Re: Eclipse 2020-09 (for Java) XML Editor shows new errors which were not there before. What to do? [message #1834541 is a reply to message #1834529] |
Thu, 12 November 2020 02:14   |
Ed Willink wrote on Wed, 11 November 2020 20:00Hi
If I'm using an XML editor, I expect to be told about rubbish XML by default. Perhaps an editing option facilitates various dimensions of rubbish.
If I want to edit rubbish XML, I use NotePad / a Text editor.
Ed Willink
Hellow!
Notepad does not highlight XML syntax or show XML structure errors, so I consider your advice to be useless!
Arbitrary fields with correct syntax in XML are not a bug, this is normal and was fine until the last Eclipse update. As I wrote above, even "Validate" does not see an error here, this "error" is shown only by the XML editor. If "Validate" showed an error, then it would be another matter, but this is a bug.
I ask you to tell me how I can remove this error, maybe I can change something in the configuration of the Eclipse itself or the Xml editor?
Re: Eclipse 2020-09 (for Java) XML Editor shows new errors which were not there before. What to do? [message #1834545 is a reply to message #1834542] |
Thu, 12 November 2020 03:42  |
Eitan Rosenberg wrote on Thu, 12 November 2020 07:40Hi there,
I have Version: 2020-09 (4.17.0).
There are some settings that might do the job (I did not test it.)
Regards.
I turned off all these errors altogether - and none of them worked. As I said above, these are settings for "Validate" and it worked without error before. I even turned off "Validate" for verification, but in the XML Editor the error is still shown!
The error is only in XML Editor and these settings do not affect it!
[Updated on: Thu, 12 November 2020 03:42] by Moderator
FUDForum. Page generated in 0.21624 seconds
