Xtend template expressions are not resolved using Xtend Maven plugin [message #1832047] |
Mon, 07 September 2020 12:05 |
Zakir Meer Messages: 50 Registered: February 2016 |
Member |
Hello Experts,
I am using Xtend for model to text use-case. I am creating a RCP product and have used maven to build the product from the eclipse plugins.
I realized that the generated code from Xtend file, is different in both development envrionment (inside Eclipse IDE) and build envrionment (generated using Xtend maven plugin).
I realized that in the build environment, Xtend expressions are not resolved and the entire content is dumped as a text. Please find the below screenshot for reference
It will be helpful if you can let me know if I need to do some change in the build configuration to get the same output.
Note: I am using Xtext 2.20.0
[Updated on: Mon, 14 September 2020 14:54] Report message to a moderator
FUDForum. Page generated in 0.04071 seconds
