Hi guys,
I want to create a simple activity diagram in a package from the Model Explorer.
I get the UML-Object "ActivityDiagram_Online Shopping" from the Model Explorer (see ModelExplorer.JPG) with the function:
IStructuredSelection selection = (IStructuredSelection)
PlatformUI.getWorkbench().getActiveWorkbenchWindow().getSelectionService().getSelection();
EObject selectedElement = getSelectedEObject(selection);
CreateGraphicalElements graphic = new CreateGraphicalElements();
graphic.createSimpleDiagram(selectedElement);
The method getSelectedEObject delivers me the EObject:
public EObject getSelectedEObject(IStructuredSelection selection)
EObject selectedEObject = null;
if (selection != null)
selectedEObject = EMFHelper.getEObject(selection.getFirstElement());
return selectedEObject;
And with createSimpleDiagram() I want to create a new diagram with the CreateDiagramCommand:
public void createSimpleDiagram(EObject owner)
CreateDiagramCommand createDiagramCommand = new CreateDiagramCommand();
CreationCommandDescriptor creationCommandDescriptor = new CreationCommandDescriptor();
String name = "TestDiagram";
ModelSet modelSet = new ModelSet();[code][/code]
try
modelSet = ServiceUtilsForResource.getInstance().getModelSet(owner.eResource());
createDiagramCommand.createDiagram(modelSet, owner, name);
catch (ServiceException e)
System.out.println(e.getLocalizedMessage());
By debugging I find out that in the Class AbstractPapyrusGmfCreateDiagramCommandHandler the method getCreateDiagramCommand() throws a ClassCastException. The variable ViewPrototype prototype is cast to (DiagramPrototype) prototype (see ViewPrototype_DiagramPrototype.JPG) and the following Error is displayed:
org.eclipse.core.commands.ExecutionException: Error executing 'de.seppmed.papyrus.mbtassist.plugin.commands.ConnectMBTassist': java.lang.ClassCastException: org.eclipse.papyrus.infra.viewpoints.policy.UnavailableViewPrototype cannot be cast to org.eclipse.papyrus.infra.gmfdiag.common.helper.DiagramPrototype
at org.eclipse.e4.core.commands.internal.HandlerServiceHandler.execute(HandlerServiceHandler.java:170)
at org.eclipse.core.commands.Command.executeWithChecks(Command.java:488)
at org.eclipse.core.commands.ParameterizedCommand.executeWithChecks(ParameterizedCommand.java:487)
at org.eclipse.e4.core.commands.internal.HandlerServiceImpl.executeHandler(HandlerServiceImpl.java:213)
at org.eclipse.e4.ui.workbench.renderers.swt.HandledContributionItem.executeItem(HandledContributionItem.java:438)
at org.eclipse.e4.ui.workbench.renderers.swt.AbstractContributionItem.handleWidgetSelection(AbstractContributionItem.java:449)
at org.eclipse.e4.ui.workbench.renderers.swt.AbstractContributionItem.lambda$2(AbstractContributionItem.java:475)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java:89)
at org.eclipse.swt.widgets.Display.sendEvent(Display.java:4213)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1037)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:4030)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3630)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$5.run(PartRenderingEngine.java:1158)
at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:338)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:1047)
at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:155)
at org.eclipse.ui.internal.Workbench.lambda$3(Workbench.java:658)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:557)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:154)
at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:150)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:137)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:107)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:401)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:657)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:594)
at org.eclipse.equinox.launcher.Main.run(Main.java:1447)
at org.eclipse.equinox.launcher.Main.main(Main.java:1420)
Caused by: org.eclipse.e4.core.di.InjectionException: java.lang.ClassCastException: org.eclipse.papyrus.infra.viewpoints.policy.UnavailableViewPrototype cannot be cast to org.eclipse.papyrus.infra.gmfdiag.common.helper.DiagramPrototype
at org.eclipse.e4.core.internal.di.MethodRequestor.execute(MethodRequestor.java:68)
at org.eclipse.e4.core.internal.di.InjectorImpl.invokeUsingClass(InjectorImpl.java:319)
at org.eclipse.e4.core.internal.di.InjectorImpl.invoke(InjectorImpl.java:253)
at org.eclipse.e4.core.contexts.ContextInjectionFactory.invoke(ContextInjectionFactory.java:173)
at org.eclipse.e4.core.commands.internal.HandlerServiceHandler.execute(HandlerServiceHandler.java:156)
... 33 more
Caused by: java.lang.ClassCastException: org.eclipse.papyrus.infra.viewpoints.policy.UnavailableViewPrototype cannot be cast to org.eclipse.papyrus.infra.gmfdiag.common.helper.DiagramPrototype
at org.eclipse.papyrus.infra.gmfdiag.common.AbstractPapyrusGmfCreateDiagramCommandHandler$1.doExecuteWithResult(AbstractPapyrusGmfCreateDiagramCommandHandler.java:438)
at org.eclipse.gmf.runtime.emf.commands.core.command.AbstractTransactionalCommand.doExecute(AbstractTransactionalCommand.java:248)
at org.eclipse.emf.workspace.AbstractEMFOperation.execute(AbstractEMFOperation.java:150)
at org.eclipse.gmf.runtime.common.core.command.CompositeCommand.doExecuteWithResult(CompositeCommand.java:404)
at org.eclipse.gmf.runtime.common.core.command.AbstractCommand.execute(AbstractCommand.java:135)
at org.eclipse.papyrus.infra.emf.gmf.command.GMFtoEMFCommandWrapper.execute(GMFtoEMFCommandWrapper.java:123)
at org.eclipse.emf.workspace.EMFCommandOperation.doExecute(EMFCommandOperation.java:119)
at org.eclipse.core.commands.operations.DefaultOperationHistory.execute(DefaultOperationHistory.java:496)
at org.eclipse.papyrus.infra.emf.gmf.command.CheckedOperationHistory.doExecute(CheckedOperationHistory.java:208)
at org.eclipse.papyrus.infra.emf.gmf.command.CheckedOperationHistory.execute(CheckedOperationHistory.java:197)
at org.eclipse.papyrus.infra.emf.gmf.command.NotifyingWorkspaceCommandStack.doExecute(NotifyingWorkspaceCommandStack.java:266)
at org.eclipse.emf.transaction.impl.AbstractTransactionalCommandStack.execute(AbstractTransactionalCommandStack.java:165)
at org.eclipse.emf.transaction.impl.AbstractTransactionalCommandStack.execute(AbstractTransactionalCommandStack.java:219)
at org.eclipse.papyrus.infra.emf.gmf.command.NestingNotifyingWorkspaceCommandStack.execute(NestingNotifyingWorkspaceCommandStack.java:132)
at org.eclipse.papyrus.infra.gmfdiag.common.AbstractPapyrusGmfCreateDiagramCommandHandler.createDiagram(AbstractPapyrusGmfCreateDiagramCommandHandler.java:358)
at org.eclipse.papyrus.infra.gmfdiag.common.AbstractPapyrusGmfCreateDiagramCommandHandler.createDiagram(AbstractPapyrusGmfCreateDiagramCommandHandler.java:388)
at org.eclipse.papyrus.infra.gmfdiag.common.AbstractPapyrusGmfCreateDiagramCommandHandler.createDiagram(AbstractPapyrusGmfCreateDiagramCommandHandler.java:342)
at de.seppmed.papyrus.mbtassist.plugin.handlers.CreateGraphicalElements.createSimpleDiagram(CreateGraphicalElements.java:86)
at de.seppmed.papyrus.mbtassist.plugin.connector.ConnectMBTassist.execute(ConnectMBTassist.java:56)
at org.eclipse.ui.internal.handlers.HandlerProxy.execute(HandlerProxy.java:283)
at org.eclipse.ui.internal.handlers.E4HandlerProxy.execute(E4HandlerProxy.java:97)
at org.eclipse.e4.core.internal.di.MethodRequestor.execute(MethodRequestor.java:58)
... 37 more
What am I doing wrong?
best regards,
Yasin
