Home » Eclipse Projects » Eclipse Titan » OpenApi 3 support
OpenApi 3 support [message #1834552] Thu, 12 November 2020 05:16
OpenAPI Specification (formerly Swagger Specification) is an API description format for REST APIs. An OpenAPI file allows you to describe your entire API, including:
    Available endpoints (/users) and operations on each endpoint (GET /users, POST /users)
    Operation parameters Input and output for each operation
    Authentication methods
    Contact information, license, terms of use and other information.
More information:
https://swagger.io/docs/specification/about/
https://github.com/OAI/OpenAPI-Specification/blob/master/versions/3.0.2.md
The OpenAPI 3 data types are based on an extended subset JSON Schema Specification. As the TITAN natively supports JSON encoding the OpenAPI data types can be represented in TTCN-3.
OpenAPI 3 <-> TTCN-3 type mapping
integer
The OpenAPI integer type is mapped to TTCN-3 integer. The range restrictions are mapped to the TTCN-3 range restrictions. The format specifier can be ignored during the mapping.
Example:
components:
  schemas:
    Uint16:
      type: integer
      minimum: 0
      maximum: 65535
    Int32:
      format: int32
      type: integer
The TTCN-3 type definitions
  type integer Uint16   (0..65535)
  type integer Int32
string
The OpenAPI string type is mapped to TTCN-3 charstring or universal charstring. The format specifier can be ignored during the mapping. The pattern can be mapped to TTCN-3 pattern restriction.
Example:
components:
  schemas:
    Date:
      format: date
      type: string
    DiameterIdentity:
      type: string
      pattern: '^([A-Za-z0-9]+([-A-Za-z0-9]+)\.)+[a-z]{2,}$'
  type charstring Date
  type charstring DiameterIdentity // pattern "([A-Za-z0-9]+([-A-Za-z0-9]+)\.)+[a-z]{2,}"
boolean
The OpenAPI boolean type is mapped to TTCN-3 boolean.
Example:
components:
  schemas:
    BoolT:
      type: boolean
  type boolean BoolT
array
The OpenAPI array type is mapped to TTCN-3 record of. The length restriction properties minItems and maxItems can be mapped to the TTCN-3 length restriction
Example:
components:
  schemas:
    ArrayT:
      type: array
      items:
        type: integer
      minItems: 1
      maxItems: 10
  type reocrd of integer ArrayT length(1..10)
Any Type
A schema without a type matches any data type is mapped to JSON_generic_val which can represent any kind of JSON value.
Example:
components:
  schemas:
    AnyValue: {}
  type JSON_Generic.JSON_generic_val AnyValue
enum
The OpenAPI string types enum type is mapped to TTCN-3 enumerated.
Example:
components:
  schemas:
    Color:
      type: string
      enum:
        - black
        - white
        - red
  type enumarated Color {black, white, red}
object
The OpenAPI object type is mapped to TTCN-3 set. The elements listed under the properties are the fields of the set. The fields are optional except the ones are present on the required list.
Example:
components:
  schemas:
    Property:
      type: object
      required:
        - name
      properties:
        name:
          type: string
        required:
          type: boolean
        regex:
          type: string
        value:
          type: string
  type set Property  {
    charstring  name,
    boolean  required optional,
    charstring  regex optional,
    charstring  value_ optional
  } with {
    variant (value_) "name as 'value'"
Please note as the value is a keyword in TTCN-3, it can't be used as field name.
Dictionaries, HashMaps and Associative Arrays
In OpenApi to define a dictionary, use type: object and use the additionalProperties keyword to specify the type of values in key/value pairs. The OpenAPI dictionary type is mapped to TTCN-3 set of record.
Example:
components:
  schemas:
    DictT:
      type: object
      additionalProperties:
        type: string
  type set of record  {
    universal charstring  key,
    charstring  additionalProperties optional
  } DictT
  with {
    variant "as map"
Please note dictionary with a fixed keys are not supported. It should be handled as normal dictionary.
oneOf
The OpenAPI oneOf is mapped to TTCN-3 union. The union members are the alternative schemas. Because the union field names are not used during the encoding, they can be named freely.
Example:
components:
  schemas:
    OneOfT:
      oneOf:
        - integer
        - boolean
  type union OneOfT  {
    integer  field1,
    boolean  field2
  } with {
    variant "JSON: as value"
allOf
The OpenAPI allOf is mapped to TTCN-3 set. The mapping is the same as the mapping of object, just the list of the properties are merged.
anyOf
The OpenAPI anyOf is mapped to TTCN-3 set. The mapping is the same as the mapping of object, just the list of the properties are merged. Please note this mapping can't validate the received data correctly.
nullable
The nullable properties modifies the mapping of the schema. The schema is mapped to special TTCN-3 union. The type of the schema is mapped to one of the union member. The other member of the union represents the null value.
Example:
components:
  schemas:
    NidRm:
      type: string
      nullable: true
  type union NidRm  {
    JSON_generic_val.JSON_null_val  null_val,
    charstring  val
  } with {
discriminator
The mapping of the discriminator is not supported.
Previous Topic:Unexpected behavior of port.halt?
Next Topic:OpenApi 3 support- generator script
Current Time: Mon Nov 03 10:23:28 EST 2025
Powered by FUDForum. Page generated in 0.03425 seconds
