| Behaviour PC inclusion into Node PC [message #1831857] |
Tue, 01 September 2020 04:24  |
For convenience, in the Physical Architecture level, I moved the Behaviour PC into a Node PC. To do that, in the Project Explorer, I dragged and dropped the Behaviour into the Node.
When I run the model validation however, I get an error message stating that a Behaviour cannot be included into a Node.
I wonder why this hard constraint.
| Re: Behaviour PC inclusion into Node PC [message #1831885 is a reply to message #1831857] |
Tue, 01 September 2020 14:51   |
Hi Massimiliano,
First of all, you may decide to deactivate this validation rule because, in your context, you want to be able to do what you did. Validation rules can be activated/deactivated in Capella in the preference Window. I am not saying this is a good thing to do, especially that this validation rule generates an error meaning that you should avoid doing this.
Now on the reasons why this is like this, I may not have all the answers to your question, but here are a few things to consider:
- First of all, it enables you to have those elements of the same type all stored in the same place of your model (not sufficient reason on its own of course)
- I am sure you are aware that having a Behaviour PC into your Node PC as you did does not mean that your Node PC is deploying your physical component, this is another relation in Capella
- To me, one of the main reasons why Behaviour PC should stay all under the same folder is because, as you are doing System Architecture, part of your work will be to architecture your Behaviour PCs. And architecting components is done by containment in Capella. By architecting, I mean that you may group behavioral PCs together based on some architecture principles for instance.
- Also, you may reuse Behaviour PCs, so having them under on Node PC may not favor this.
More on this topic (although not 100% related to your question): https://polarsys.org/forums/index.php/t/101/
I hope this helps.
| Re: Behaviour PC inclusion into Node PC [message #1833972 is a reply to message #1831912] |
Thu, 29 October 2020 05:46  |
Is it possible to deploy existing undeployed BPC and undeploy already deployed one? There is no any difference between deployed and undeployed BPCs in Project Explorer, only one I can find is Deploying Physical Component link in Semantic Browser and Deploying Links/Parts in Properties of BPC, but those can't be edited. I can move deployed BPC between two NPCs on a PAB diagram, but I can't move it out of existing NPC and also I cant move undeployed BPC in to existing NPC in order to deploy it there. Any ideas?
FUDForum. Page generated in 0.04974 seconds
