Home » Language IDEs » C / C++ IDE (CDT) » What is "resolving _WinMain@16 by linking to _WinMain"(C++, Eclipse)
What is "resolving _WinMain@16 by linking to _WinMain" [message #1833377] Sun, 11 October 2020 20:36 Go to next message
I'm still pretty new at c++ so don't be too harsh but when I was compiling, this warning happened:
c:/mingw/bin/../lib/gcc/mingw32/9.2.0/../../../../mingw32/bin/ld.exe: warning: resolving _WinMain@16 by linking to _WinMain
and here is my code if you all are wondering:
#include <iostream>
#include <cmath>
#include <SDL.h>
using namespace std;
double power(double base, int exponent)
double result = 1;
for(int i = 0; i < exponent; i++)
result = result * base;
return result;
int WinMain()
bool ttrue = true;
cout << "Hello would you like to use the Exponent Calculator? Type yes to continue.";
string answer;
cin >> answer;
if(answer == "yes")
ttrue = 1;
cout << "That's great! We'll need to find out a few stuff from you first. ";
else if(answer != "yes")
ttrue = false;
cout << "Then what are you doing here? Get out!";
if(ttrue == 1)
int base, exponent;
cout << "What is the base?: ";
cin >> base;
cout << "What is the exponent?: ";
cin >> exponent;
double myPower = power(base,exponent);
cout << "Your final answer is " << myPower << "!";
return 0;
as you can see, I am using WinMain because one of the libraries, SDL, requires the use of it. Changing WinMain to regular main will cause an error instead of a warning. Obviously, I want a warning-free compilation so any ideas?
Re: What is "resolving _WinMain@16 by linking to _WinMain" [message #1833410 is a reply to message #1833377] Mon, 12 October 2020 09:30 Go to previous message
Sounds similar to this article:
https://mail.gnome.org/archives/vala-list/2012-March/msg00079.html
_WinMain is the default for a missing WinMain in your code.
It could be because your WinMain doesn't have the proper signature.
Since you are using C++ this is critical.
INT WinMain(HINSTANCE hInstance, HINSTANCE hPrevInstance,
    PSTR lpCmdLine, INT nCmdShow)
    return 0;
An example using MinGW
https://www.transmissionzero.co.uk/computing/win32-apps-with-mingw/
Scroll down to The Application's WinMain Procedure
Previous Topic:"Nothing to build" problem
Next Topic:Unable to add some characters in editor.
Current Time: Fri Oct 31 06:14:12 EDT 2025
Powered by FUDForum. Page generated in 0.03459 seconds
