Re: Eclipse wont install [message #1834162 is a reply to message #1834155] |
Wed, 04 November 2020 04:47 |
Ed Merks Messages: 33142 Registered: July 2009 |
The error suggests that your bundle pool is corrupted, either because a corrupt artifact was downloaded or your virus scanner block the moving of that file after it was downloaded.
Please refer to this page for how to repair the pool:
https://www.eclipse.org/setups/installer/question/
In particular this:
Use the eclipse installer's Bundle Pools... menu item to manage where this pool is physically located on disk; this location can become large. The Bundle Pool Management dialog supports garbage collecting of unused artifacts, i.e., if you delete an installation, the artifacts it uses can potentially be removed from disk. In addition, if some artifact becomes corrupted, or if a corrupted artifact is downloaded from some mirror site, this dialog can be used to detect the damage and to repair it.
Ed Merks
FUDForum. Page generated in 0.08880 seconds
