Home » Newcomers » Newcomers » Unable to Start Eclipse(After closing the application, which failed to save state, unable to open past flash screen)
Unable to Start Eclipse [message #1832884] Mon, 28 September 2020 13:26 Go to next message
I closed down Eclipse to restart my computer to complete installation of an unrelated application. I noticed that there was an error instead of the the usual "Saving workbench state...". Upon reopening Eclipse, I got an error:
An error has occurred. See the log file...
LOCATION_OF_FILE
The most recent entry in the log file seems to pertain to a missing file, which I believe had unsaved changes that it is trying to recover (I am used to Zend Studio which puts an asterisk beside unsaved files, so I forgot to save the file when I closed the entire application).
Hoping someone can lend a hand here as I am dead in the water as it stands. Here is the last entry:
!SESSION 2020-09-28 14:15:36.326 -----------------------------------------------
eclipse.buildId=4.17.0.I20200902-1800
java.version=14.0.2
BootLoader constants: OS=win32, ARCH=x86_64, WS=win32, NL=en_CA
Framework arguments: -product org.eclipse.epp.package.php.product
Command-line arguments: -os win32 -ws win32 -arch x86_64 -product org.eclipse.epp.package.php.product
!ENTRY org.eclipse.core.resources 2 10035 2020-09-28 14:15:37.532
!MESSAGE The workspace exited with unsaved changes in the previous session; refreshing workspace to recover changes.
!ENTRY org.apache.felix.scr 4 0 2020-09-28 14:15:37.564
!MESSAGE bundle org.apache.felix.scr:2.1.16.v20200110-1820 (42)Error while disposing components of bundle org.eclipse.core.resources:3.13.800.v20200706-2152 (92)
!STACK 0
java.lang.IllegalStateException: BundleContext is no longer valid org.eclipse.core.resources_3.13.800.v20200706-2152 [92]
at org.eclipse.osgi.internal.framework.BundleContextImpl.checkValid(BundleContextImpl.java:1027)
at org.eclipse.osgi.internal.framework.BundleContextImpl.ungetService(BundleContextImpl.java:697)
at org.apache.felix.scr.impl.logger.LogServiceEnabledLogger$1.removedService(LogServiceEnabledLogger.java:79)
at org.osgi.util.tracker.ServiceTracker$Tracked.customizerRemoved(ServiceTracker.java:969)
at org.osgi.util.tracker.ServiceTracker$Tracked.customizerRemoved(ServiceTracker.java:1)
at org.osgi.util.tracker.AbstractTracked.untrack(AbstractTracked.java:341)
at org.osgi.util.tracker.ServiceTracker.close(ServiceTracker.java:380)
at org.apache.felix.scr.impl.logger.LogServiceEnabledLogger.close(LogServiceEnabledLogger.java:91)
at org.apache.felix.scr.impl.logger.BundleLogger.close(BundleLogger.java:28)
at org.apache.felix.scr.impl.BundleComponentActivator.dispose(BundleComponentActivator.java:531)
at org.apache.felix.scr.impl.Activator.disposeComponents(Activator.java:429)
at org.apache.felix.scr.impl.Activator.access$300(Activator.java:49)
at org.apache.felix.scr.impl.Activator$ScrExtension.destroy(Activator.java:292)
at org.apache.felix.scr.impl.AbstractExtender$1.run(AbstractExtender.java:216)
at java.base/java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:515)
at java.base/java.util.concurrent.FutureTask.run(FutureTask.java:264)
at org.apache.felix.scr.impl.AbstractExtender.destroyExtension(AbstractExtender.java:238)
at org.apache.felix.scr.impl.AbstractExtender.bundleChanged(AbstractExtender.java:132)
at org.eclipse.osgi.internal.framework.BundleContextImpl.dispatchEvent(BundleContextImpl.java:945)
at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:234)
at org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEventSynchronous(ListenerQueue.java:151)
at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEventPrivileged(EquinoxEventPublisher.java:232)
at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEvent(EquinoxEventPublisher.java:138)
at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEvent(EquinoxEventPublisher.java:130)
at org.eclipse.osgi.internal.framework.EquinoxContainerAdaptor.publishModuleEvent(EquinoxContainerAdaptor.java:217)
at org.eclipse.osgi.container.Module.publishEvent(Module.java:499)
at org.eclipse.osgi.container.Module.doStart(Module.java:611)
at org.eclipse.osgi.container.Module.start(Module.java:468)
at org.eclipse.osgi.framework.util.SecureAction.start(SecureAction.java:506)
at org.eclipse.osgi.internal.hooks.EclipseLazyStarter.postFindLocalClass(EclipseLazyStarter.java:117)
at org.eclipse.osgi.internal.loader.classpath.ClasspathManager.findLocalClass(ClasspathManager.java:572)
at org.eclipse.osgi.internal.loader.ModuleClassLoader.findLocalClass(ModuleClassLoader.java:346)
at org.eclipse.osgi.internal.loader.BundleLoader.findLocalClass(BundleLoader.java:398)
at org.eclipse.osgi.internal.loader.sources.SingleSourcePackage.loadClass(SingleSourcePackage.java:41)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:473)
at org.eclipse.osgi.internal.loader.ModuleClassLoader.loadClass(ModuleClassLoader.java:171)
at java.base/java.lang.ClassLoader.loadClass(ClassLoader.java:522)
at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:151)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:401)
at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
at java.base/jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.base/java.lang.reflect.Method.invoke(Method.java:564)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:657)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:594)
at org.eclipse.equinox.launcher.Main.run(Main.java:1465)
!ENTRY org.eclipse.osgi 4 0 2020-09-28 14:15:37.564
!MESSAGE An error occurred while automatically activating bundle org.eclipse.core.resources (92).
!STACK 0
org.osgi.framework.BundleException: Exception in org.eclipse.core.resources.ResourcesPlugin.start() of bundle org.eclipse.core.resources.
at org.eclipse.osgi.internal.framework.BundleContextImpl.startActivator(BundleContextImpl.java:835)
at org.eclipse.osgi.internal.framework.BundleContextImpl.start(BundleContextImpl.java:763)
at org.eclipse.osgi.internal.framework.EquinoxBundle.startWorker0(EquinoxBundle.java:1011)
at org.eclipse.osgi.internal.framework.EquinoxBundle$EquinoxModule.startWorker(EquinoxBundle.java:365)
at org.eclipse.osgi.container.Module.doStart(Module.java:605)
Caused by: org.eclipse.core.internal.dtree.ObjectNotFoundException: Tree element '/ymsapp/application/common/models/api_client.php' not found.
at org.eclipse.core.internal.dtree.AbstractDataTree.handleNotFound(AbstractDataTree.java:260)
at org.eclipse.core.internal.dtree.DeltaDataTree.getData(DeltaDataTree.java:599)
at org.eclipse.core.internal.dtree.DataDeltaNode.asBackwardDelta(DataDeltaNode.java:54)
at org.eclipse.core.internal.dtree.NoDataDeltaNode.asBackwardDelta(NoDataDeltaNode.java:63)
at org.eclipse.core.internal.dtree.DataDeltaNode.asBackwardDelta(DataDeltaNode.java:51)
at org.eclipse.core.internal.dtree.DeltaDataTree.asBackwardDelta(DeltaDataTree.java:91)
at org.eclipse.core.internal.dtree.DeltaDataTree.reroot(DeltaDataTree.java:835)
at org.eclipse.core.internal.dtree.DeltaDataTree.reroot(DeltaDataTree.java:834)
at org.eclipse.core.internal.dtree.DeltaDataTree.reroot(DeltaDataTree.java:811)
at org.eclipse.core.internal.watson.ElementTree.immutable(ElementTree.java:522)
at org.eclipse.core.internal.resources.SaveManager.restore(SaveManager.java:731)
at org.eclipse.core.internal.resources.SaveManager.startup(SaveManager.java:1555)
at org.eclipse.core.internal.resources.Workspace.startup(Workspace.java:2452)
at org.eclipse.core.internal.resources.Workspace.open(Workspace.java:2210)
at org.eclipse.core.resources.ResourcesPlugin.start(ResourcesPlugin.java:489)
at org.eclipse.osgi.internal.framework.BundleContextImpl$2.run(BundleContextImpl.java:814)
at org.eclipse.osgi.internal.framework.BundleContextImpl$2.run(BundleContextImpl.java:1)
at java.base/java.security.AccessController.doPrivileged(AccessController.java:554)
at org.eclipse.osgi.internal.framework.BundleContextImpl.startActivator(BundleContextImpl.java:806)
... 27 more
Root exception:
!ENTRY org.eclipse.osgi 4 0 2020-09-28 14:15:37.595
!MESSAGE Application error
!STACK 1
java.lang.NoClassDefFoundError: org/eclipse/core/resources/IContainer
Caused by: java.lang.ClassNotFoundException: An error occurred while automatically activating bundle org.eclipse.core.resources (92).
at org.eclipse.osgi.internal.hooks.EclipseLazyStarter.postFindLocalClass(EclipseLazyStarter.java:126)
... 13 more
Caused by: org.osgi.framework.BundleException: Exception in org.eclipse.core.resources.ResourcesPlugin.start() of bundle org.eclipse.core.resources.
... 20 more
... 27 more
Re: Unable to Start Eclipse [message #1832885 is a reply to message #1832884] Mon, 28 September 2020 13:35 Go to previous messageGo to next message
While waiting on a response from the community, I decided to try the fix from this Stack Overflow article:
https://stackoverflow.com/questions/3505187/eclipse-wont-start-log-error-says-objectnotfoundexception-tree-element
However, the result of removing the SNAP files is the project is lost and an error saying "Cannot determine URI for '/ymsapp/application/common/models/api_client.php'." is displayed.
I backed up the SNAP files and restored them after, but unfortunately this did not bring my project back. So, I guess I should have waited for a response. Oops. Any ideas on how to get back on track, or should I just blow the whole thing up and start from scratch?
[Updated on: Mon, 28 September 2020 13:37] by Moderator
Re: Unable to Start Eclipse [message #1832902 is a reply to message #1832885] Tue, 29 September 2020 00:51 Go to previous messageGo to next message
It seems your workspace is quite corrupt. If that happened to me, and deleting the *.snap files didn't fix the problem, I would delete the <workspace>/.metadata/.plugins/org.eclipse.core.resources folder. The IDE should then come up with an empty workspace. Then I would use File -> Import... -> General -> Existing Projects into Workspace, locate my workspace folder (or wherever the physical projects are stored on disk), and thereby re-import those projects into my workspace.
You could also start with a new workspace and import the projects from the old workspace in the same way; note the "Copy projects into workspace" checkbox which can be checked to copy the projects from physically being in the old workspace folder to the new workspace folder.
You could also delete the entire <workspace>/.metadata folder, but that would loose all your workspace's preferences and configuration information; that shouldn't be necessary.
Re: Unable to Start Eclipse [message #1832930 is a reply to message #1832902] Tue, 29 September 2020 11:47 Go to previous message
Yeah, I ended up having to import the existing git projects. I'm not sure how it got so corrupted... I didn't do anything crazy, and this project is only a few days old.
Previous Topic:Eclipse 2020-06 failed to start after update
Next Topic:installing eclipse.
Current Time: Mon Sep 22 05:10:44 EDT 2025
Powered by FUDForum. Page generated in 0.07870 seconds
