Home » Newcomers » Newcomers » Eclipse hangs on boot(Eclipse hangs on boot)
Eclipse hangs on boot [message #1833760] |
Fri, 23 October 2020 11:32 |
Bernd Dot Messages: 1 Registered: October 2020 |
I am using Eclipse for ages and it worked very relaible. But today it stucks on can see the UI with some UI failures but can't click anything in the window. The only thing I can do is force close it.
I did a reboot of my windows machine, I reinstalled Eclipse (but keeping the settings), nothing helped,
Here is the log:
!SESSION 2020-10-23 13:19:26.038 -----------------------------------------------
eclipse.buildId=4.17.0.I20200902-1800
java.version=12.0.1
BootLoader constants: OS=win32, ARCH=x86_64, WS=win32, NL=de_DE
Framework arguments: -product org.eclipse.epp.package.java.product
Command-line arguments: -os win32 -ws win32 -arch x86_64 -product org.eclipse.epp.package.java.product -consolelog
!ENTRY org.eclipse.equinox.simpleconfigurator 4 0 2020-10-23 13:19:26.454
!MESSAGE FrameworkEvent ERROR
!STACK 0
org.osgi.framework.BundleException: Exception in org.eclipse.equinox.internal.simpleconfigurator.Activator.start() of bundle org.eclipse.equinox.simpleconfigurator.
at org.eclipse.osgi.internal.framework.BundleContextImpl.startActivator(BundleContextImpl.java:863)
at org.eclipse.osgi.internal.framework.BundleContextImpl.start(BundleContextImpl.java:791)
at org.eclipse.osgi.internal.framework.EquinoxBundle.startWorker0(EquinoxBundle.java:1015)
at org.eclipse.osgi.internal.framework.EquinoxBundle$EquinoxModule.startWorker(EquinoxBundle.java:365)
at org.eclipse.osgi.container.Module.doStart(Module.java:603)
at org.eclipse.osgi.container.Module.start(Module.java:467)
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel$2.run(ModuleContainer.java:1844)
at org.eclipse.osgi.internal.framework.EquinoxContainerAdaptor$1$1.execute(EquinoxContainerAdaptor.java:136)
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1837)
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1780)
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.doContainerStartLevel(ModuleContainer.java:1742)
at org.eclipse.osgi.container.SystemModule.startWorker(SystemModule.java:269)
at org.eclipse.osgi.container.SystemModule.start(SystemModule.java:193)
at org.eclipse.osgi.internal.framework.EquinoxBundle.start(EquinoxBundle.java:439)
at org.eclipse.osgi.internal.framework.EquinoxBundle.start(EquinoxBundle.java:458)
at org.eclipse.osgi.launch.Equinox.start(Equinox.java:120)
at org.eclipse.core.runtime.adaptor.EclipseStarter.startup(EclipseStarter.java:338)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:251)
at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
at java.base/jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.base/java.lang.reflect.Method.invoke(Method.java:567)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:657)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:594)
at org.eclipse.equinox.launcher.Main.run(Main.java:1447)
Caused by: java.lang.IllegalStateException: The System Bundle was updated. The framework must be restarted to finalize the configuration change
at org.eclipse.equinox.internal.simpleconfigurator.ConfigApplier.install(ConfigApplier.java:79)
at org.eclipse.equinox.internal.simpleconfigurator.SimpleConfiguratorImpl.applyConfiguration(SimpleConfiguratorImpl.java:189)
at org.eclipse.equinox.internal.simpleconfigurator.SimpleConfiguratorImpl.applyConfiguration(SimpleConfiguratorImpl.java:204)
at org.eclipse.equinox.internal.simpleconfigurator.Activator.start(Activator.java:64)
at org.eclipse.osgi.internal.framework.BundleContextImpl$3.run(BundleContextImpl.java:842)
at org.eclipse.osgi.internal.framework.BundleContextImpl$3.run(BundleContextImpl.java:1)
at java.base/java.security.AccessController.doPrivileged(AccessController.java:551)
at org.eclipse.osgi.internal.framework.BundleContextImpl.startActivator(BundleContextImpl.java:834)
... 26 more
Root exception:
!ENTRY org.eclipse.oomph.setup.ui.questionnaire 4 0 2020-10-23 13:19:26.495
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.oomph.setup.ui.questionnaire [363]
Another singleton bundle selected: osgi.identity; type="osgi.bundle"; version:Version="1.11.0.v20200407-0508"; osgi.identity="org.eclipse.oomph.setup.ui.questionnaire"; singleton:="true"
at org.eclipse.osgi.container.Module.start(Module.java:462)
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1778)
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1664)
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1)
at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:234)
at org.eclipse.osgi.framework.eventmgr.EventManager$EventThread.run(EventManager.java:345)
!ENTRY org.eclipse.jst.ws.axis2.consumption.core 4 0 2020-10-23 13:19:26.512
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.jst.ws.axis2.consumption.core [704]
Unresolved requirement: Require-Bundle: org.eclipse.wst.ws
-> Bundle-SymbolicName: org.eclipse.wst.ws; bundle-version="1.1.500.v201910301957"; singleton:="true"
org.eclipse.wst.ws [2081]
Unresolved requirement: Require-Bundle: org.eclipse.wst.common.uriresolver; bundle-version="[1.1.301,1.3.0)"
Unresolved requirement: Require-Bundle: org.eclipse.jst.ws.consumption
-> Bundle-SymbolicName: org.eclipse.jst.ws.consumption; bundle-version="1.0.1400.v201910301957"; singleton:="true"
org.eclipse.jst.ws.consumption [1898]
Unresolved requirement: Require-Bundle: org.eclipse.wst.ws; bundle-version="[1.0.100,1.2.0)"
Unresolved requirement: Require-Bundle: org.eclipse.jst.ws; bundle-version="[1.0.101,1.1.0)"
-> Bundle-SymbolicName: org.eclipse.jst.ws; bundle-version="1.0.900.v201910301957"
org.eclipse.jst.ws [1894]
Unresolved requirement: Require-Bundle: org.eclipse.jst.ws.consumption.ui
-> Bundle-SymbolicName: org.eclipse.jst.ws.consumption.ui; bundle-version="1.1.1000.v201910301957"; singleton:="true"
org.eclipse.jst.ws.consumption.ui [1899]
Unresolved requirement: Require-Bundle: org.eclipse.wst.ws.explorer; bundle-version="[1.0.101,1.1.0)"
-> Bundle-SymbolicName: org.eclipse.wst.ws.explorer; bundle-version="1.0.1000.v201910301957"; singleton:="true"
org.eclipse.wst.ws.explorer [2082]
Unresolved requirement: Require-Bundle: org.eclipse.jst.ws.ui
-> Bundle-SymbolicName: org.eclipse.jst.ws.ui; bundle-version="1.1.0.v201910301957"; singleton:="true"
org.eclipse.jst.ws.ui [1907]
Unresolved requirement: Require-Bundle: org.eclipse.wst.ws.explorer; bundle-version="[1.0.204,1.1.0)"
!ENTRY org.eclipse.jst.ws.axis2.consumption.ui 4 0 2020-10-23 13:19:26.520
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.jst.ws.axis2.consumption.ui [705]
!ENTRY org.eclipse.jst.ws.axis2.core 4 0 2020-10-23 13:19:26.527
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.jst.ws.axis2.core [706]
!ENTRY org.eclipse.jst.ws.axis2.creation.core 4 0 2020-10-23 13:19:26.536
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.jst.ws.axis2.creation.core [707]
Unresolved requirement: Require-Bundle: org.eclipse.jst.ws.axis2.consumption.core
-> Bundle-SymbolicName: org.eclipse.jst.ws.axis2.consumption.core; bundle-version="1.0.200.v201903050508"
Unresolved requirement: Require-Bundle: org.eclipse.jst.ws.axis2.core
-> Bundle-SymbolicName: org.eclipse.jst.ws.axis2.core; bundle-version="1.0.300.v201903050508"; singleton:="true"
!ENTRY org.eclipse.jst.ws.axis2.creation.ui 4 0 2020-10-23 13:19:26.543
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.jst.ws.axis2.creation.ui [708]
Unresolved requirement: Require-Bundle: org.eclipse.jst.ws.consumption; bundle-version="[1.0.101,1.1.0)"
Unresolved requirement: Require-Bundle: org.eclipse.wst.common.uriresolver; bundle-version="[1.1.0,1.3.0)"
Unresolved requirement: Require-Bundle: org.eclipse.jst.ws.ui; bundle-version="[1.0.100,2.0.0)"
!ENTRY org.eclipse.jst.ws.axis2.ui 4 0 2020-10-23 13:19:26.551
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.jst.ws.axis2.ui [709]
!ENTRY org.eclipse.jst.ws.cxf.consumption.core 4 0 2020-10-23 13:19:26.558
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.jst.ws.cxf.consumption.core [717]
Unresolved requirement: Require-Bundle: org.eclipse.wst.ws; bundle-version="[1.1.0,1.2.0)"
Unresolved requirement: Require-Bundle: org.eclipse.jst.ws; bundle-version="[1.0.304,1.1.0)"
Unresolved requirement: Require-Bundle: org.eclipse.jst.ws.cxf.core; bundle-version="0.4.3"
-> Bundle-SymbolicName: org.eclipse.jst.ws.cxf.core; bundle-version="1.1.400.v201910301957"; singleton:="true"
org.eclipse.jst.ws.cxf.core [1903]
!ENTRY org.eclipse.jst.ws.cxf.creation.core 4 0 2020-10-23 13:19:26.567
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.jst.ws.cxf.creation.core [720]
Unresolved requirement: Require-Bundle: org.eclipse.jst.ws.cxf.core; bundle-version="[1.0.0,1.2.0)"
!ENTRY org.eclipse.jst.ws 4 0 2020-10-23 13:19:26.573
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.jst.ws [1894]
!ENTRY org.eclipse.jst.ws.axis.consumption.core 4 0 2020-10-23 13:19:26.588
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.jst.ws.axis.consumption.core [1895]
!ENTRY org.eclipse.jst.ws.axis.consumption.ui 4 0 2020-10-23 13:19:26.597
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.jst.ws.axis.consumption.ui [1896]
Unresolved requirement: Require-Bundle: org.eclipse.jst.ws.consumption.ui; bundle-version="[1.1.0,1.2.0)"
!ENTRY org.eclipse.jst.ws.axis.creation.ui 4 0 2020-10-23 13:19:26.603
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.jst.ws.axis.creation.ui [1897]
Unresolved requirement: Require-Bundle: org.eclipse.jst.ws.consumption.ui; bundle-version="[1.1.300,1.2.0)"
!ENTRY org.eclipse.jst.ws.consumption 4 0 2020-10-23 13:19:26.613
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.jst.ws.consumption [1898]
!ENTRY org.eclipse.jst.ws.consumption.ui 4 0 2020-10-23 13:19:26.620
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.jst.ws.consumption.ui [1899]
!ENTRY org.eclipse.jst.ws.creation.ui 4 0 2020-10-23 13:19:26.629
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.jst.ws.creation.ui [1901]
Unresolved requirement: Require-Bundle: org.eclipse.wst.ws.ui; bundle-version="[1.1.0,2.0.0)"
-> Bundle-SymbolicName: org.eclipse.wst.ws.ui; bundle-version="1.2.0.v201910301957"; singleton:="true"
org.eclipse.wst.ws.ui [2084]
Re: Eclipse hangs on boot [message #1833858 is a reply to message #1833760] |
Mon, 26 October 2020 13:12 |
It looks like part of that log was cut off, but a number of the unresolved bundles referenced in what's there aren't part of the IDE for Java Developers. Did you add something to it after installation?
_
Nitin Dahyabhai
Eclipse Web Tools Platform
Current Time: Tue Sep 24 23:54:57 GMT 2024
Powered by FUDForum. Page generated in 0.37303 seconds
