Re: Upload my own odesign file to Sirius Web [message #1833946 is a reply to message #1833945] |
Wed, 28 October 2020 15:45 |
From the look of the stack posted by Alejandro, it seems the the odesign file defines a conditional style which does not specify a predicate expression.
The code should be more robust to this, I'll open a ticket.
In the meantime, you should be able to workaround it by making sure all conditional styles have a predicate, even if it is just "aql:true"
Pierre-Charles
Pierre-Charles David - Obeo
Re: Upload my own odesign file to Sirius Web [message #1836945 is a reply to message #1833946] |
Tue, 19 January 2021 15:22 |
mike hill Messages: 13 Registered: December 2020 |
This is the instruction for Sirius Desktop compatibility:
1. Make sure the JAR which contains the modeler definition is in your application's classpath. Typically this involves publishing the .design JAR in a Maven repository and adding its coordinates into your sample application's POM file. Example in Sirius Web.
2. In your application, provide a Spring @Configuration which implements org.eclipse.sirius.web.compat.services.api.ISiriusConfiguration and tells the platform the path (inside the JAR) where the .odesign file is available. Example in Sirius Web
This is probably a newbie question, but how do I publish my .design into a Maven repository with Obeo Designer?
[Updated on: Tue, 19 January 2021 16:05] Report message to a moderator
FUDForum. Page generated in 0.03494 seconds
