Home » Modeling » TMF (Xtext) » generator denies to run
generator denies to run [message #1832370] Thu, 17 September 2020 04:36 Go to next message
i have installed the newest xtext 2.23.0 from a bundle provided which includes also the java se 11.0. I tried to execute a simple hello world with success. My next step is to create a button in the index.html. On button click event i want to call the generator which will only log out a hello world to the console.log of the running server.
index.html
<html>
<head>
	<meta http-equiv="Content-Type" content="text/html; charset=UTF-8">
	<meta http-equiv="Content-Language" content="en-us">
	<title>Example Web Editor</title>
	<link rel="stylesheet" type="text/css" href="xtext/2.23.0/xtext-ace.css"/>
	<link rel="stylesheet" type="text/css" href="style.css"/>
	<script src="webjars/requirejs/2.3.6/require.min.js"></script>
	<script type="text/javascript">
		var baseUrl = window.location.pathname;
		var fileIndex = baseUrl.indexOf("index.html");
		if (fileIndex > 0)
			baseUrl = baseUrl.slice(0, fileIndex);
		require.config({
			baseUrl: baseUrl,
			paths: {
				"jquery": "webjars/jquery/3.4.1/jquery.min",
				"ace/ext/language_tools": "webjars/ace/1.3.3/src/ext-language_tools",
				"xtext/xtext-ace": "xtext/2.23.0/xtext-ace"
		require(["webjars/ace/1.3.3/src/ace"], function() {
			require(["xtext/xtext-ace"], function(xtext) {
				xtext.createEditor({
					baseUrl: baseUrl,
					syntaxDefinition: "xtext-resources/generated/mode-mydsl"
				$("#generate-button").click(function() {
					//do smothing
				alert("clicked ")
				//editor.xtextServices.enableGeneratorService();
				//editor.xtextServices.saveResource();
				//var gen = editor.xtextServices.generate();
	</script>
</head>
<body>
<div ><button id='generate-button'>generate button </button></div>
<div class="container">
	<div class="header">
		<h1>Example MyDsl Web Editor</h1>
	</div>
	<div class="content">
		<div id="xtext-editor" data-editor-xtext-lang="mydsl"></div>
	</div>
</div>
</body>
</html>
MyDslGenerator.xtend
 * generated by Xtext 2.23.0
package org.xtext.example.mydsl.generator
import org.eclipse.emf.ecore.resource.Resource
import org.eclipse.xtext.generator.AbstractGenerator
import org.eclipse.xtext.generator.IFileSystemAccess2
import org.eclipse.xtext.generator.IGeneratorContext
import org.xtext.example.mydsl.myDsl.Greeting
 * Generates code from your model files on save.
 * See https://www.eclipse.org/Xtext/documentation/303_runtime_concepts.html#code-generation
class MyDslGenerator extends AbstractGenerator {
	override void doGenerate(Resource resource, IFileSystemAccess2 fsa, IGeneratorContext context) {
		fsa.generateFile('greetings.txt', 'People to greet: ' +
			resource.allContents
				.filter(Greeting)
				.map[name]
				.join(', '));
		println("this is the generator.xtend");
var JsonGenerator jg = new JsonGenerator();
	jg.generateJson()
JsonGenerator.java
package org.xtext.example.mydsl.generator;
public class JsonGenerator {
	public void generateJson() {
		 System.out.println("Starting genetator");
	  throw new UnsupportedOperationException("TODO: auto-generated method stub");
I don't now there is something missing in this call process. The problem is that i don't see if the methods are executed or the problem comes to the console . Is there any other connection point missing ?
Best Regards
[Updated on: Thu, 20 May 2021 11:01] by Moderator
Re: generator denies to run [message #1832371 is a reply to message #1832370] Thu, 17 September 2020 04:39 Go to previous messageGo to next message
did you check this one
https://www.eclipse.org/forums/index.php?t=msg&th=1073968&goto=1720505&#msg_1720505
besides that i recomment you to debug the server
Re: generator denies to run [message #1832379 is a reply to message #1832371] Thu, 17 September 2020 06:20 Go to previous messageGo to next message
Hi Christian,
thanks for your quick answer.
I have made these changes as you suggested
index.html
<html>
<head>
	var editor;
		if (fileIndex > 0)
		require.config({
			baseUrl: baseUrl,
			paths: {
				editor=xtext.createEditor({
					baseUrl: baseUrl,
					jQuery('#generate-button').bind("click", function(e){
					jQuery('#generator-result').html('<iframe style="width:1000px; height:200px;" src="http://' + location.host + '/xtext-service/generate?resource=example1.mydsl2"></iframe>');
					alert(location.host + '/xtext-service/generate?resource')
					e.preventDefault();
	</script>
</head>
<body>
	</div>
		<div id="xtext-editor" data-editor-xtext-lang="mydsl" data-editor-resource-id="example1.mydsl2"></div>
	</div>
	<div class="button-wrapper">
		<button id="generate-button" value="Generate" title="Generate">Generate</button>
		<div id="generator-result">
			Result
		</div>
	</div>
</div>
</body>
</html>
 * See [url]https://www.eclipse.org/Xtext/documentation/303_runtime_concepts.html#code-generation[/url]
		fsa.generateFile('/DEFAULT_ARTIFACT', 'People to greet: ' +
				.filter(typeof(Greeting))
				.map[name]
				.join(', '))
style.css
div.button-wrapper {
	display: block;
	position: absolute;
	top: 90px;
	bottom: 0;
	left: 640px;
	right: 0;
	padding: 4px;
	border: 1px solid #aaa;
Now i get this message inside the Iframe.
HTTP ERROR 400 Unable to identify the Xtext language for resource example1.mydsl2. URI: /xtext-service/generate STATUS: 400 MESSAGE: Unable to identify the Xtext language for resource example1.mydsl2. SERVLET: XtextServices Powered by Jetty:// 9.4.22.v20191022
Also in the console of the browser appears an error message
jquery.min.js:2
GET http://localhost:8082/xtext-service/generate?resource=example1.mydsl2 400 (Bad Request)
Failed to load resource: the server responded with a status of 400 (Bad Request)
The resource extension should be similar to the language being used in my dsl example ? In my case the xtext file is "MyDsl.xtext" . Also i can't get it work to display the message "this is the generator.xtend" in the console log of the sever.
Best regards
[Updated on: Thu, 20 May 2021 11:00] by Moderator
Re: generator denies to run [message #1832381 is a reply to message #1832379] Thu, 17 September 2020 06:27 Go to previous messageGo to next message
sure mydsl2 is your extension? and example1 the filename?
[Updated on: Thu, 17 September 2020 06:28] by Moderator
Re: generator denies to run [message #1832383 is a reply to message #1832381] Thu, 17 September 2020 06:38 Go to previous messageGo to next message
Sorry but i am a little bit confused .
Christian you mean that in my case the resource should have at list the extension "xtext" (because of my dsl language named "MyDsl.xtext")
If i get it right, the name can be anything because of a file creation (for example resource name with extension can be " myresource.xtext").
If this is the case ,then the generated file should be created in the same folder, where the generator is laying also. Correct ?
Best Regards
Re: generator denies to run [message #1832384 is a reply to message #1832383] Thu, 17 September 2020 06:41 Go to previous messageGo to next message
you define the file extension in the GenerateMyDsl.mwe2 file
Re: generator denies to run [message #1832385 is a reply to message #1832384] Thu, 17 September 2020 06:42 Go to previous messageGo to next message
and no the file name is the name the server knows the client side file under
<div id="xtext-editor" data-editor-xtext-lang="mydsl2" data-editor-resource-id="example1.mydsl2"></div>
vs
jQuery('#generator-result').html('<iframe src="http://' + location.host + '/xtext-service/generate?resource=example1.mydsl2"></iframe>');
Re: generator denies to run [message #1832386 is a reply to message #1832384] Thu, 17 September 2020 06:50 Go to previous messageGo to next message
I defined the xtension to be "mydsl".
Now i am getting a 404. The request resource was not found.
Should i first create the file "example1.mydsl" or is it something that the generator do? (Confussed++)
Re: generator denies to run [message #1832387 is a reply to message #1832386] Thu, 17 September 2020 06:51 Go to previous message
data-editor-resource-id="example1.mydsl">
and: please debug the server
[Updated on: Thu, 17 September 2020 06:51] by Moderator
Previous Topic:xText ParallelBuilderParticipant issue
Next Topic:Unresolved reference with dsl in jar library
Current Time: Thu Nov 06 12:54:56 EST 2025
Powered by FUDForum. Page generated in 0.05692 seconds
