Re: What does letter R mean in installer name? [message #1830833 is a reply to message #1830818] |
Wed, 05 August 2020 03:34 |
Ed Merks Messages: 33141 Registered: July 2009 |
I'm not sure what you mean by it's called 'Eclipse Installer 2020-06 R' . Do you mean the path from which it's downloaded, e.g., oomph/epp/2020-06/R/eclipse-inst-win64.exe?
If you look on this folder, all the current and older versions of the installer are available:
https://download.eclipse.org/oomph/epp/
And there is an index file of them:
https://download.eclipse.org/oomph/epp/installer-index.xml
The R versions are the released versions. There can be M and RC versions as well, for the milestones and release candidates before the final release. There might also be an Ra, or an Rb version if I needed to respin the release for some reason.
Oh, maybe you mean on this page?
https://www.eclipse.org/downloads/packages/installer
This page is generated from the installer-index.xml mentioned above.
In any case, all these installers are "restricted" to install only products/packages for that corresponding release of Eclipse (when used in simple mode). Whereas the following ones are unrestricted and can install any version of Eclipse even in simple mode:
https://wiki.eclipse.org/Eclipse_Installer
The installer itself is self-updating, so you don't actually need to download a new one each time, but rather update it; updating it removes the restrictions...
Ed Merks
FUDForum. Page generated in 0.09457 seconds
