Problem with Maven-Tycho build of Xtext project in GitLab CI [message #1832806] |
Fri, 25 September 2020 11:53 |
Martijn Hendriks Messages: 4 Registered: September 2020 |
We are building an Eclipse Xtext based project with Maven and the Tycho plugin. Everything works fine, except for the automated tests in GitLab CI/CD. These fail because somehow the main class in the org.eclipse.equinox.launcher dependency cannot be found:
148908 [INFO] Command line:
[/usr/lib/jvm/java-11-openjdk-amd64/bin/java, -Dosgi.noShutdown=false, -Dosgi.os=linux, -Dosgi.ws=gtk, -Dosgi.arch=x86_64, , --add-modules=ALL-SYSTEM, -Dosgi.clean=true, -jar, /builds/qrml/qrml-dsl/.m2/repository/p2/osgi/bundle/org.eclipse.equinox.launcher/1.5.700.v20200207-2156/org.eclipse.equinox.launcher-1.5.700.v20200207-2156.jar, -debug, -consolelog, -data, /builds/qrml/qrml-dsl/QRML_tooling/qrml-2.0/nl.tue.ele.es.qrml.parent/nl.tue.ele.es.qrml.tests/target/work/data, -install, /builds/qrml/qrml-dsl/QRML_tooling/qrml-2.0/nl.tue.ele.es.qrml.parent/nl.tue.ele.es.qrml.tests/target/work, -configuration, /builds/qrml/qrml-dsl/QRML_tooling/qrml-2.0/nl.tue.ele.es.qrml.parent/nl.tue.ele.es.qrml.tests/target/work/configuration, -application, org.eclipse.tycho.surefire.osgibooter.headlesstest, -testproperties, /builds/qrml/qrml-dsl/QRML_tooling/qrml-2.0/nl.tue.ele.es.qrml.parent/nl.tue.ele.es.qrml.tests/target/surefire.properties]
Error: Could not find or load main class
Caused by: java.lang.ClassNotFoundException:
Locally (windows environment, Maven 3.6.3, JDK 13.0.1) this works fine: tests are executed normally as expected during the Maven build. I tried to add the org.eclipse.equinox.launcher explicitly (test scope) but that doesn't help. Juding from the log files, the jar is present. The CI environment is an Ubuntu server with openjdk 11.0.8 and Maven 3.6.0.
Any hints or pointers on how to solve this are greatly appreciated, thanks!
Martijn
Re: Problem with Maven-Tycho build of Xtext project in GitLab CI [message #1832812 is a reply to message #1832809] |
Fri, 25 September 2020 13:06 |
Here is more logging:
148979 [INFO] ------------------------------------------------------------------------
148979 [INFO] Reactor Summary for nl.tue.ele.es.qrml.parent 1.0.0-SNAPSHOT:
148979 [INFO]
148979 [INFO] nl.tue.ele.es.qrml.parent .......................... SUCCESS [ 0.032 s]
148979 [INFO] nl.tue.ele.es.qrml ................................. SUCCESS [ 29.657 s]
148979 [INFO] nl.tue.ele.es.qrml.ide ............................. SUCCESS [ 0.885 s]
148979 [INFO] nl.tue.ele.es.qrml.ui .............................. SUCCESS [ 0.473 s]
148979 [INFO] nl.tue.ele.es.qrml.lsp ............................. SUCCESS [ 4.333 s]
148979 [INFO] nl.tue.ele.es.qrml.gen ............................. SUCCESS [ 4.231 s]
148979 [INFO] nl.tue.ele.es.qrml.target .......................... SUCCESS [ 0.004 s]
148979 [INFO] nl.tue.ele.es.qrml.feature ......................... SUCCESS [ 0.078 s]
148979 [INFO] nl.tue.ele.es.qrml.repository ...................... SUCCESS [ 1.147 s]
148979 [INFO] nl.tue.ele.es.qrml.tests ........................... FAILURE [ 1.214 s]
148979 [INFO] nl.tue.ele.es.qrml.ui.tests ........................ SKIPPED
148979 [INFO] BUILD FAILURE
148979 [INFO] Total time: 02:28 min
148979 [INFO] Finished at: 2020-09-25T09:12:10Z
148980 [ERROR] Failed to execute goal org.eclipse.tycho:tycho-surefire-plugin:1.7.0:test (default-test) on project nl.tue.ele.es.qrml.tests: An unexpected error occurred while launching the test runtime (process returned error code 1). Command-line used to launch the sub-process was null -Dosgi.noShutdown=false -Dosgi.os=linux -Dosgi.ws=gtk -Dosgi.arch=x86_64
148980 [ERROR] --add-modules=ALL-SYSTEM
148980 [ERROR] -Dosgi.clean=true -jar /builds/qrml/qrml-dsl/.m2/repository/p2/osgi/bundle/org.eclipse.equinox.launcher/1.5.700.v20200207-2156/org.eclipse.equinox.launcher-1.5.700.v20200207-2156.jar -debug -consolelog -data /builds/qrml/qrml-dsl/QRML_tooling/qrml-2.0/nl.tue.ele.es.qrml.parent/nl.tue.ele.es.qrml.tests/target/work/data -install /builds/qrml/qrml-dsl/QRML_tooling/qrml-2.0/nl.tue.ele.es.qrml.parent/nl.tue.ele.es.qrml.tests/target/work -configuration /builds/qrml/qrml-dsl/QRML_tooling/qrml-2.0/nl.tue.ele.es.qrml.parent/nl.tue.ele.es.qrml.tests/target/work/configuration -application org.eclipse.tycho.surefire.osgibooter.headlesstest -testproperties /builds/qrml/qrml-dsl/QRML_tooling/qrml-2.0/nl.tue.ele.es.qrml.parent/nl.tue.ele.es.qrml.tests/target/surefire.properties in working directory /builds/qrml/qrml-dsl/QRML_tooling/qrml-2.0/nl.tue.ele.es.qrml.parent/nl.tue.ele.es.qrml.tests
148980 [ERROR] -> [Help 1]
org.apache.maven.lifecycle.LifecycleExecutionException: Failed to execute goal org.eclipse.tycho:tycho-surefire-plugin:1.7.0:test (default-test) on project nl.tue.ele.es.qrml.tests: An unexpected error occurred while launching the test runtime (process returned error code 1). Command-line used to launch the sub-process was null -Dosgi.noShutdown=false -Dosgi.os=linux -Dosgi.ws=gtk -Dosgi.arch=x86_64
at org.apache.maven.lifecycle.internal.MojoExecutor.execute (MojoExecutor.java:215)
at org.apache.maven.lifecycle.internal.MojoExecutor.execute (MojoExecutor.java:156)
at org.apache.maven.lifecycle.internal.MojoExecutor.execute (MojoExecutor.java:148)
at org.apache.maven.lifecycle.internal.LifecycleModuleBuilder.buildProject (LifecycleModuleBuilder.java:117)
at org.apache.maven.lifecycle.internal.LifecycleModuleBuilder.buildProject (LifecycleModuleBuilder.java:81)
at org.apache.maven.lifecycle.internal.builder.singlethreaded.SingleThreadedBuilder.build (SingleThreadedBuilder.java:56)
at org.apache.maven.lifecycle.internal.LifecycleStarter.execute (LifecycleStarter.java:128)
at org.apache.maven.DefaultMaven.doExecute (DefaultMaven.java:305)
at org.apache.maven.DefaultMaven.doExecute (DefaultMaven.java:192)
at org.apache.maven.DefaultMaven.execute (DefaultMaven.java:105)
at org.apache.maven.cli.MavenCli.execute (MavenCli.java:956)
at org.apache.maven.cli.MavenCli.doMain (MavenCli.java:288)
at org.apache.maven.cli.MavenCli.main (MavenCli.java:192)
at jdk.internal.reflect.NativeMethodAccessorImpl.invoke0 (Native Method)
at jdk.internal.reflect.NativeMethodAccessorImpl.invoke (NativeMethodAccessorImpl.java:62)
at jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke (DelegatingMethodAccessorImpl.java:43)
at java.lang.reflect.Method.invoke (Method.java:566)
at org.codehaus.plexus.classworlds.launcher.Launcher.launchEnhanced (Launcher.java:289)
at org.codehaus.plexus.classworlds.launcher.Launcher.launch (Launcher.java:229)
at org.codehaus.plexus.classworlds.launcher.Launcher.mainWithExitCode (Launcher.java:415)
at org.codehaus.plexus.classworlds.launcher.Launcher.main (Launcher.java:356)
Caused by: org.apache.maven.plugin.MojoFailureException: An unexpected error occurred while launching the test runtime (process returned error code 1). Command-line used to launch the sub-process was null -Dosgi.noShutdown=false -Dosgi.os=linux -Dosgi.ws=gtk -Dosgi.arch=x86_64
at org.eclipse.tycho.surefire.TestMojo.runTest (TestMojo.java:1093)
at org.eclipse.tycho.surefire.TestMojo.execute (TestMojo.java:712)
at org.apache.maven.plugin.DefaultBuildPluginManager.executeMojo (DefaultBuildPluginManager.java:137)
at org.apache.maven.lifecycle.internal.MojoExecutor.execute (MojoExecutor.java:210)
148981 [ERROR]
148981 [ERROR]
148981 [ERROR] For more information about the errors and possible solutions, please read the following articles:
148981 [ERROR] [Help 1] http://cwiki.apache.org/confluence/display/MAVEN/MojoFailureException
148981 [ERROR]
148981 [ERROR] After correcting the problems, you can resume the build with the command
148981 [ERROR] mvn <goals> -rf :nl.tue.ele.es.qrml.tests
The "(test scope) " statement i dont understand. this is a tycho build, not a pure maven build correct?
do you have Xvnc/Xvfb etc running on Gitlab?
Yes, it is a Tycho build. The project has been created from the Wizard and only slightly modified. I will check whether a "clean" wizard project works on our GitLab.
FUDForum. Page generated in 0.03770 seconds
