Home » Eclipse Projects » Plugin Development Environment (PDE) » Ant ClassNotFoundException While Exporting A Plug-In
Ant ClassNotFoundException While Exporting A Plug-In [message #1831742] Thu, 27 August 2020 17:03
PDE Gurus,
Session info:
eclipse.buildId=4.16.0.I20200604-0540
java.version=1.8.0_232
BootLoader constants: OS=linux, ARCH=x86_64, WS=gtk, NL=en_US
Framework arguments: -product org.eclipse.epp.package.rcp.product -showlocation main
Command-line arguments: -os linux -ws gtk -arch x86_64 -product org.eclipse.epp.package.rcp.product -clean -showlocation main -data workspace.plugin
OS Info:
CentOS 7 - 3.10.0-1062.9.1.el7.x86_64
Problem:
I've been making some changes to our local Eclipse plugin recently, and exporting it via File->Export...->Plug-in Development->Deployable plugins and fragments.
This mechanism works a few times, but usually within three or so exports I'll start getting a panel that says:
'Export Plug-ins' has encountered a problem.
Could not find one or more classes:
"org.eclipse.ant.internal.core.ant.InternalAntRunner".
Please check the Ant classpath.
Once this starts happening then the export doesn't work again until I restart Eclipse.
The error log shows the exception at the bottom of this message.
Any clue what might be causing this?
Rob
Here's the exception spew:
java.lang.ClassNotFoundException: org.eclipse.ant.internal.core.ant.InternalAntRunner
at java.net.URLClassLoader.findClass(URLClassLoader.java:382)
at org.eclipse.ant.internal.core.AntClassLoader.findClass(AntClassLoader.java:53)
at java.lang.ClassLoader.loadClass(ClassLoader.java:418)
at java.lang.ClassLoader.loadClass(ClassLoader.java:351)
at org.eclipse.ant.core.AntRunner.getInternalAntRunner(AntRunner.java:399)
at org.eclipse.ant.core.AntRunner.run(AntRunner.java:319)
at org.eclipse.pde.internal.core.exports.FeatureExportOperation.runScript(FeatureExportOperation.java:468)
at org.eclipse.pde.internal.core.exports.FeatureExportOperation.doExport(FeatureExportOperation.java:305)
at org.eclipse.pde.internal.core.exports.FeatureBasedExportOperation.run(FeatureBasedExportOperation.java:62)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:63)
Previous Topic:PDE Build vs. Maven + Tycho
Next Topic:Eclipse product export fails if plug-ins have different EEs and "Generate p2 repository" s
Current Time: Tue Aug 05 09:22:42 EDT 2025
Powered by FUDForum. Page generated in 0.03343 seconds
