.batik.css.parser.Parser cannot be cast to class org.w3c.css.sac.Parser (org.apache.batik.css.parser.Parser is in unnamed module of loader org.eclipse.osgi.internal.loader.EquinoxClassLoader @28554ac8; org.w3c.css.sac.Parser is in unnamed module of loader org.eclipse.osgi.internal.loader.EquinoxClassLoader @4bcdd11)
at org.eclipse.e4.ui.css.core.impl.sac.SACParserFactoryImpl.makeParser(SACParserFactoryImpl.java:52)
at org.eclipse.e4.ui.css.core.sac.SACParserFactory.makeParser(SACParserFactory.java:39)
at org.eclipse.e4.ui.css.core.impl.dom.parsers.AbstractCSSParser.getParser(AbstractCSSParser.java:142)
... 30 more
!SESSION 2020-12-03 08:39:25.494 -----------------------------------------------
!ENTRY org.eclipse.ecf.ssl 2 0 2020-12-03 08:39:39.749
!ENTRY org.eclipse.ecf.provider.filetransfer.ssl 2 0 2020-12-03 08:39:39.751
!ENTRY org.eclipse.osgi.compatibility.state 2 0 2020-12-03 08:39:39.751
!ENTRY org.eclipse.osgi 4 0 2020-12-03 08:39:39.752
!STACK 1
org.eclipse.e4.ui.css.core.sac.ParserNotFoundException: java.lang.ClassCastException: class org.apache.batik.css.parser.Parser cannot be cast to class org.w3c.css.sac.Parser (org.apache.batik.css.parser.Parser is in unnamed module of loader org.eclipse.osgi.internal.loader.EquinoxClassLoader @1f949ab9; org.w3c.css.sac.Parser is in unnamed module of loader org.eclipse.osgi.internal.loader.EquinoxClassLoader @1c62c3fd)
Caused by: java.lang.ClassCastException: class org.apache.batik.css.parser.Parser cannot be cast to class org.w3c.css.sac.Parser (org.apache.batik.css.parser.Parser is in unnamed module of loader org.eclipse.osgi.internal.loader.EquinoxClassLoader @1f949ab9; org.w3c.css.sac.Parser is in unnamed module of loader org.eclipse.osgi.internal.loader.EquinoxClassLoader @1c62c3fd)
... 30 more
[nkamp_admin@localhost .metadata]$
FUDForum. Page generated in 0.08912 seconds
