Re: Problems by installation Papyrus IDE [message #1832071 is a reply to message #1832064] |
Tue, 08 September 2020 06:15 |
Yasin Gül Messages: 10 Registered: September 2020 |
Now I have another issue.
When I want to run papyrus.product the console displays the following error:
!SESSION 2020-09-08 07:57:35.995 -----------------------------------------------
eclipse.buildId=unknown
java.version=1.8.0_251
BootLoader constants: OS=win32, ARCH=x86_64, WS=win32, NL=de_DE
Framework arguments: -product org.eclipse.papyrus.rcp.product --launcher.XXMaxPermSize 256m --launcher.defaultAction openFile
Command-line arguments: -product org.eclipse.papyrus.rcp.product -data C:\Entwicklung\Repositories\org.eclipse.papyrus\releng\rcp\org.eclipse.papyrus.rcp.product -dev file:C:/Entwicklung/Workspaces/papyrusdev/.metadata/.plugins/org.eclipse.pde.core/papyrus.product/dev.properties -os win32 -ws win32 -arch x86_64 -consoleLog --launcher.XXMaxPermSize 256m --launcher.defaultAction openFile
!ENTRY org.eclipse.equinox.app 0 0 2020-09-08 07:57:45.579
!MESSAGE Product org.eclipse.papyrus.rcp.product could not be found.
!ENTRY org.eclipse.osgi 4 0 2020-09-08 07:57:56.710
!MESSAGE Application error
!STACK 1
java.lang.RuntimeException: No application id has been found.
at org.eclipse.equinox.internal.app.EclipseAppContainer.startDefaultApp(EclipseAppContainer.java:246)
at org.eclipse.equinox.internal.app.MainApplicationLauncher.run(MainApplicationLauncher.java:33)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:137)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:107)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:401)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:657)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:594)
at org.eclipse.equinox.launcher.Main.run(Main.java:1447)
at org.eclipse.equinox.launcher.Main.main(Main.java:1420)
An error has occurred. See the log file
C:\Entwicklung\Repositories\org.eclipse.papyrus\releng\rcp\org.eclipse.papyrus.rcp.product\.metadata\.log.
In the attachments you can see also a warning about the product name.
Thanks for your help,
Yasin
[Updated on: Wed, 09 September 2020 08:37] Report message to a moderator
Re: Problems by installation Papyrus IDE [message #1832160 is a reply to message #1831978] |
Thu, 10 September 2020 13:01 |
Hi Again,
From the posted pdf it seems that you are trying to launch a non compiled product as a product (i.e. you are trying to launch the plugin containing what builds the products from the git you have imported in your workspace).
if you really want to have a RCP you will need to, either check it out from the published releases or archives, or build it yourself locally.
A good baseline if you are looking for pointers on what and where you can get it is the Papyrus website [1].
If you want to build your own, the compilation is meant to be done via maven from the poms located in the releng folder. The intended order is Main> Toolsmiths> RCP.
HTH,
/Quentin
[1] https://www.eclipse.org/papyrus/download.html
[edit] sorry for the delay I forgot to subscribe to the post and was not notified upon your new post.
[Updated on: Thu, 10 September 2020 13:05] Report message to a moderator
FUDForum. Page generated in 0.04456 seconds
